Question about Keurig Platinum B70 Coffee Maker
When the screen says "Not Ready" the water just runs through until the reservoir is empty. Then it says "Add Water" When I remove the resevoir and fill it with water, replace it, then it is ready to brew. It will brew one cup, then after the cup is brewed the "Brewing" message remains on for about one minute. It finally shuts off. When I turn it back on, the screes says "Not Ready" and the water begins to run through again until it is all gone. It keeps repeating this cycle.
    Champion:
  • 248 Answers
Turn on,wait for it to say add water,then put water in-dont put water in first
Posted on Oct 12, 2010
2 Suggested Answers
  • 3 Answers
SOURCE: Water doesn't come down when brewing
I had the same problem, and it turned out it was the top needle that was clogged. I used a safety pin to clean out the needle and it worked again . . . I descaled immediately, just in case it needed that too. I am back to coffee goodness!
Posted on Jul 11, 2010
Eurig B70 empties the entire reservoir when turned on
Buy a saeco you'll never look back
I've had mine for four years and do the cleaning as required
It has pulled 15468 coffees and still going strong
It did cost a pretty Pennie but you get what you pay for
My condolences to your coffee machine
Jan 04, 2014 | Keurig Platinum B70 Coffee Maker
Kureig heats but won't brew
The exit needle could be clogged located( inside bottom of the holder assembly). Remove K-cup assembly and detach funnel. Insert a paper clip or simiilar tool into the exit needle to loosen the clog and push it out. REMEMBER, the needles are very sharp, proceed with caution!!
You may also need to Descale your Keurig...I do this every other month due to high mineral content in my potable water. Change out resevoir filter and clear exit needles as part of Descaling. Disable "auto shut off" feature, remove reservoir filter and do not use a kcup prior to proceeding. Place 48ounces of white vinegar into reservoir, press brew, discarding each mug of water down kitchen drain and repeat until "Add Water". Let brewer stand for four hours in "On" . Rinse after 4 hours by filling water reservoir with fresh water and press brew until ADD WATER is indicated.
I run two full fresh water cycles before actually using the Keurig for beverages I will consume.
Hope this helps
Nov 17, 2013 | Keurig B60 Coffee Maker
Will not brew says it is ready
TRY...1. Lift up the water reservoir and drop it back into place. There is a magnet that has to be in the right position and putting the reservoir back into place causes it to go back where it should be.
2. It may be time to descale. Most models will give you a message when it's time to have the mineral deposits cleaned.
HERES HOW TO DO THAT...
Empty water resevoir. Disable auto off. Pour approx 48 oz of undiluted white vinegar into resevoir. PLace large mug on drip plate, run brew cycle, dump contents of mug in sink. DO NOT USE A K-CUP.
Repeat this process until the add water light is indicated.
Let brewer stand for at least 4 hours while still on.
Discard any residual vinegar in the resevoir and rinse thorughly.
AFTER approx 4 hours...fill resevoir with water.
RINSE:
PLace a large mug on the drip plate and water brew cycle. Pour the contents of the mug into the sink.
REPEAT this brew process until the add water light is indicated.
YOU MAY NEED TO REPEAT THIS "RINSE" PROCESS if you notice any residual taste.
Nov 10, 2013 | Keurig Special Edition B60 Coffee Maker
Need to descale k75.
RINSE:
Nov 02, 2013 | Keurig K75 Black Platinum Coffee Maker w...
My Keurig B40 will not brew. I have turned it on and off several times, refilled with water and pressed the brew button. Every time it makes the noises, heats the water, and SOUNDS like it is pumping water...
TRY 1. Lift up the water reservoir and drop it back into place. There is a magnet that has to be in the right position and putting the reservoir back into place causes it to go back where it should be. This method has worked for me.
or 2. It may be time to descale. Most models will give you a message when it's time to have the mineral deposits cleaned.
RINSE:
Oct 14, 2013 | Keurig Coffee Makers & Espresso Machines
Water spits in tank but all inlets are open
RINSE:
Jun 19, 2013 | Keurig B100 Coffee Maker
Leaking water out of bottom and will not brew a full cup
RINSE:
Apr 14, 2013 | Keurig Platinum B70 Coffee Maker
Water just trickle half cup
RINSE:
Mar 01, 2013 | Keurig B31BLACK Mini Brewer Black 1-c
How do i clean my Keurig?
RINSE:
Feb 24, 2013 | Keurig Elite B40 Coffee Maker
Need to descale it how
RINSE:
Dec 17, 2012 | Keurig Coffee Makers & Espresso Machines
Keurig Platinum B70 Coffee Maker Logo
1,511 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
