Question about Keurig B60 Coffee Maker
I cannot find an exit needle on my used keurig B60, where do I buy a new one?
    Champion:
  • 248 Answers
Coffeemakers.smarter.com
Posted on Oct 12, 2010
My Keurig coffee maker will not pump water into the chamber, I have tried the fixit suggestions but to no aavail. Machine was used less than 6 months.
Take the K-cup insert out.
Insert a small paperclip and carefully insert upward into exit needle, swirl to dislodge debris (clog could be preventing H2O uptake).
Do this for all three of the holes in the exit needle.
Add distilled white vinegar to reservoir.
Run "Brew" without a KCup to see if this clears the reservoir uptake and exit needle.
Fill reservoir with water and run to clear vinegar from system.
Mar 13, 2014 | Keurig B60 Coffee Maker
Kureig heats but won't brew
The exit needle could be clogged located( inside bottom of the holder assembly). Remove K-cup assembly and detach funnel. Insert a paper clip or simiilar tool into the exit needle to loosen the clog and push it out. REMEMBER, the needles are very sharp, proceed with caution!!
You may also need to Descale your Keurig...I do this every other month due to high mineral content in my potable water. Change out resevoir filter and clear exit needles as part of Descaling. Disable "auto shut off" feature, remove reservoir filter and do not use a kcup prior to proceeding. Place 48ounces of white vinegar into reservoir, press brew, discarding each mug of water down kitchen drain and repeat until "Add Water". Let brewer stand for four hours in "On" . Rinse after 4 hours by filling water reservoir with fresh water and press brew until ADD WATER is indicated.
I run two full fresh water cycles before actually using the Keurig for beverages I will consume.
Hope this helps
Nov 17, 2013 | Keurig B60 Coffee Maker
Keurig exploded k cup & very slow to brew
The water tube needs cleaning and the lower holder also. You have a clogged system and it needs cleaning.
Feb 06, 2013 | Keurig B60 Coffee Maker
Keurig B31 one cupcoffee maker users mannual
Keurig calls the B31 the Mini Plus Brewer. The manual is available from the Keurig Customer Service site: http://www.keurig.com/customer-service/brewer-registration-and-support/user-guides-and-help . The direct link to the English version of the Use and Care Manual is http://www.keurig.com/customer-service/brewer-registration-and-support/~/media/Files/Keurig%20Brewer%20Manuals/B31%20UCG%20ENG_FRE.ashx .
I hope this helps.
Nov 08, 2011 | Keurig B60 Coffee Maker
Where is the Exit needle
The exit needle is on the bottom of the K-cup holder...it pokes the bottom hole in the K-cup...
heatman101
Sep 12, 2011 | Keurig B60 Coffee Maker
I need the little rubber part that goes over the neddle
I lost the little rubber gasket that goes over the top needle. WHere can I get a new oone. THanks
Sep 21, 2009 | Keurig B50 Coffee Maker
Weak coffee
Have you de-scaled and rinsed your Keurig?
Two things more you should look after: Boiling temperature and cleaning the funnel and exit needle.
Instructions here:
http://www.keurig.com/help/B60_Use&Care_guide_spreads.pdf
Nov 24, 2008 | Keurig B60 Coffee Maker
Coffee isn't dispensing properly
You're using K-cups right?
Check if the funnel or exit needle is clogged up.
If you haven't de-scaled it for the last 4 months, try to de-scale it and rinse it with clear water and no K-cups.
Information here: http://www.keurig.com/help/B60_Use&Care_guide_spreads.pdf
Nov 14, 2008 | Keurig B60 Coffee Maker
Keurig B60 Coffee Maker Logo
610 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
