Question about ATI RADEON HD 2400 PRO Graphic Card
I have a giga byte mobo ga-7va rev. 1.0 and want to upgrade my graphics card, the problem is, it needs to run at 1.5volts, nowhere can i find graphic card voltage specs.
  • funsun98 Oct 12, 2010
    i have a nvidia geforce2 mx / mx 400, could i go to geforce4?
  • 13,433 Answers
Let me take a look at that mainboard....
1 x AGP slot (8x/4x, AGP 3.0 compliant), supports 1.5v display card only.
Okay this information is misleading. AGP 2.0 uses 1.5V, AGP 3 cards function at 0.8v.
Your slot supports AGP3.0 so this is comfusing I understand.
But this is irrelevant and any AGP X4/X8 card will work on this machine as long as it mentions support for X4 and X8 socket.
Like this one, the best AGP card available today I think. - best I could find in the AGP section.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161337&cm_re=AGP-_-14-161-337-_-Product
As long as it reads
InterfaceAGP 4X/8XIt will work, if it reads 8x only, I would first ask if it is possible to send the card back incase it does not work with your mainboard.
But I'm guessing that all AGP card will work on this as your board has the latest AGP, and AGP is discontinued. It won't get any better from what it is.
Posted on Oct 12, 2010
  • Ekse Oct 12, 2010
    pretty old card, yes it will work perfectly fine.
Do GeForce GTX 550 Ti fit with igabyte GA-MA74GM-S2 (rev. 4.4, motherboard, micro ATX, AMD 740G) specs mobo
This GeForec graphics card connects to a PCI-Eexpress 2.0 x16
and this Gigabyte has a PCI-Express 16 expansion slot which is compatible with the GeForce graphics card.
You may need to disable the on-board graphics card in the BIOS.
Mar 10, 2012 | Gigabyte Computers & Internet
I have a GA-7VA (rev.1) board with Athlon XP 2600+, 1.7 GB RAM and 350wat power. I need to upgrade my video card. Game requires Minimum -NVIDIA GeForce 5700 / ATI Radeon x800 and above. Will...
Those are video chips, not cards. You need something like
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=555389&CatId=318
Jun 17, 2011 | Computers & Internet
Pcwith FSB800 DDR400 motherboard is not boothing and is giving 3 long beeps. Can you help please? Thanks
Hi this problem can be caused by either faulty hardware or bios.
1., reset the bios => unplug the comp, open it, look for a small battery on the motherboard and remove it, wait for 30 secs and put it all back together
2., diagnose hardware problem: remove first the ram modules and see if it can be turned on, repeat this with every part (hdd, ram modules separately, sound card, graphics card and finally if needed the cpu => only if everything else fails, you'll need thermal paste to put it back on). If the completely stripped mobo cannot be started then it is probably faulty.
Finally when you successfully located the faulty part replace it.
Mar 04, 2011 | Gigabyte Giga-Byte: GA-8S661FXMP-RZ P4...
I want install graphic drivers
Please visit below to get the driver for your Operating system.
http://ee.giga-byte.com/products/mb/driver/ga-8ld533-c.html
Thanks for joining us.
Have a nice day.
Dec 08, 2010 | Gigabyte GA-8LD533 Motherboard
Wont start monitor
The Gigabyte GA-8PE667 Ultra MB will only run certain AGP graphics cards. Check you manual. See page 1. Click the next link to open your manual; http://europe.giga-byte.com/FileList/Manual/motherboard_manual_8pe667u_e.pdf
To view your manual you'll need the program, Adobe PDF reader.
You can download Adobe here; http://www.adobe.com/products/reader/
If you install anything other than an AGP 4X, (1.5Volt) graphics card. Your system may not boot up normally, if at all. Just because you tested your graphics card in another system does not mean the card is compatible with the GA-8PE667 Ultra. The link below will show a compatible graphics card for your Gigabyte GA-8PE667 Ultra;
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3281698&csid=ITD&body=MAIN#detailspecs
Cheers!
Mike
Nov 05, 2009 | Gigabyte GA-8PE667 Ultra Motherboard
I need graphics driver
Here is the download page for the Gigabyte GA-945GCMX-S2:
http://tw.giga-byte.com/Support/Motherboard/Driver_Model.aspx?ProductID=2521
Let us know if that's what you were after. ;-)
Feb 03, 2009 | Gigabyte GA-945GCMX-S2 Motherboard
Upgradation for vista
Gigabyte 7VM333M-RZ - motherboard - micro ATX - KM266
There is a cool way to find out just what it takes to run Vista on your current system. Download and run MS Windows Vista Hardware Assessment. It will help you prepare and suggest just what you need to upgrade either hardware or software. Make it simple! Download below.
http://www.microsoft.com/technet/solutionaccelerators/hardwareassessment/wv/default.mspx
Dec 11, 2007 | Gigabyte 7VM333M-RZ (GA-7VM333M-RZ)...
AGP card support
Hi, Unfortunately no AGP slot nor PCI-E. The Gigabyte GA-8I845GV motherboard has only 3 Expansion Slots and all of the are PCI (33MHz & PCI 2.2 compliantt). From their website, here's an image of the motherboard http://www.giga-byte.com.tw/FileList/Image/motherboard_productimage_ga-8i845gv_big.jpg It has a built-in Intel® Extreme Graphics Engine (845GV chipset) for video with max of 128 mb shared memory. Should you wish to install an add-on 3rd party PCI video card, Inno3D FX5500 256ddr PCI slot tv-dvi are still available (at least in my location) for an equivalent of about 3.5K INR (80USD+). Hope this gives you an idea. Good luck and kind regards.
Aug 19, 2007 | Gigabyte GA-8I845GV-C (GBSA4LB)...
What graphics card this motherboard will support
Gigabyte did not put a special graphics slot (AGP, PCIe etc) on this corporate series board. It has good internal graphics support. If you would like to run two monitors, it appears that one choice is the CHAINTECH P-FX20 256MB Geforce FX5200 256MB 128-bit DDR PCI Video Card, based upon user reviews at NewEgg. You may need help getting both graphics adapters to operate together. Typically, there is a jumper on the card that disables "Primary VGA" mode. Your OS should boot using the on-board adapter and then you can tell the OS that it should "Extend the Desktop" to the second (PCI) adapter. Your results may vary.
May 12, 2007 | Gigabyte GA-8I865GVMK Motherboard
ATI RADEON HD 2400 PRO Graphic Card Logo
96 people viewed this question
Top ATI Computers & Internet Experts
David
David
Computer Links
Tony
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
