Question about Home
How do you unlock a vita spa. is lock i already turn the breaker off and on and did not work
  • jon Debelak Aug 21, 2012
    i have the same problem, how did you fix it?
I have a vita spa an it is locked how do I unlock it
Posted on Nov 17, 2013
When you wire a vita spa do you need a service engineer or can you do it yourself
You can as long as you don't mind getting electrocuted if you get it wrong.
You have a dead short, so you will need to check every wire with a meter until you find the one that is earthed. First place to check would be your pump and then the lights, and the heater and the control panel.
Another way to check would be to disconnect those items and then turn on your breaker. When you find the component that has been disconnected and the breaker doesn't trip will indicate the item that is causing it, or the wiring to that item.
My advice is to get it fixed and serviced professionally. Also they may well have seen this problem before.
Apr 16, 2016 | Pool & Spa
Vita Spa DX series. Why does it keep blowing fuses when I turn on breaker?
You have a dead short to earth. Basically a bit of electricity wants to kill you. The fuse trips to save your life. You need a service engineer.
http://vitaspa.com/
Home
Apr 15, 2016 | Pool & Spa
Unlock hot tub control panel
Panel needs to be in the display of "Time" 1st. If not, push the "Prog" button to get there. Once the Time is displayed, push & "Hold" the "UP" button for at least 5 seconds. The Lock icon/symbol will be displayed - panel is locked. Release and hold the UP button again for at least 5 seconds, the panel will then be unlocked.
Nov 29, 2013 | Pool & Spa
I have a vita duet spa. It has a pb error and the jets or the lights will not turn on. Any suggestions?
Vita Spa Error code (PB) is a power board communication error. Turn off the power and then check the connection between the topside control and control box. check for loose or unplugged wires, unplug the topside control (after turning off the power) and check for signs of shorts or charring on the wiring ribbon/connectors. If you cannot find the source of the problem you will need to contact your dealer or repair technician. I hope this helps =)
Nov 03, 2013 | Dream Maker Spas Dream Maker Ez Spa Hot...
Power trips out when jets are switched on
I'm going on somewhat limited information here not knowing if the tub is newly installed or if this is a spa that has been working in the past and just started doing this. It would be helpful to know if this is a recently installed pump as well. That said here are a few things to check.
If it's a new install: Your electrician has more than likely wired the spa incorrectly. Be sure that the spa pack has 220V going into the pack and that the GFCI is wired correctly.
If it's an old spa with a new problem: A lot of times a bad heater element can cause a spa to trip the breaker. If you have a bad element the spa will operate normally for about a minute when you turn the power on, then trip the breaker as soon as the heater kicks in.
If it only trips the breaker when the pump is turned on to high speed, more than likely there is a problem with the wiring of the pump or the relay on the pump itself.
May 04, 2013 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Air lock for my aruba spa hot tub how do i fix it
This sounds like a problem with the circuit board inside the spa control box.Do this:
  • Turn the breaker off
  • Unplug everything that is plugged into the circuit board i.e. the pump, heater coil, air blower, light etc.
  • Turn the breaker back on
If the circuit board stays on then you have to go thru the process of plugging one item at a time turning the breaker on then off to find the part that is bad.
Rod
US Parts Center
888-521-6183
Dec 19, 2012 | Pool & Spa
Need manual for a vita bijou hot tub
Vita Spa is now out of business, so contacting the factory isn't a option. You can try googling for an online manual download. They usually cost between $10 and $15.
Jun 14, 2010 | RTO 2 Person Spa Hot Tub 8 Hydrotherapy...
Hi E2 will not lite gives me a ignition lock out code
it try to turn on 3 times thant lock out. turn off breakers for 10 sec and turn back on. this will unlock the heater but? what is making the heater not to work is due to not flame at all this may have several possibilities like gas valve ignition control hot surface ignitor etc,etc, etc,
Oct 09, 2009 | Teledyne Laars Pool & Spa
I have a Homeline Load Center circut breaker Catolog # HOM48l125GRB, which was installed for my spa. Each summer the spa is drained and the circut turned off. I turn it back on in the fall. However, this...
You have 1 of 2 problems #1 the breaker overload element is bad=replace breaker, #2 You have a shot somewhere in your line feeding your spa, make sure you have power to the line side of your panel/breaker. hope this helps you...
Oct 03, 2009 | Square Homeline Circuit Breaker
Hot tub maintenance
there will be the same amount of basic maintenance on either spa. The difference will be in water chemistry. you definitely want an ozone generator on either spa. Both are awesome Mfg of spas. they both have been around since the 1980's
Ozone will keep the water cleaner, fresher smelling and reduce the total amount of traditional chemicals used in any hot tub.
There are many other solutions for taking care of water chemistry out there without using the traditional types.
some are all natural.
Jan 02, 2009 | Waterway Spa Pump & Hot Tub Pump 1.5"...
Home Logo
384 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
