Question about GE Monogram ZE2160SF Convection / Microwave Oven
If a microwave dosent get hot when on is it fixable and is it expensive
  • GE Master
  • 43,501 Answers
Hi, Yes, and yes...
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Oct 12, 2010
The vent will turn on randomly and not turn off!
Most over the range microwaves have a heat safety system built into them. If for instance you are cooking on the stove top for a long period of time on the burner directly under the micro control panel and the control panel get too hot, a thermostat in the microwave will automatically turn on the vent fan to help keep the control panel cooled off. My guess is that the safety thermostat (usually right behind the bottom of the control panel) may be going bad and needs replaced.
Apr 03, 2015 | Kenmore 30" Microwave Combination...
Is the clock that has stopped working fixable?
Yes, but ... If this truly is a failure, you're looking at replacing the clock/display/control board. This is usually a VERY expensive solution. In some cases more than it's worth as compared to replacing the entire microwave. The clock not 'sticking' is a rather unusual complaint. I'd highly recommend that you dig out the owner's manual - or check on-line for one if you can't find / don't have - to make sure you're not missing a step while setting the clock.
Jul 07, 2014 | Amana ACO1840A Microwave Oven
Microwave gets really hot on inside, especially the right wall, but the food will not get hot at all
it seems that the right wall inside of the microwave is absorbing most of the microwave energy. If the panels are replaceable then you might want to consider having them replaced but it probably wouldn't be worth it. Maybe buying a new microwave will save you a lot of expense and grief.
Good luck
Dec 25, 2013 | GE XL1800 1100 Watts Microwave Oven
Everything runs on my microwave but it will not get hot. what can i do to fix this problem?
The magnetron will more than likely need replacement, one of the most expensive parts in the microwave oven. If the item is more than five years old consider a new microwave oven
Mar 05, 2012 | GE JE2160 Microwave Oven
We have a GE Microwave Model# JVM1660 and the turntable dosent work
the spindal motor under the microwave in some cases burn out these units are not expensive to have replaced you will need to find a local microwave tech in your are
best wishes
Dec 29, 2010 | GE Microwave Ovens
Mbbs/01 microwave makes noise when turned on and doesn't get hot. Is it fixable or need to be replaced?
Sorry to read about your problem, I hope this helps you out.
yes they are all fixable..just depends on repair cost
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 25, 2010 | Thermador MBBS Microwave Oven
I touch the touch pad and nothing happens
Hi!!
Try unplugging unit from the wall outlet for 5 min. If the key pad still do not respond, it may have become defective they are not fixable. Replacing the key pad it is often more expensive then buying a new unit.
Spills and directly spraying cleaner solutions into keypad will eventually cause it to fail.
The correct way to clean the front of your microwave is to apply a small amount of the cleaner solution to a cleaning cloth and then wipe the keypad clean
Show your appreciation with a 4 THUMBS Rating for answering your FREE question. Thank you for using FixYa
Oct 03, 2010 | Samsung MT1088SB 1000 Watts Convection /...
My microwave makes an awful noise sometimes. And now it won't heat anything up, and makes a funny smell. Is this fixable?
That's usually the sign of a bad magnetron tube, the microwave source. The tube can be replaced, but it's an expensive part. With repair labor, it may be not cost much more to replace the oven. Microwave repair is best left to professionals because of lethal voltages under the cover and the chance of microwave leakage if repairs aren't done properly. Take this to a shop for an estimate, then decide whether to fix or replace.
Mar 31, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
The glass turntable broke in 3 pieces this morning while cooking bacon. The bacon was not yet cooked or even hot. It broke into 3 large pieces. The unit is not at all new. Does this sound normal? Did I do...
The same thing happened to my microwave this morning while heating a cup of water, which broke into 3 pieces too before the water hadnt even hot.
Maybe you have already solved your problem and I just share my experience.
I am trying to call the manufacturer nearby and ask for the turntable, but I am afraid the new turntable dosent fit my a little bit old microwave.
Dec 27, 2009 | Microwave Ovens
MIcrowave doesn't heat up food
heatman101
fdyjhd
Jul 18, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Monogram ZE2160SF Convection / Microwave Oven Logo
96 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
