Disk back up
I have tried a variety of disks but whenever i try to use my cd writing wizard it does not recognise that there is a disk in the drive.
  • 85 Answers
Clean lance of your cd/rw
there is some problum in your cd/ rw
Posted on Jun 01, 2008
DVD drive recognised but disc not recognised
not sure how its recognised on control panel
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
Apr 05, 2012 | NEC MultiSpin ND-1300A (ND-1300A)...
Not recognising any blank medis. Or if recognises, it tries preparing and then fails with 'Invalid disk'
For a barcode scanner?
The only ones I've seen with disks use floppies, so try using a cleaning disk in the drive, if that doesn't work, you may need to replace the floppy drive.
It's also possible you have 1.44MB floppies and the scanner only recognises 720K, but the drive itself sees the 1.44MB.
Simple fix for that is to use string scotch tape or a strip of packing tape to cover the hole ACROSS from the write protect hole (write protect hole usuaullyhas a slider in it, otherwise they are the same size hole)
Aug 31, 2010 | Computers & Internet
Wd elements 1tb hdd write protected help
the volume of the partiton is corrupted, u need to use winpe mini cd or hirens boot disk to realocate partitions and fix the volume with active partiton recovery programe.
or an alternative way, use a linux live cd, mount the drive and copy the needed files to your primary hard disk, then go back to windows and accept the format, than recopy the files
Apr 28, 2010 | Computers & Internet
Computer does not seem to recognise disc. I keep
Hello !
Either your disk or disk drive is problematic.
Try your disk in another PC to test. If the disk works, your CD drive is faulty. Try another disk in your computer's drive. If the disk doesn't work, you have confirmed that the drive is faulty.
If the drive is a problem, I would suggest to purchase a disk head cleaner, first. Then, if the drive is still a problem, it would need replacing.
Hope this helps.
Sep 10, 2009 | Lexmark Office Equipment & Supplies
Can my cd /dvd player write too?
You can also verify the users manual. Mostly you can see some code in the CD-ROM like: DVD-RW= Can write CD and DVD DVD-R= Can only read DVD's CD-R= Can only read cd's. CD-RW- Can write CD's only.
Jun 10, 2009 | Computers & Internet
Toshiba sd-r2002 - won't recognize blank CD when trying to write files to a CD
right click on the drive.... go to properties... under tab recording, remove tick "enable CD recording on this drive" and press apply... after that tick "enable CD recording on this drive" and press OK.
It should work.
Jun 01, 2009 | Toshiba SD R2002 CD-RW/DVD-ROM Burner
I want USB port Driver for detect
No mention of Brand of Pen Drive so I would start there first.
Try www.pendrive.com
Also no mention of when the latest updates were done ,hmmm
Normally should auto recognise when plugged in
(should do anyway)
When you install usb drive,
and drive does not appear be present,
SOLUTION...............................................................
Assuming your using XP,
go to start
then my computer,
right click,manage,
disk management,
This will put you in the area where you can check the health and activitys of your hard drives,
If this drive was recognised in the port then it will be visable in this area,
here you can right click on the drive and update the individual drivers of each device that may have issues.
So go ahead right click and update the drivers,
click I have disk on the wizard prompt and let the wizard search for the correct drivers,
if it comes back saying please insert cd then let the wizard search the internet for the correct drivers.
If this does not fix the problem then a Factory Default Reinstall will fix this.
If the issue still remains after these steps its the motherboard replacement time.
BACK UP BEFORE FORMATTING.......
Jun 27, 2008 | Acer Aspire 3000 Notebook
CD-RW/DVD-ROM wont write to 8x disks
My combo drive is unable to read any files in DVD. Please let me know what should be done.
Combo Drive SM-352F
May 12, 2008 | Samsung SM-352F CD-RW/DVD-ROM (Combo)...
I can write cds and dvds and when you go to the disk drive on my computer you can see the items on the disk but when i remove the disk and then put it back in the drive does not read the disk for some...
if u trying to read another cd...
if can read..
mayb u write the cd speed to high..
if u write the cd speed to high and u cd drive speed is lower , u cannot open that...because your cd drive speed is low..
try to write cd use a lower speed,its mayb can be read..
happy trying.
good luck
Apr 17, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
