Question about EliteGroup 945GZT-M (V1.0) Motherboard
Configuration problem I've had my 945gzt-m motherboard for a while,now all of a sudden it's reading only 3rd master and 3rd slave drives no matter if i change the junpers on the drives or even the cables
  • Anonymous Nov 12, 2008
    no hay audio de salida y ya reinstale los drivers de la board. La opciòn aparece inabilitada desde el sistema. tambien reinstale el sistema operativo.
    Muchas gracias
    Atte, Oscar Fernando V.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 262 Answers
Maybe several things,sli maybe bad,pci bad or if using standard feed to motherboard carrier of info from plug in to cpu may have shorted out. lala linda
Posted on Jun 02, 2008
What connections are required to set hard drive function (Master, Slave, etc) in this case for use on a USB extender
Doesn't matter where the pins are if the drive is being connected via usb because it will act as a internal drive. If anything, just set the jumper to Master.
Nov 08, 2012 | Computers & Internet
How do you connect the cables or jumpers?
the leads from your ((motherboard to your hard drive)) they might have a 40 pin on the hard drive or a sata they just push on to make a connection make sure they have a secure connection
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
? single or master :::::
master with slave ::'::
???????????????? slave? :::':
note the plastic jumper is ' located at the rear of the hard drive next to the IDE/SATA lead/s
hope this helps
?don't forget to vote
Feb 08, 2011 | Western Digital Caviar SE WD3200JS...
What are the 2 pins in the back for? master slave configurations? If so what jumper setting makes it a slave?
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
hope this helps
dont forget to vote
Feb 06, 2011 | Hitachi Deskstar 7K160 HDS721616PLA380 160...
When I connect 2nd and 3rd hard disk my system wont starts......
Just because it has a CPU, it is not a brain
It is ok to set up 2 or 3 harddrives BUT... make sure one is a master, (C:)the others are slaves D-Z
Look at all drives, most now have jumpers and they are master,slave,cselect.
To make it easy, slaves/masters
Jul 24, 2010 | Intel D915GAV Motherboard
Bios Fail to detect Local Disk C and DVD-RW
I'm going to make an assumption here and guess that you have both hard drive and cdrom plugged into the same IDE cable. I think you have either 2 masters or 2 slaves and that is why the bios can't see them. On any one cable you can have a master and a slave. Drives have to be jumpered to configure them as a master, slave, or cable select. Cable select requires a certain kind of cable but in that system the master is the drive plugged into the first plug-in away from the motherboard or the middle plug and the slave is the second one or end plug on cable. If you can jumper cable select and then plug the hard drive into the middle plug on the IDE ribbon and the CD rom to the end one then you'll have a master and a slave. Bios should then read the drives. If that doesn't work then you have to jumper the hard drive to master and cdrom to slave. The cdrom is marked on the back as to which jumpers you use. MS/SL/CS. master/slave/cable select. The hard drive usually has jumper settings on the front of the drive but you might have to look up on manufacturer's web site. Most computers use cable select now.
Dec 06, 2009 | Audio Players & Recorders
Master slave jumper settings on 250gb Maxline Plus II SATA
There are no master/slave settings on SATA drives because each drive has its own cable. The drive order is determined by what SATA port they are plugged into, or by the BIOS configuration.
Mar 16, 2009 | Maxtor MaxLine Plus II 7Y250MO 250 GB SATA...
IDE HD Not Detected
My first thought is the cables have been moved or the drives moved. Maybe the jumper has fallen off the back of the drive (highly unlikely, but possible) or maybe a cable has come loose. It can't hurt to reseat all the cables and check the jumpers to see that all are correctly jumpered as master and slave.
herdex may not have the same problem, but will email this suggestion to him.
Nov 07, 2008 | ECS 945GZT-M (V1.0) Motherboard
Seagate 320g internal hard drive
Hi-
How bout on device manager? right click on my computer icon then go to manage, go to disk manager and check the disk management and configure the new hard drive
hope this helps
Aug 16, 2008 | Computers & Internet
I installed an additional hard drive in my laptop. The computer will no longer boot up. I've read the the BIOS needs to be changed by I don't know how.
Please tell me which Motherboard your system has???
If you have added an additional drive, check whether you have set the jumpers right for master/slave/cable select configuration.
If you bios setup to boot up from first HDD, then the bootable HDD shall be in master mode. Configure bootable HDD as master & additional one as slave.
If still no luck, Put this additional HDD on other IDE slot.
Tell me if this works...
Jun 21, 2008 | Computers & Internet
945GZT-M: HD listed as third IDE master in bios
If the drive is set as Cable Select you are allowing the motherboard to detect where it is on the ribbon cable. If the drive is shown as Primary slave then the drive is on the wrong connector on the ribbon cable. If it is shown as secondary master than the IDE cables on the board need to be switched (primary to secondary, secondary to primary)
Apr 10, 2008 | ECS 945GZT-M (V1.0) Motherboard
EliteGroup 945GZT-M (V1.0) Motherboard Logo
43 people viewed this question
Top EliteGroup Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Matthew Spark
Matthew Spark
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
