Question about Radio Shack Radio Communications
I have realistic TRC-431 Base set. It receives well but will not send. Even when I change microphones with one from a working unit it will not send any sound. All another radio receives is an electric hum. Any suggestions. I do not have a repair shop close buy. Hoping I could figure this out as the old radio is in nice shape otherwise.
    Sergeant:
  • 270 Answers
If you do get a hum, that would indicate that the transceiver is working. What is likely, is that the antenna is somehow not broadcasting.
Check out the connection on the coax, and the type of antenna your are using to broadcast.
Posted on Oct 12, 2010
Mic wiring diagram for a realistic Navaho TRC -490
Check out this website www.qsl.net/g4wpw/astaticbook.pdf. It should help you out. Also, your D-104 should have the amplifier in the base. You'll see a hole in the base with an adjustment beneath it. You will have to adjust your transmit level with this. Make sure that you have a battery installed!
Dec 13, 2017 | Astatic Radio Communications
I need a new channel changing Mike for a Realistic TRC 476. The cord for the Mike was cut and even though repairs were done the radio just scans through every channel very quickly and constantly.
You should check the new cable wiring connections. There is a resistor in that microphone that connects to the channel button circuit, it is (electrically) between switch 5 (up) and pin 3. If this not present then it may be causing your issue, IT is also possible that the diode for that circuit (located on the main board) got damaged when the cord was cut. diagram: http://www.cbtricks.com/radios/realistic/trc_476/476_print.htm
Oct 10, 2016 | Radio Communications
I have Realistic CB TRC-431 wont transmit
sounds like the mic or it's cord has failed, try replacing the mic and it will prbably be back in business for ya
Feb 06, 2014 | Radio Communications
Realistic TRC-458 Base CB Problem ??HELP??
This uses a uniden board and has a relay for transmitting, check and clean the relay contacts
May 03, 2013 | Radio Communications
WHERE CAN I GET A MANUAL FOR A REALISTIC NAVAHO TRC-433
Have you tried Radio Shack they handle realistic products you may find the manual on their website.
May 08, 2011 | Radio Communications
Radio will receive but not send
The transmit final transistor is no good. it blew out. needs to be replaced.
Mar 17, 2010 | Radio Communications
Ok, i have one CB that is a realistic TRC-474 and it powers up just fine and everything works except theres no noise at all coming out of the speaker! However, my buddy pulled up next to me and i could...
there a several things you can check yourself with a minimum of tools or test equipment. this model has been around for several years and voice coils do expire in the internal speakers as they age. attempt to locate a known good external speaker with a 3.5 mm plug and see if the receiver can be heard through it. if so then the internal speaker has seen better days and the solution/s should be obvious. also in this particular model the receiver output is controlled by the microphone switching and an open receive line in the mic cord/cable or the plug itself would render the receiver unhearable. check with another known good microphone wired for realistic radios (5 pin DIN). the microphone might also have been rewired improperly. make sure the squelch is in the fully counter-clockwise position and the volume is adjusted to a suitable level while testing, 12 o'clock or higher.
Jun 10, 2009 | Cobra 25 LTD 40-Channels Base CB Radio
We need a wiring Diaghram for a Realistic TRC 495 Echo Mic.
You can download it at CBtricks.com ....hope this helps....
Dec 08, 2007 | Radio Communications
Mic wiring diagram
Want to wire cobra mic to a uniden washington radio
Nov 20, 2007 | Radio Shack TRC-447 CB Radio
Radio Communications Logo
178 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
