Question about Acer Aspire 3680 Laptop
Cant get the computer to do anything without the bios password
  • 2,296 Answers
To reset the BIOS password read the information from this link.
In case of your Acer Aspire laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
Posted on Jan 05, 2011
What is BIOS password?
No way to know YOUR bios password.
If you've neverassigned a BIOS password, press enter without inputting anything.
If you have a BIOS passwoed, you can reset BIOS rmoving CMOS battery
laptop cmos battery
Tutorial How to replace the CMOS battery in your laptop
How to Clear Your Computers CMOS to Reset BIOS Settings
How to clear an unknown BIOS or CMOS password
Apr 01, 2015 | Computers & Internet
Tip
Toshiba Laptop BIOS Password Removal
<span><b>ESC Key BIOS Password removing procedure</b><br />1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the Esc key. The computer will display the "Password = " prompt.<br />2. Enter the correct password, and press the Enter key. The computer will display "Valid password entered, system is now starting up. Check system. Then press (F1) key"<br />3. Press the F1 key. The BIOS setup program will appear.<br />4. Using the arrow keys or the tab key, move to the password field, and highlight REGISTERED.<br />5. Press the spacebar, enter the correct password, and press the Enter key. The Password field will change to NOT REGISTERED.<br /><b><br />F2 Key BIOS Password removing procedure</b><br />1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the F2 key. The unit will display the "Password = " prompt.<br />2. Enter the correct password, press the Enter key. (You may need to press the F2 key after you hit the enter key.)<br />3. The BIOS setup program will appear.<br />4. Using the arrow keys, move to the Security tab, and to Set User Password.<br />5. Press the F5 or the F6 key to navigate to the Password section. Enter the current password at the Old Password prompt, and press Enter. At the New Password prompt, press Enter (without typing anything into the password field). At the Confirm Password prompt, press Enter again (without typing anything into the password field). The password should now be removed.<br />6. Press F10 to save and exit from the BIOS Setup program.<br /><br />In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.<br /><br />If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.</span>
on Jun 09, 2011 | Computers & Internet
Bios password
First would try to reset BIOS by removing CMOS batter. If removing CMOS battery did not help, you need to do the BIOS reset from jumper on motherboard.
Apr 06, 2014 | Dell Latitude D505 Notebook
I cant remember my login password and f8 does not work in safe mode still asking the password
Once you assign a password to your HP computer's BIOS configuration utility, you will need to enter that password every time you attempt to access the BIOS.
If you forget this password, don't fret there is still a way to unlock your BIOS without actually knowing the original user defined password.
This involves using a "backdoor" password, which is something that is installed onto your BIOS at the factory level that never changes.
Turn on your HP computer.
Press "F2" to load your HP BIOS access screen.
A password prompt will load on your monitor.
Type "merlin" into the password field (with no quotes) and hit your "Enter" keyboard key to unlock your HP BIOS password.
Sep 20, 2013 | HEWLETT-PACKARD Computers & Internet
I have a everex stepnote nc1501 laptop when i turn it on it askes for a password i cant even go to settings or anything how do i reset the computer or find the password
is it bios or windows password? If it is bios's password then you should reset the bios by removing the bios battery. If it is your os then reinstall your os
Nov 05, 2011 | Everex StepNote NC1500 Notebook
Hello,sorry my english is not good, i have a problem with my thinkcentre M52 . when i start the comp it writes enter system password.i press enter and it goes into the Bios,but i cant change anything into...
Someone has put a password on the BIOS - you must input it before entering the BIOS and the normal boot procedure. Because of the way IBM are build you can't reset the password by removing the battery, but only by performing a low level BIOS upgrade - which only a dealer can do. You will have to take it to one.
If you aren't the one that put that password and noone had access to it then the motherboard is dying - replace it before it's too late and all your data is lost.
Jan 30, 2011 | IBM ThinkCentre M52 8113 - P4 551 3.4 GHz...
Hi!bios problem.ask for password.when type i cant du nothing anyway.shortly cant boot from usb or external dvd row.whay?
When you type a bios password, you won't see anything because this is a security measure; people looking over your shoulder wont know how many digits your password is. There is a way to bypass it, though. Disconnect the battery, unplug it, then open it up. There should be a small round battery called the CMOS battery somewhere in there. Pull that out. Then plug your computer in and boot it up without the CMOS battery. It should say password disabled. Turn it off, disconnect it, put it back together, and you're good to go.
Jan 18, 2011 | Fujitsu Siemens LIFEBOOK Q2010 PC Notebook
Dell inspiron 630m bios password problem
usually the bios password is 0000 by default
Mar 13, 2010 | Dell Computers & Internet
I cant open my computer my password does not accepted
Open Computer and take out oversized watch battery. Count to ten and put it back in. Close computer - Don't touch anything else!! Start computer. Should let you reset from there.
Oct 01, 2009 | Computers & Internet
Cant log in forgot password
Boot from install cd. select reset password from utilites
Nov 17, 2007 | Apple MacBook PC Notebook
Acer Aspire 3680 Laptop Logo
65 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
