Hello thanks the model # is FP5251 G105
Thats the model # FP5251 G105.. yes the tv you can here it turn on and the green led power light comes on but the screen is black/ also we can here sound but no pitcher just a black screen with great sound!!! thanks for helping me !!! your the best!!!!!
  • 8,617 Answers
Thats the PTV711 chassis phillips magnavox. I would suspect the vertical output IC needs to be resolderd. Its located on a aluminum heatsink and should have vertical stamped on the board near where the IC is located. Often when the vertical drops out it causes the CRTs not to light as a safety feature to protect the tubes. let me know if you need more assistance.
Posted on Jun 01, 2008
Hello. My Panasonic PT-50LC13 is not turn on. First flashing green light for one minute on the power button then starts to blink red and at the same time it starts blinking red LED lights every five...
Check ur tv fan,if ur cooling fan are runnig,before all these LED lights are flashing.If not that ur tv problems.All these LED lights are flashing the tv making alots of clinking noises too like it trying turn itself on?Yes,than the tv board that called the Ballast board it is dead too,must be replace also.This tv Ballast board only job are to help to ignite the tv projection lamp only and keeping it on and running.
Aug 29, 2011 | Panasonic PT-50LC13 50" Rear Projection...
We were just watching tv and it just shut off. Now it won't turn back on. I already unplugged it and still nothing except for the green light will come on for a second then turn right back off. You can...
Now tv on,power LED light indication flashes?Yes.The power supply board is the problems and the causes.That the board,where the power a/c cord plug into it.Try website like Ebay.com to buy a refurbish power supply board for the replacement.
Mar 24, 2011 | Televison & Video
Hi, i have here a mitsubishi WD-57733. once the unit is switch ON, green LED light and a few seconds the status LED light then shuts off. I think light engines good since i just replaced a new lamp.
hello i've just checked the manual for here is some information
None TV is powered off. Normal operation.
Green TV is powered on. Normal operation.
Green 1. TV just plugged into AC outlet.
Wait until blinking stops before turning on (approximately 1
minute). Normal operation.
2. AC just restored after power failure.
3. TV Rebooting after System Reset was
used.
4. TV Rebooting after power fluctuation
or receiving abnormal digital signals
from digital channel, or digital device.
5. You have begun the procedure to
update software from an authorized
flash memory device.
For detailed information, see the instructions that accompany
the authorized software update. IMPORTANT: Do not
use unauthorized software at any time.
Green TV just powered off and lamp is
cooling.
Starts to blink 30 seconds after turning off TV. TV can be turned
on before blinking starts or after blinking stops, but not while the
indicator is blinking. Normal operation. hope it helps regards shaun
Green TV powered off and auto-on timer is set. Normal operation. TV can be turned on at any time.
Dec 06, 2010 | Mitsubishi Televison & Video
Problem for Sony Grand WEGA KDF-55WF655. Hello,
5 times Red LED blinks means Lamp Driver Error. (KDF-55WF655)
2 possible reasons, either Lamp is gone or Ballast Supply got bad.
Replace lamp first, in most cases it solved the problem.
How old is this TV and did you replaced lamp recently?
Thanks.
Oct 21, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Tv won't turn on
yes but you have to open the tv
Mar 01, 2009 | Loewe Aconda ACO9303 30" TV
Hitachi 50SBX78B
Good Day, dpmc;
There are many items in the TV that can cause this concern. CAN you repair it if I guided you through this??? I will..... If not call an authorized service center and get an estimate of the cost of repair.
Come back on this sight and I will help you further in detail.
Good Luck, big IRISH.
Aug 09, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
No picture, no sound.
Hi i have a pilips 42" plasma tv (42PF5320/79) i can hear clicking the green light is on and the tv will go into stand by if i press the power button and the red light also comes on .I have turned it on and off and it works now nothing just the light on the front as if its working looking at the back through the slots two green lights come on then the tv clicks and they turn off,thanks
Aug 06, 2008 | Philips 42PF9630A 42 in. Plasma Television
Hello its me again!!!! model# is FP5251 G105
from the back is the best way to get to it.
Jun 01, 2008 | Philips Magnavox 27MS343S 27" TV
Hello again!!!! model# is FP5251 G105
There should be three circuit boards on that model a small board on the right then a larger board in the middle and another large board on the left the vertical IC will be located on the middle board it will be attached to a aluminum heat sink.
Jun 01, 2008 | Philips Magnavox 51MP392H Rear Projection...
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
