Question about Dell OptiPlex 360 Desktop Computer
The electricity went off and when it came again the my dell optiplex 360 failed to startup. Since that time when I press the power button it turns yellow and failed to startup.
    Problem Solver:
  • 4 Answers
Unplug the power cord for about 30 minutes, plug back in (obviously :-) then try it again. No guarantees but this fix has worked for a few of my clients.
Posted on Oct 12, 2010
Dell optiplex 360 power button is damaged, how can i start my desktop without this button?
I suppose there's a way to do that but I don't advise doing it. You're bypassing built-in power protections inside the computer. How is the power button damaged?
Sep 18, 2014 | Dell OptiPlex 360 Desktop Computer
Cpu fan failure dell optiplex 360
Make sure the fan cables are plugged in on the motherboard. Or the cpu fan may have went bad and needs to be replaced.
Jun 24, 2014 | Dell Systems Dell OptiPlex 360 Minitower...
Dell optiplex mini tower, when turn on the computer amber led lights blink with a , and will not startup
If the power light is blinking amber - The computer is receiving electrical power, but an internal power problem might exist.
Apr 25, 2014 | Dell OptiPlex GX520 PC Desktop
Dell optiplex 360 power button orange light
is the orange light flashing? if it is, that would indicate a problem with your power supply or wall outlet to your computer.
Jan 21, 2014 | Dell Systems Dell OptiPlex 360 Minitower...
Power or motherbaord failure
open it ...remove the bios battery and after that put it back ..this will reset it ...and will boot ...just set the time and date and press f10 to exit and save ...
if it still fail to boot after that it has another issue ..probably a cpu fan or a ram memory
Jan 18, 2010 | Dell OptiPlex GX280 PC Desktop
My Dell optiplex 170L keeps turining off and then
Possible that it's caused by a faulty hardware or a computer virus on your computer. For us to isolate the issue we must start troubleshooting with the hardware
1. Remove all the connection at the back of your computer
2. Power cycle your computer tower by pressing the power button for 15 seconds
3. Plug the power cord back in and monitor cable at the back of your computer tower (if it turned on, meaning that one of the device plugged at the back of your computer is the one's causing the problem, for you to pin point the problem, try plugging it one-by-one and turn on the computer each time you plug a device)
4. If it keeps on doing that, open up your computer tower (be careful to unplug the power cord and power cycle it to avoid static electricity)
5. Reseat the video card, turn on the computer again, if it's still occurring
6. Reseat the IDE/Sata cable of your hard drive and try to make sure it's properly plugged in, turn on the computer again, if it's still occurring
7. Reseat the memory, turn on the computer and test it again if the same thing
8. If you have 2 memory chip inserted in your computer tower memory slot, remove the other one and turn on the computer, do the same thing to other memory and each slot
9. If all else fails, restart the computer and keep on pressing F8 before the window welcome screen comes up - to go to advanced boot options
10. Boot to Safemode
11. If you are able to boot to Safemode
12. Login as administrator
13. Click start
14. run
15. type msconfig then press enter
16. click on startup tab and click on disable all button at the bottom part
17. Restart the computer and let it start normally
18. if the same thing happen, boot to safemode again
19. Login to administrator again
20. Right click my computer
21. Click on properties
22. Click on Advanced Tab
23. Click on settings button under Startup and Failure
24. Uncheck the Automatically restart under System failure
25. Restart the computer in normal mode
26. Tell us if you see any blue screen error, if so, post the error here
if all else fail, your operating system needed to be reinstalled and you should have the cd for the operating system if it's XP or Vista or Windows 7.
Jan 08, 2010 | Dell OptiPlex 170L PC Desktop
Dell Optiplex GX260 Tower flashing yellow power button
Hi
Power up the Optiplex GX260 and check the QUAD Pack Diagnostics LEDs (located at the back). Compare the LED pattern to http://support.dell.com/support/edocs/systems/opgx260/en/ug/solvprob.htm#1167139 for more info.
Ideally, to troubleshoot and resolve the issues, try removing all PCI devices, disconnect all external devices/peripherals including keyboard and mouse. You may leave the Monitor connected. Power up the PC and check for successful Power On Self Test (POST). If POST completes (generally fails on "Keyboard not present"), shutdown, connect keyboard and try POST again.
If all goes well, install PCI devices one at a time and test successful POST. This will help identity a failing device.
If issue persists, after removing all devices, remove the CMOS battery for about 90 seconds and try POST again. If same, remove all DIMMs (Memory) and check for beep codes. Compare beep pattern to http://support.dell.com/support/edocs/systems/opgx260/en/ug/solvprob.htm#1176760.
NB: Ensure to remove power lead and press power button briefly to use up flea power before working in the system.
If the system beeps, it suggests that the CPU and systemboard are "likely" fine. Install one DIMM at a time and test successful POST. If there no beeps then the systemboard and/or CU is/are at fault.
Regards
Mike
Mar 27, 2008 | Dell OptiPlex GX260 PC Desktop
Don't power on
I suspect Motherboard Failed. Contact a qualified service person to assess it.
Regards
Rafique
Feb 18, 2008 | Dell OptiPlex GX260 PC Desktop
Dell OptiPlex 360 Desktop Computer   Logo
94 people viewed this question
Alun Cox
