Question about Acer Computers & Internet
While typing caps lock may apear and then some times key board goes completely dead have lifted it out and repluged ribon in and out of conectorand works but when i assemble it back it just fails again very eratic
    Scholar:
  • 47 Answers
My first inclination would be to tell you to replace your keyboard. A possible test could be hooking up an external keyboard and see if the problem migrates to that as well (this isn't always the case when using an USB keyboard as that doesn't use the same I/O addresses, so dependent on the age of your laptop there could be an original PS2 connection or not).
If this worked, then its you incorporated keyboard needing replacement.
Another test would to boot your system into "Safe Mode" and see if the problem persists as well. Thgis is done by rebooting your computer and hitting F8 (several times in my experience, as I can't always anticipate the proper moment for the computer to actually go into safe mode), . Once you have gotten into a DOS like screen choose the option that states "Safe Mode with Networking". The reason being, if your keyboard operates with no problems in SM, then there could be a virus/malware attack causing your woes.
Seeing as your in SM anyway, you can then go online and Google for one of the many Free Online Virus scans that are offered. I favor Bitdefender myself, but other will debate its effectiveness ad nauseum.
If this clears it up then you can feel good about the fact that you didn't have to spill the bucks for software, repair parts or the dreaded technician...
Hope this helped...
Posted on Oct 12, 2010
Ipod heat issue
It is not a heat issue, you have shorted the board out.
You need to have the iPod repaired. If you know about circuits, you could test each one on the board, but you need to know the resistance of each one. I suggest you send it to apple repair.
Nov 25, 2013 | Cell Phones
How do I get the caps lock light to turn on and off?
Unlock the Caps on Computers The All-Caps or "Caps Lock" function causes all letters to appear as capital letters when typing into word processing documents, emails or other files. This is convenient when needing to type numerous capital letters or All-Caps phrases, as you do not have to hold down the "Shift" button with one finger as you type the words. When All-Caps is stuck and does not respond to the "Caps Lock" keyboard button, a simple procedure overrides and shuts down the function. Open a word processing program. Press the "Caps Lock" button located on the left side of the keyboard to turn Caps Lock off. Type inside the document. If lower case letters appear in the document, Caps are successfully unlocked. Proceed if the text is in All-Caps. Hold down "Shift" on the keyboard. Press the letter "P." A lower case "p" appears in the document. Release the "Shift" button. Type the phrase "rint" directly after the lower case "P." The word "pRINT" is now in the document, and the document cursor is after the phrase's "T." Press "Enter" on the keyboard. The cursor goes down one line and "pRINT" becomes "Print." The "Caps Lock" function is turned off. Restart the computer to save the setting.
Enable the Caps Lock Key The "Caps Lock" key is loved by some and disliked by others. The key turns all letters into capitals as you type. While this feature is useful in some situations, a more common occurrence is that the key is accidentally hit and all the text typed is capitalized. The person typing must then delete the capitalized type and rehit the key to turn off "Caps Lock." If the "Caps Lock" key needs to be enabled, it indicates that someone has disabled or remapped the key. If a user wanted to, the "Caps Lock" key can be disabled and enabled through the registry or remapped through the control panels. Updating the registry for the keyboard will enable the "Caps Lock" key. Open the Notepad program. Type the following: [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout] "Scancode Map"=- Select "Save As" from the "File" drop down menu. Navigate to the computer desktop as the save file location and choose "All Files" from the "Save as type:" drop-down menu at the bottom of the Save As window. Type "enable.reg" without quotes in the "File name:" field and click "Save." Minimize all open windows to view the desktop. Double-click on the "enable.reg" file. A box will pop up asking if you are sure you want to run the file. Select "Run" or "Yes" and then click "Yes" for the Registry Editor warning. Reboot the computer. The registry will be updated and the "Caps Lock" key will be enabled. b> Manually Update the Registry b> Click the "Start" menu, type "regedit" without the quotes and press "Enter." In older versions of Windows, Click the "Start" menu, select "Run," type "regedit" without the quotes and press "Enter." This will launch the Registry Editor. Navigate to "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout" to view the settings. Right click on the "Scancode Map" setting and choose "Delete." Click "Yes" to confirm the deletion. Reboot the computer. The registry will be updated and the "Caps Lock" key will be enabled.
b> b> b> Disable the Caps Lock Key in Windows Your computer's Caps Lock key has likely only collected dust since you first brought the machine home. The Caps Lock key is beneficial if you want to type a long string of words entirely in capital letters, but this form of typing is not needed often. Consider disabling your Caps Lock key if you do not need it, or if you are tired of hitting the key accidentally while rapidly typing.
Restart your computer before beginning the process of disabling your Caps Lock key. Download the registry file necessary to disable your Caps Lock key. You have the option to disable your Caps Lock key or change the key to a number of different keystrokes. For example, you may choose to use the "ChangeCapsToShift" registry file if you want the Caps Lock button to function as a shift key. Double-click the registry file you have downloaded. A prompt will appear on your screen asking if you would like to add the registry file to your computer's registry. Select "Yes" to install the registry file. Restart your computer, once again, to complete the registry change. Upon reboot, your Caps Lock key will no longer function as a traditional Caps Lock key.
Disable the Caps Lock Key on a Computer The Caps Lock is an easy key to hit by accident, and often the user does not realize it immediately. When this mistake occurs, usually you must correct some text errors and your time is wasted. If you think the Caps Lock key is more of an aggravation than it is good, follow these steps to disable your Caps Lock key. Click on "Start" and select "Run". Type "regedit" into the textbox and hit "OK". This command will open the "Registry Editor" window. Select "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control". Double click on "Keyboard Layout" to open the folder. Open the "Edit" menu and choose "New" then "Binary Value". A new file will appear on the right side of your screen with the file name highlighted. Type "Scancode Map" for the new file name. Double click to open and type in "00000000 00000000 0200000000 003A00 00000000" into the Value data box. Hit the "OK" button. Close the "Registry Editor" by selecting "Exit" from the "File" menu. Restart your computer for the change to go into effect and enjoy life without the Caps Lock Key.
Feb 04, 2013 | ASUS R503u-rh21
CAP LIGHT DOES NOT COME ON
Disable the Caps Lock Key on a Computer The Caps Lock is an easy key to hit by accident, and often the user does not realize it immediately. When this mistake occurs, usually you must correct some text errors and your time is wasted. If you think the Caps Lock key is more of an aggravation than it is good, follow these steps to disable your Caps Lock key. Click on "Start" and select "Run". Type "regedit" into the textbox and hit "OK". This command will open the "Registry Editor" window. Select "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control". Double click on "Keyboard Layout" to open the folder. Open the "Edit" menu and choose "New" then "Binary Value". A new file will appear on the right side of your screen with the file name highlighted. Type "Scancode Map" for the new file name. Double click to open and type in "00000000 00000000 0200000000 003A00 00000000" into the Value data box. Hit the "OK" button. Close the "Registry Editor" by selecting "Exit" from the "File" menu. Restart your computer for the change to go into effect and enjoy life without the Caps Lock Key. Hope this helps
Jan 21, 2013 | Acer Computers & Internet
How to tell if caps lock is on
Some keyboards will have a light that goes on when caps lock is turned on
Type the following:
"Scancode Map"=-
Hope this helps
Nov 05, 2012 | Computers & Internet
When I turn on the wheel riter 3500 it beeps 6 times, the ribon cycles but it won't go to left and reset and type. Seems like a board problem
There are a lot of possibilities. Look for debris on or under the boards, unplug and replug the keyboard, If all fails, take out a battery and turnoff the machine, wiat 30 sec and turn back on.
NOTE THIS WILL CLEAR THE MEMORY AND RESET ALL FUNCTIONS TO DEFAULT!!!
DickyO
Jan 22, 2011 | IBM 3500 Typewriter
Power button blinking and no screen...just black. What to do?
I just did this to a friends monitor as well, a different model and not much different in build. I think you might have 3 screws on lower back side of cover. Start your separation from the bottom of the frame.Your power switch will remain on the front frame while the wire will remain with the rest.
HOW TO OPEN A SYNCMASTER2.gif 2053BW
NO SCREWS!!! Assuming that the stand mount has been pulled out..The seam around the screen frame is where you start. The frame has the prongs, the back cover has what the prongs slip over.The frame is coming off first! I got the side to open by finger, then used a small standard screwdriver to pry ever so gently(lifting frame from rearcover). Leave the power button assembly on the frame, pull wire only a little to relax any tension..you get about 3/4" in extra taped to panel. The hard part is done.;) Still holding the frame...Now lift the panel (where the power button assembly wiring goes under panel) with the power housing that is under it as a whole and you will see where the powerbuttonassemble detaches.Remove frame. Now..holding edges of panel into back cover, lift and flip the whole thing over and place panel face down on a perfectly flat surface..a towel on my desk works. Lift and remove back cover.Your now looking at the back of the board housing. The ribon is simple, on the panel end of the ribon, squeez the outer clips together and slide it away against the panel..The secondary tin plate is removable(if you need to remove it), two clips super close to where the sets of wires come around the housing and into the panel. Unhook the 4 plugs(blues and pinks)...Now lift the power housing off of the panel. The big board has the power. One screw to remove a ground plate first. Two screws to remove power board. Pics from phone.56ec44b.jpg
aae8fab.jpg The capacitors top-plain should be flat(not rounded) and there should be no color whatsoever coming through the top of the cap lines(google "bad capacitors"). The specs of the cap are on the cap. The 2 caps cost me $4.00. Now keep in mind there are hazards to this.Google them;)
Nov 17, 2009 | Samsung SyncMaster 204BW LCD Monitor
Screen not coming on
Typical problems with Samsung SyncMaster.
I just did this to a friends monitor as well, a different model and not much different in build. I think you might have 3 screws on lower back side of cover. Start your separation from the bottom of the frame.Your power switch will remain on the front frame while the wire will remain with the rest. Read the rest it will help.
NO SCREWS!!! Assuming that the stand mount has been pulled out..The seam around the screen frame is where you start(different versions might have screws). The frame has the prongs, the back cover has what the prongs slip over.The frame is coming off first! I got the side to open by finger, then used a small standard screwdriver to pry ever so gently(lifting frame from rearcover). Leave the power button assembly on the frame, pull wire only a little to relax any tension..you get about 3/4" in extra taped to panel. The hard part is done.;) Still holding the frame...Now lift the panel (where the power button assembly wiring goes under panel) with the power housing that is under it as a whole and you will see where the powerbuttonassemble detaches.Remove frame. Now..holding edges of panel into back cover, lift and flip the whole thing over and place panel face down on a perfectly flat surface..a towel on my desk works. Lift and remove back cover.Your now looking at the back of the board housing. The ribon is simple, on the panel end of the ribon, squeez the outer clips together and slide it away against the panel..The secondary tin plate is removable(if you need to remove it), two clips super close to where the sets of wires come around the housing and into the panel. Unhook the 4 plugs(blues and pinks)...Now lift the power housing off of the panel. The big board has the power. One screw to remove a ground plate first. Two screws to remove power board. Pics from phone.56ec44b.jpg
Nov 10, 2009 | Samsung SyncMaster 743B 17 inch LCD...
Toshiba tecra s2 keyboard starts skipping typed characters and stalling
there may be a pressed key in your key board, but pls chcek the key board with keyboard tester free software to identify pressed keys.
pls remove the key board cap carefully and clean
Apr 29, 2017 | Toshiba Tecra S2 Notebook
CAPS LOCK PROBLEM!!! URGENT HELP NEEDED!!!!
On some keyboards, there's a hidden 'feature' where if you hit CAPS LOCK and Shift at the same time, everything works backwards, until you hit that combo again.
Try this and let me know if it pertains to you...
Dec 29, 2007 | Computers & Internet
My typing goes uppercase without hitting the caps lock
I have the HP Pavilion and cap locks does the same thing.
THIS WORKS EVERY TIME. Hit both the right and left shift lock simultaneously about 5 to 10 times. It immediately disengages the cap locks. It is a little bit of a hassle, but I'm just used to it. It may happen 3 times per week, but I LOVE the machine, so I just fix it this way!
Oct 20, 2007 | HP Pavilion dv8000z Notebook
Computers & Internet Logo
21 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
