Question about Wurlitzer Crosley WR18 Mini-Bubbler CD Player CD Player
Bubbbles work lights work remote does not tried new baateriris twice no luck juke box wr 18 mini bubbler if you open control door mode only stays on mode or play but no reaction manually or remotely..... does remotr supposed to light up in front where bulb is when puushing buttons. please help me. please reply if it is the remote how do, i get a new one. thankyou for your help medo you can email me or call me eather one" lesfisher2@aol.com.....6318078414
  • 734 Answers
Please take out all the batteries and let your unit sit overnight (also unpluggeed). When you wake up, still leaving all unplugged with no batteries, hold down the power button that starts it for 5 FULL MINUTES. Then, plug in using only main power. If it fires corectly, tuen it off and install batteries. Then restart. If this does not work, start a trek beginning with eBay and the great vendors there. Well...not all great...LOL!!!!! but find a great one.
You'll get fixed and nothing I've suggested will have harmed your property.
Blessed be
regards
selk
Posted on Oct 12, 2010
2013 Toyota Highlander. Key fob remote doesn't work after installing new battery. It is not a smart key remote.
PROCEDURE. Make SURE the battery you installed is good.
  • Driver's door open, key removed from ignition switch
  • Within 5 seconds: Insert and remove the key from the ignition switch twice
  • Within 40 seconds: Close and open driver's door twice
  • Insert and remove the key from the ignition switch. Close and open driver's door twice
  • Insert the key into the ignition switch and close the driver's door
  • Within 40 seconds: Switch ignition ON and OFF once to program a remote transmitter code whilst retaining the original codes or twice to program and remote transmitter code whilst erasing the original codes. Three times to check how many remote transmitter are currently registered or five times to erase all registered codes
  • Remove key from ignition switch. System should now lock and unlock vehicle once, twice or five times depending which mode has been selected. One to four times, slowly, to indicate number of remote transmitters registered
  • Within 40 seconds: Press and hold LOCK and UNLOCK buttons simultaneously for 1.5 seconds
  • Within 3 seconds: Press LOCK button
  • SYstem should now lock and unlock vehicle once to confirm registration, twice to indicate registration has failed
  • Within 40 seconds: Repeat button procedure to program remaining remote transmitters.
  • NOTE: To exit programming mode: Open driver's dorr
  • NOTE: A maximum of 4 remote transmitters can be programmed
If the above programming procedures do not work, then you should contact your locksmith.
Goood Luck!
Dec 13, 2017 | Toyota Highlander Cars & Trucks
Where to order a brand new remote for my Wurlitzer Jukebox wr-18
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability.
Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops.
Type in the brand name of your device, in the search box [at the top right] of the display window, and press enter to get all related posts. It will make surf easy.
Feb 11, 2015 | Wurlitzer Crosley WR18 Mini-Bubbler CD...
2001 maxima alarm not working but panic works
ck for a fuse in the under the hood fuse box that says bsm may be blown.
Also try this.....
To reset the security system remove the negative battery cable for 30 minutes, then reconnect the cable. Next, lock and unlock the doors using the remote. This will reset the alarm system and the engine will start and fobs reset.
Here are some factory notes....FYI
Anti-Theft Systems
PROGRAMMING
NOTE: If a new Smart Entrance Control Module (SECU) is installed, a new identity code must be entered and all remote controllers must be programmed. If identity code cannot be entered, repair multi-remote system. See appropriate MULTI-REMOTE CONTROL SYSTEMS article.
PROGRAMMING > PROGRAMING NEW ID CODE
NOTE: This procedure will erase all previous identity codes and render all previously programmed remote controllers inoperative (until reprogrammed). All remote controllers to be used with system must be programmed at the same time. A maximum of 4 remote controllers can be programmed. Any attempt to program more than 4 controllers will be ignored. If same identity code is entered more than once, entry is ignored even though hazard warning lights will still flash twice.
1. Close and lock all doors. Erase original identity code(s) by inserting and completely removing key from ignition switch more than 6 times within 10 seconds. Hazard warning lights should flash twice. Turn ignition switch to ACC position.
2. Push any button on new remote controller once. Hazard warning lights should flash twice, indicating identity code has been entered. If identity code cannot be entered, repair multi-remote system. See appropriate MULTI-REMOTE CONTROL SYSTEMS article.
3. For each additional remote controller to be programmed, manually release door lock and lock again by using door panel switch and repeat step 2. If no additional remote controllers are to be used, exit programming mode by unlocking and opening driver's door.
Please let me know if you need anything else to get the problem fixed. Happy mew Year!
Jan 03, 2018 | 2001 Nissan Maxima
I have lost the remote for my wr-18. Can I get a new one and how much will it cost?
Try calling Deer Park Dist. (618) 427-3761. They have been able to get me bubble tubes and other front plastics. I'm not sure if they have a remote available, but it's worth a try.
Oct 24, 2010 | Wurlitzer Crosley WR18 Mini-Bubbler CD...
Could some one tell me how to change the stations on my WURLITZER -MODEL WR 18-1015-CD AM/FM- 18" TALL-LIGHT UP i have tried to and i can not get it to work. It only has a remote. Thank you
Here is a link to obtain the owner/user manual for that wurlitzer if you would like it:
http://www.payphone.com/shop/instructions/Wurlitzerwr18.pdf
1. Turn power on using either the remote or power button located behind tuner door.
2. Push CD / RADIO BUTTON (25) to enable FM tuner.
3. Turn FM dial to desired station.
4. Position FM ANTENNA (16) for best reception.
5. Set volume to desired listening level.
Sep 17, 2010 | Wurlitzer Crosley WR18 Mini-Bubbler CD...
How do i program a remote control for a 1998 toyota vienta
1-insert and remove key from ignition two times
2-close and open driver door two times
3-insert and remove key once from ign.
4-close and open drvr door twice
5-insert key into ign.,then close driver door
6-turn key to on (not start) then off, twice this is rewrite mode,have all remotes to reprogram it will clear any lost remotes.
7-remove key from ignition,the door locks should cycle twice.if not start over.it may take a few tries.
8-press lock/unlock together and hold for a second
9-release,and press lock on remote,the door locks will cycle confirming program.continue to do other remotes you have,steps 8 and 9.if only one in possession,you are done. To end mode open door or insert key into ignition.
You'll need to follow the steps with no more than a 1-2 second delay between each step.. hope it works
Aug 04, 2009 | 1998 Toyota Camry
Remote works but doors don't lock/unlock
Check the remote battery or replace. Check all fuses. If you need to reprogram, try this.
key not in ignition.
driver door open-others closed
driver door unlocked
9-release,and press lock on remote,the door locks will cycle confirming program.continue to do other remotes you have,steps 8 and 9.if only one in possesion,you are done.
to end mode open door or insert key into ig.you can do up to 4 remotes.read this a couple of times to get the sequence down.there are time restraints,but if you go in order it will work.do not wait more than a second b/t each step and you will be ok.i know from experience that you can do this as fast as you can and it will enter mode.if steps out of order or you wait to long it wont.print this and have in lap,read ahead of what you are doing.good luck
Jun 13, 2009 | 2000 Toyota Land Cruiser
1997 camry remot key
Try this.
to end mode open door or insert key into ig.you can do up to 4 remotes.read this a couple of times to get the sequence down.there are time restraints,but if you go in order it will work.do not wait more than a second b/t each step and you will be ok.i know from experience that you can do this as fast as you can and it will enter mode.if steps out of order or you wait to long it wont.print this and have in lap,read ahead of what you are doing.good luck.
Jun 10, 2009 | 2001 Toyota Camry
Remote missing on old dominator garage door opener
This is the most complicated way I know of coding a remote and I am a tech. who does this all the time.
Turn power off. Wait 3 sec's & turn back on. Quickly press program button on back of box twice. Lights will flash, bottom light will stay on. Press program button twice, & No. 3 light will start flashing. Press and hold your remote button until light stops flashing. Code will be accepted.
Apr 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote control does not work with unit
The only way you can be sure is to test it on another machine or try another remote control unit. Not very helpful I know.
Oct 29, 2007 | Wurlitzer Crosley WR18 Mini-Bubbler CD...
Wurlitzer Crosley WR18 Mini-Bubbler CD Player CD Player Logo
103 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
John Robertson
John Robertson
Level 1 Expert
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
