Question about Refrigerators
We began to notice that our Freezer temp as well as Refridgerator Temp have been fluxing...we would have a few good days then we see ice frrom the ice maker dripping and then freezing in the freezer or we see the temp at 12F and refridge at 45F....then it would go back to 0F and 37F in a few hours then in a few days it would happen again, Our Repair guy said he couldn't find the problem when it was working fine so he said to call him when it was not working right. I have cleaned the coils in the back and removed all of the dust build up everywhere possiable to get a vaccum into with compressed air. Where to we begin to start troubleshooting....?
  • 4,066 Answers
DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can't flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won't turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it's bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it's in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Posted on Oct 12, 2010
Whirlpool conquest side by side. Ice began melting and red light for filter replacement was on. I changed the filter but it didn't seem to fix the issue. Few days later everything began working fine but...
Turn the temp control to max, does the compressor come on? If yes feel the discharge line at the back of the compressor, is it nice and cold? If yes you can eliminate the simple items, make sure all the fans are working inside the fridge and at the rear of the unit. Check to make sure the defrost drain/trap are clear. Let it run for a while, then drop the temp to the usual setting it, and see what happens.
Feb 26, 2015 | Whirlpool Refrigerators
Water dripping inside KTLA22EMSS01
Your freezer actually cools your fridge. It sounds like you have ice build up in your freezer behind the back panel. You should be able to unscrew the back wall inside your freezer. A hair dryer should help defrost or keep it open for a few and use a screwdriver to remove the build up of ice. The ice has made its way down the vent and when it hits the fridge it is above 32 degrees so it is melting. Hope this helps. I manage rental properties and have had it happen on a few occasions.
Aug 16, 2012 | KitchenAid Refrigerators
Jenairrefridgerator model jcd2292ktb, what is the temperature for freezer and refridgerator
If you want to set the temperature your Fridge/Freezer should maintain, you need to set the Freezer to between -19c and -23c, however if you will be keeping Ice-cream in this freezer then it's best to set the base temp @ -21c minimum, -23 preferable, or the ice cream may begin to break down (very slowly I might add). The Fridge needs to be set to a maximum Highest temp) of 5c, any higher and the food will not stay as fresh and bugs will be able to breed, preferable temp is approximately 3-4c.
Jun 20, 2012 | Refrigerators
I noticed in the mornings that the temp on my freezer and frig will increase a few degrees then go back down. Then occasionally here and there during the day it will go up a little again. Sometimes the...
if it is a frost free the temp will vary room temp and the warm food you put in will affect it or the electronic controler is not operating properly frost free also defrosts its self in a 24 hr time frame this will affect the flux temp
Nov 07, 2011 | Refrigerators
We have a refridgerator, about 2-3 years old, Model #ED5JHEXTB00. Side by side freezer, refridgerator that is not cooling as much as it should in the refer part. I'm not sure of the temp, but milk goes...
if your noticing frost on the back wall you have a defrost problem and need to address it immediatley before u get warm in freezer and refrigerator sides remeber that a refrigerator is just a cold air duct from the freezer.... defrost heater bimetal defrost thermostat ot timer defrost control is bad ...
Feb 01, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
My Jenn-air refridgerator model JCD2389GEW is not cooling
turn freezer to higher temp and turn fresh to lower temp this maximizes airflow into the refrigerator. check the door that regulates airflow into fresh side..see if its stuck closed for some reason. good luck! :)
Jun 11, 2009 | Refrigerators
Both freezer and refrigerator temp variations
in most refridgerator cabins is a air dam at top right of side by side and it could be sticking open and working other times or it could get stuck in defrost cycle due to defrost timer not working properly.defrost timer would be first thing to look to.
Apr 20, 2009 | Refrigerators
Bottom freezer not keeping ice cream frozen
Check out freezer temp - should be around zero degrees. Fact that ice maker is still working would indicate that the temps are at least about 10 degrees. If the door seals are tight and the self defrosting mechanism is working properly, the unit may be low on refrigerant. I had similar situation where stuff was frozen but my ice cream was mushy even though unit was running 24 hours a day.
Apr 18, 2017 | Amana BX21V
Temp Fluctuations
i wouldnt worry mucha bout the fluxuations in temp, chances are simply a momentary reading perhaps just after a defrost cycle, sometimes new electronics can be a little too sensitive, I would only worry if you actually experience a noticable deiifeence in temp(ie.. your milk doesnt last as long, ice cream not hard as once was,, dairy usually best indicator in temp flux's))) dont worry so much abou the number, unlkess they are consistantly rising without correction
Aug 05, 2008 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Refrigerators Logo
35 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
