Question about Dometic RM2652 Refrigerator
I think my cooling unit is shot, but about the same time of my fridge going out I had what seemed like a water leak. It was in a closet no where near any water lines,but on the same side of the closet opposite (next to)the fridge.Could the fridge have lost any liquids that got that side of the closet wall saturated?The paneling in the closet is loose like it has been submerged under water and the carpet is soaked.I have a dehumidifier in it now to get all of the moisture removed before it mildews. There is a yellow/green substance at the base of the burner that makes me feel like theres a leak.
  • 24 Answers
These RV fridges are filled with ammonia, sounds like your unit has a leak, You should remove your fridge and possibly get it repaired , refilled and tested, or find a used one, These units are a few $$$$.
Posted on Oct 16, 2010
Why is water leaking into cool (deli) drawer?
Hi,have you got a drain at the back of the fridge just above the veg draw,if yes is there eney food above that that is tuching the back wall of the fridge above the veg tray,if so then the water that runs down the back wall will be going onto the food that it tuches and into the veg draw,hope this was some help,all the best.
Sep 16, 2015 | Refrigerators
CAN I PUT THE EXHAUST TUBE INTO STORAGE CLOSET INSTEAD OF PUTTING IT IN A DOOR GOING TO THE OUTSIDE?
I think you are asking about a portable air conditioner, not a de-humidifier. With that assumed, the answer is, NO - that is not a good idea. The exhaust tube is for getting rid of the heat that you have pulled from the room you are cooling, plus the extra heat that the device itself creates. This is a considerable amount of heat, which will quickly heat up the closet and leak back into the room you are trying to cool. If the closet it tightly sealed, the unit will not be able to push the air through the tube, and the unit itself will overheat. The result will be that you will be buying electricity to actually RAISE the temperature of the room you are trying to cool.
Jun 05, 2012 | Danby Premiere 12,000 Btu Portable Air...
My Amana french door/bottom freezer is leaking water. Did the procedure with hot water the drain in back of the freezer, although it seemed clear of ice. That didn't help. The leaking stops when I...
Two possibilities:
1. A cracked plastic tube. These will leak whenever there's a call for water - either the chilled water dispenser, or re-filling the icemaker tray (two seperate tubes). Pay particular attention to anywhere the tubes are clamped to the chassis; anywhere they're routed near or under the refrigeration unit; and near the solenoid valve - especially if there's a tight loop in the tube there.
2. A bad (leaking) connection where one of the tubes exits the water valve. Again, these will leak whenever the valve is activated.
Those plastic tubes don't last forever. I've replaced many of them for the same symptoms. They're known to simply deteriorate with age.
Manuf's make good money selling replacement tubing kits.
Aug 15, 2011 | Amana AFB2534DE Bottom Freezer French Door...
I see water collected under my fridge. We have had couple of incidents of milk going bad. I don?t feel enough chillness when I open the door and stand near it. The fridge seems to be running, we have...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 23, 2010 | GE GSS25SGMBS Side by Side Refrigerator
Leaking water on floor
find where line comes out under fridge in pan and blow back through line with shop air. clean evap pan inside freezer by defrosting and cleaning pan.
Sep 23, 2009 | Refrigerators
My amana side by side fridge quits cooling for periods of up to 4hrs, at the same time the water dispenser doesnt work.. then after 4-5hrs the fridge starts back up.. runs for probably 16hrs and quits...
The water dispenser and the compressor are separate circuits, check if the fridge has power or has no power at all during the time it is idle, test on a different power outlet.
Oct 28, 2008 | Amana Refrigerators
Frigidaire 7.5 cu.ft. Top Freezer the fridge part doesn't cool; freezer is fine.
It should be under warranty, retry he is probably right, run for 24hrs and it should work ok, if you ever defrost you should turn off for 24hrs and leave the door open. Regards Advisor
Aug 08, 2007 | Frigidaire GLRT83TES Top Freezer...
Dometic RM2652 Refrigerator Logo
112 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
