Question about Olevia LT37HV 37 in. HD-Ready LCD Television
We have a Olevia Syntax 337-B11. The T.v. does not have a place to plug in a regular male cable jack.Instead it has a s- video jack, a hdmi, jack and numerous other jacks. What do you need , as in jack cables or just what do I do with a T.V. that has no female coax plug in on the back of the T.V.?
5 Suggested Answers
tvtek
  • 1284 Answers
SOURCE: The HDMI port on my Olevia Model 337-B11 LCD tv
Without replacing the main board, probably not. Did you try another HDMI source to verify the TV is at fault? If it is the cheapest fix is to use component only.
Posted on Sep 10, 2009
Testimonial: "Thanx for the quick response! Plan A is to use component/S-Video inputs but plan B is replace the board, if I can find one. Thanks Again!"
dave1645
  • 834 Answers
SOURCE: I have a olevia 337-B11 HD-ready TV, which kind of
you need a quam tunner your best bet would be to get the box from your cable company set toop boxes are not cheap for hd
Posted on Nov 28, 2009
Testimonial: "thanks for the info."
SOURCE: Olevia 337-B11 how to connect to a TV
Unfortunately, This hdtv can only use with receiver. There is no cable connection back of it. You may connect it using with HDMI cable.
Posted on Jan 29, 2010
  • 3 Answers
On Olevia TV's ( at least the 542 ) there is a hdmi daughteroard that connects to the main board. These can fry. I got one sent to me under warrantee from Olevia - and it fixed my hdmi problem. The 337 might use a different part #.
Posted on Jul 27, 2010
Olevia 342 b11
On the remote select menu
Go to audio input set up
Choose HDMI
Mar 25, 2014 | Televison & Video
I have an Olevia 242tfhd television that just stopped working. The blue light was on and when I pressed it- it wouldn't turn on and the blue light went off. I unplugged it for a day and when I plugged it...
Same happened with my Olevia 540-B11. You can probably find the details of how to disassemble the TV somewhere online. The problem is poor stress-relief on the cables that plug into the secondary (low voltage) side of the power circuit board (PCB). Once the back is removed you'll find the PCB on the left side with three cables connected to the very top of the board. These cables plug into four clips, 3 horizontal clips side-by-side at the top and one vertical clip on the left side. Unplug these cables, remove the PCB and re-solder the sockets (there are approximately 40 solder points on the back of the board). Reassemble your TV and it'll work just fine.
Dec 15, 2010 | Syntax-Brillian Olevia 242TFHD 42 in. LCD...
I tryed to connect coby speaker (model number - csp42) up to my olevia 337-b11 tv and i can only hear sound through the bulit in speakers in the front of the tv and not out of the coby speaker! the coby...
Does your TV have an Audio out? This is the only way that you can get signal to feed to your coby speakers and make sure that your coby speakers has an amplifier.
Apr 03, 2010 | Olevia LT37HVS 37 in. LCD HDTV
My menu says dtv Currently unavailable. How do I use the HD feature on my Olevia LT32HV
Do you have a High Definition cable/satellite reciever or a Blu-Ray player? Does your tv have a HDMI input or component or DVi or all of those? Most newer HD components use the HDMI connection. The HDMI connection is a single cable that has both video and digital audio together. The component connection is a connector with three rca jacks that are red, green, and blue. Audio is connected seperately with this connection via red and green rca audio jacks or a digital audio connector. The last is a DVi connector that is found on computers. Some older HD tvs and components use this connection. There are adapters available to turn a DVi connection into a HDMI connection. So if your TV does not have a HDMI connection but your HD reciever does you can use and adapter but you will not have any audio this way without using a seperate connector for the audio.
Sep 16, 2009 | Syntax Olevia LT32HV 32 in. HD-Ready LCD...
The HDMI port on my Olevia Model 337-B11 LCD tv quit working. Is there an easy fix?
Sep 10, 2009 | Olevia Televison & Video
Purchased TV without stand
You could try calling this number 866-965-3842 its a 3rd party repair center that services Olevia televisions.. but they might be able to sell you a stand..
Jul 06, 2009 | Syntax Olevia 537H Television
Nov 30, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Olevia 337 B11 Power Problem
Olevia sugested repl. the Main board
Mar 05, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Olevia LT37HV 37 in. HD-Ready LCD Television Logo
139 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
