Question about Health & Beauty
Good afternoon I have a mobility scooter and the speed on it fluctuates between high and barely crawling. I have the speed on high and even though the batteries have just come off charge the scooter can be crawling and then all of a sudden it will take off and start speeding or anything in between. After being told it was my batteries I?ve bought two new ones but I still have the problem. The speed of it is becoming a safety issue now as I?ve been caught on the road with cars coming my way and the scooter is not moving. Do you have any ideas what the problem is from this description and much it is likely cost to fix? Thank you Louisa New
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 346 Answers
Louisa,some of these so called repairers as they are refered to could not fill a postage stamp up with their knowledge.I am disabled myself,i spent 3 months depressed on my settee & £700 in parts alone to be left in the same situation.But being me lol,i refuse to lie down so i went about learning all i could so i did the job myself,it was 1 frustrating job,but my learning will be given to anyone like you.Please rate mwe as in thumbs up 1 to 4 for my answer.As you see i care.
Please visit:WWW.ALLDATASHEET.COM Download as a PDF File to an Adobe Reader:troubleshooting_2007 SHOPRIDER.pdf
This is an Adobe Acrobat Document.This document is 36 pages long,pages 19 to 36 refer to electric wheelchairs,but 1 to 19 covers batteries & scooters.Ihope i have helped ya dear.I may be wrong but going on what you have wrote,i doubt it was your batteries,did the repairer get them drop tested?.Finally save this file i gave you to an Adobe Reader & as i did print & save to a polythene sleeve folder for future.I HOPE YOU HAVE YOUR WHEELS BACK SOON,ANY PROBLEM ASK AGAIN[COLIN 4 HELP]
Posted on Oct 12, 2010
My Prorider mobility scooter judders in low speed and in high speed the speed fluctuates and jolts forward quite a lot. Anyone know what's causing it?
If a tech can't find a mechanical defect then I would look at the speed control unit hidden in the bodywork.
May 14, 2015 | Health & Beauty
I compare it to a gas motor with a miss.
Could be your carbon brushes. Really easy job to check. The brushes are located inside the motor housing and are covered by 2 or 4 black caps depending on your scooter model. You simply undo the caps and remove the Brush. Check that there is plenty of carbon material left and that the spring and contact are in good condition and that the Brush slides freely through the housing. Sometimes a sticking brush or bad contact can cause power fluctuations..... Let me know how you get on.
Jul 22, 2014 | Pride Mobility Revo 3 Wheel Electric...
Speed fluctuating on controller. goes from slow to fast without me touching controller on pride jazzy 614 hd battery powered chair
Your controller is dirty. Unfortunately, the unit is sealed and you therefore can do other than replace the unit. I suggest monster scooter parts at Jazzy 614 HD Parts The cost is high at $377.00. If you were really into fixing electronics it is possible to take the unit apart and clean the joystick, but that is a stop gap measure until you get your new joystick. Let me know if you need instructions on tearing the joystick apart and I will help if I can.
Jul 22, 2014 | Pride Jazzy 614 Hd JAZZY 614HD
I have a invacare agura mobility scooter with new batteries but the power lights fluctuate in use the lights go down fairly quick if i turn the scooter off for 2/3 seconds the lights go up for a short time
if it is not making a difference in speed sounds ok deep cycle batterys run at same amps until completely dead this is when they should be charged for 8 hours most chargers are auto shut off
Mar 18, 2013 | Invacare Health & Beauty
New battery. hooked up correctly. But, scooter will still barely go in reverse super slow. forward speed slow .can throttle cable be problem/ when I push inside of speed lever it moves faster. pushing ends...
Hi. Did the machine used to operate properly in the past? Sometimes previous owners or technicians have changed the programme for owners for different uses. What you describe sounds like a faulty throttle pot ( Wig Wag ). I have changed many throttle pots for this reason.
Also check battery and motor connectors.
Do you have another switch on the machine for controlling the speed, such as an indoor/outdoor switch? Good luck. Neil.
May 12, 2010 | Activeforever Lynx L4 Portable Mobility 4...
I have a 2002four wheel Legend Mobility scooter.
Hi. A lot of scooters have a seperate switch to select a high or low speed setting.
This switch is sometimes labeled indoor/ outdoor.
I have had a few scooters with a similar fault, and the wires that connect to the high/low switch have broken of the terminals on the rear of the switch.
It could also be a faulty speed control pot.
Check these and good luck. Neil.
Mar 08, 2010 | Pride Mobility Products Legend 4-Wheel...
When moving at top speed, my scooter hesitates at times until lately when it has slowed down to a crawl, then it will speed back up again. The charge meter is in the green area and I am consistently...
hi, that is a textbook problem related to the speed controller pot,
the pot is attached to the lever you move to go forward etc,
to be 100% certain trying moving the lever in the upwards direction while gong forward ? does it speed up ,a new speed pot required.
Regards
GeWiz.
Oct 21, 2009 | Pride Value Line Revo Scooter 3 Wheel
After a series of stop start problems I have tested the 5k pot ( made by Clarostat) on my friends Pride Legend and it is very unstable. I have purchased a linear 5k potentiometer of a high specification...
the best way to do any job is to make sure you are correct before undertaking any job.put together a good update of your problem & ring the people direct,speak to in person someone qualified then you will be sure,rather than make a mistake & add to the problem.
Jul 21, 2009 | Drive Medical Mini Phantom Three Wheel...
Health & Beauty Logo
81 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
