Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
I have a USB connector on the back of my 250GB My Book that is now broken. The inside black rectangular plastic is missing. Can this be easily repaired?? I can do this myself if it can be.
    Problem Solver:
  • 4 Answers
Repair is next to impossible. The black center part that's missing is what holds the four gold terminals in place. Good news is these external hard drive cabinets are universal. You can buy an empty one on eBay, for instance, and mount your drive inside.
Only caveat: The included software might not work on a non-MyBook drive interface. But if you don't use the software (which usually sucks anyway) then you are good to go.
Posted on Oct 12, 2010
I got a memory card card reader that fits in myu tower it conects to the front usb pins but i dont know which way around the connector needs to be
David, first take a look at the connector at the end of the card reader's cable. It should be a rather wide rectangle, silver in color. You'll notice that one of the two wide sides has a thin line in the metal (or a ****, or whatever one might call it). That side should generally face down when you connect the cable to your PC.
If the USB connections are on the back of your PC and are vertically oriented, it's slightly trickier. You'll probably notice that the USB "ports", as well as all the other cable connections, are all grouped together in a rectangular area, with many of the connections being colored. That rectangular area is probably flush with one or the other side of the tower. While looking at the back side of the tower, the side that rectangular connector area is closer to is considered the "bottom direction". So if it were, say, on the left side, turn the USB connection so that the side with the **** is on the left as you connect it to the PC.
If you're unlucky enough to have a USB connector at the end of the cable on which both of the wider sides look 100% identical (without that distinguishing ****), then another way to figure it out is to look into the inside of the connector. You'll notice that it's partly hollow, and the other half is taken up by a white, black or possibly blue piece of plastic. Turn the connector so that that plastic part is in the lower half
Aug 08, 2011 | Computers & Internet
I cannot install the above mentioned scanner since the driver is unspecified
IF IT IS USB BARCODE SCANNER, DO THESE:
1.
Locate the USB connector on the bar code scanner. Bar code scanners, like other computer peripherals, connect to the computer by way of a data cable. At the end of the data cable, most likely opposite the scanner itself, should be a small rectangle-shaped plastic and metal connector. This connector is the USB terminal that will plug in to the computer's USB port.
2.
Locate the USB port on the computer. The USB port, whether on the computer or a peripheral device, will be rectangular in shape and feature either the letters "U S B" or a small network diagram showing two circles, a square, and an arrow.
3.
Connect the USB cable to the computer or peripheral device. Once the USB connector and port have been identified, push the USB connector firmly but gently into the available USB port. USB connectors are keyed so that they can only be inserted the correct way; if you feel solid resistance while inserting the USB connector, remove the connector from the port, turn it over and plug it in.
4.
Install bar-code reading software. While the bar code scanner can scan the bar code into the machine, software must decipher the meaning of the code. Bar code scanners, if purchased new, should include a version of proprietary bar code software compatible with your scanner. If your scanner did not come with software, or if it is missing the installation disc, bar code software may be purchased on the Internet from sites like WaspBarcode.com.
TO INSTALL A SERIAL BAR CODE SCANNER, DO THESE:
1.
Locate the serial connector on the bar code scanner. Bar code scanners, like other peripherals, connect to the computer by way of a data cable. At the end of the serial cable should be a rectangular, typically male connector. The cable may be pinned with nine, sixteen, or more pins depending on the design of the scanner.
2.
Locate the serial port on the computer. Most computers have at least one serial port, usually found on the back of the machine. The port will be female, maybe blue in color, rectangular in shape, and should be approximately the same size (or slightly smaller) as the serial connector.
3.
Connect the serial cable to the computer or connected peripheral. When both the connector and port have been identified, push the serial connector firmly but gently into the port. Like USB connectors, serial connectors are keyed so that they can only be inserted the correct way; if you feel solid resistance while inserting the connector, remove the connector from the port, turn it over and plug it in. Do not use excessive force while pushing on the serial connector, as it is possible to bend the connecting pins and damage the connector.
4.
Install bar-code reading software. While the bar code scanner can scan the bar code into the machine, software must interpret the meaning of the code. Bar code scanners, if purchased new, should include a version of proprietary bar code software compatible with your specific scanner. If your scanner did not come with software, or if it is missing the installation disc, bar code software may be purchased on the Internet from sites like WaspBarcode.com.
THANKS AND WELCOME.
Apr 12, 2011 | Computers & Internet
How do you remove the battery in a 2000 LS1 saturn?
If you remove the tray , the battery will still be stuck on it because of the metal covering the line of plastic which is on the battery.
There must be a rectangular box in front of the battery that slides up off a metal plate that is secured by the same bolt holding down the front of the battery. Once you slide off the rectangular box, the bolt is more easily accessible.
Undo the bolt, there's one at the base on the back (side of the connectors). You'll need a long socket wrench connector
Aug 17, 2010 | 2000 Saturn L-Series
Hello i need to know how to reconnect the computer case wires to a sr1703wm compaq motherboard
Hello.
The Compaq Presario SR1703WM desktop computer, uses an Asus A9AE-LE motherboard.
HP/Compaq's name is AmberineM - GL6E
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00496280&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&lang=en&product=1815742
1) I would like to start with the Front Panel wires.
The Front panel, is the plastic front on your computer tower, where the Power On button, Power On LED, and so on is located.
The Front Panel header is the connector on the motherboard, where the cables, (Wires), from the Front Panel connect to.
Looking at the HP Support link above, I would like you to scroll down the page to the illustration of the motherboard, and the photo of the motherboard under the illustration.
Looking at the illustration observe the bottom Right corner.
F_PANEL1 indicates the Front Panel header.
Note there are 4 pins going across the Top, and 5 pins going across the Bottom.
Looking inside your computer, the motherboard will be located in a different position, compared to the illustration.
The Front Panel header will be located Vertically, (Up, and down)
Note that there is a twisted pair of Black, and Red wires.
These wires form the Power On cable.
They come directly from the Power on switch.
There is a twisted pair of Yellow, and Black wires.
These wires form the Harddrive Activity LED light cable.
(HDD)
When the harddrive is active, this LED flashes.
There is a twisted pair of Green, and Black wires.
These wires form the Power On LED light cable.
The wires, (Cables), should be in one Black connector.
Looking at the Front Panel header in your computer, align the Black plastic connector's socket holes, with the pins sticking up out of the Front Panel header, on the motherboard.
Note that the Front Panel header is rectangular in shape. There is 1 pin missing.
The Black connector coming from the Front Panel of the computer, has one socket hole blocked off, to match.
Align the four socket holes in the Black connector, to match the 4 pins sticking up out of the Front Panel header, on the motherboard.
The other 5 socket holes in the Black connector, will match up to the 5 pins sticking up, automatically.
Use care, and you may need a bright light to assist.
These pins can be bent quite easily.
(Also watch your fingers, as the ends of the pins are S-H-A-R-P!)
2) Where it states CLRTC (CLPWD under it), is the Clear CMOS jumper.
Suggest you leave it alone.
3) Where it states F_ USB1, and F_USB2, is where the USB cables from the front of the computer connect to.
(The USB ports on the front of the computer's Front Panel.
F_USB1, and F_USB2 headers on the motherboard, are shown on the illustration to the Left, of the Front Panel header. F_PANEL1)
The plastic connector on a USB cable coming from the Front Panel, has an orientation just like the Front Panel header cable does.
There is 1 pin missing on the USB header on the motherboard.
There is a blocked socket hole in the USB cable's connector.
Align the connector to match the pins.
Doesn't matter which USB cable from the Front Panel, that you connect to the USB headers on the motherboard.
BIOS will find them, and assign an IRQ to each, once you turn the computer on.
All you will see at a first glance is a series of thick Gray insulated cables, coming from the Front Panel of your computer.
If you follow the cables by eye, you can see where the USB cables are connected to the back of the USB ports, on the Front Panel.
You may, or may not, have to remove the Front Panel to see more clearly.
Computer case open, look inside towards the Front Panel.
There is a Green plastic tab towards the Top.
This locking tab is depressed Towards the Inside of the computer, to START to unlock the Front Panel.
Towards the bottom in the same plane, is a Black locking tab. This tab is pulled Towards the Outside of the computer.
There is another Black plastic tab on the opposite side.
At the Bottom are two more Black plastic locking tabs. These are depressed down, towards the Bottom of the computer case.
One on one side, one on the opposite side.
Start by depressing the plastic Green tab, and gently easing the Top of the Front Panel, slightly out.
Then go to the two Black plastic locking tabs located towards the Middle, and depress them.
Ease the top of the Front Panel out a little more.
Finally go to the two Black plastic locking tabs located at the Bottom, and depress them.
Ease the Front Panel off.
(NOTE*
Your computer's Front Panel may not have locking tabs located at the bottom.
Just locking tabs located up from the bottom, more towards the middle)
It's no picnic for your first time, but once you have done it, it becomes easy. (Ummm, Easier!)
4) The Firewire (a1394) cable on the Front Panel, connects to the F_1394 header on the motherboard.
In the motherboard illustration the F_1394 header is located to the Left, of PCI2
Need any further cable connections, post in a Comment.
Aug 14, 2010 | Compaq Presario SR1703WM PC Desktop
Broken black piece inside usb port
This is usually going to be a part replacement problem. the black piece is part of the connectors. and backs up or guides the connectors. you can go to your local computer parts store such as frys, or an electronics parts house. and buy the connectors unless it is one that is attached to the motherboard in the back of the computer. if this is the case and you do not have enough usb ports, then you have to get an external usb hub. usually a powered hub is best.
Nov 12, 2009 | Computers & Internet
My MP3 USB is not recognized by my PC,
May be a bad USB cable. Check the connector on the end that plugs into the pc, something inside may be broken preventing the connection. Sometimes the flat plastic piece inside (white or black) breaks loose if you forced it into the usb port or felt resistance when inserting it. If it came with software, you may have to reload it especially if you are using Windows 98.
Mar 12, 2009 | Nextar MA168 (128 MB) MP3 Player
Power cord broken inside s251i miele How do i open the s251i ????
HOW TO OPEN MIELE 251 VACCUUM: 1-Unplug from wall and disconnect power cord 2-Remove black switch panel at back of top panel: A-Use Phillips screwdriver, remove two silver screws visible between back of hinged top door and front of black switch panel
B-Push back of the panel down while pushing it forward (towards front of machine). There are two plastic notches and clips which are tightly fit together that you need to separate.
Once it releases, push it a bit more towards the front of the machine and lift off panel. It has wires connecting it to the main body so it will not remove completely.
C-Be careful not to lose the springs that simply sit inside of two plastic channels, one under each of the two switches. These are required for your witches to operate properly.
3-Locate screw at bottom of deep rectangular hole now revealed (under former location of black switch panels). Unscrew using Phillips screwdriver. 4-Open hinged top panel. Locate two silver screws, one on each side of main housing. Unscrew using Phillips screwdriver. 5-This will let you lift off the whole top assembly, door and main housing, revealing the plastic chassis and the motor unit within.
You now have access to the motor, wiring connector harnesses, circuit board and the cord reel.
Dec 07, 2008 | Miele S251i Plus Bagged Canister Vacuum
Broken usb port, Acer desktop
May be hard to find.
If you have a spare PCI slot in your motherboard, I'd buy a cheap USB card and install it.
Here's some cheap ones online:
http://www.monoprice.com/products/subdepartment.asp?c_id=103&cp_id=10304
You may also be able to get one on eBay reasonable.
Nov 08, 2008 | Computers & Internet
How do I take my Miele S251i apart to be able to chenge the powercord?
Sep 13, 2008 | Miele S251i Plus Bagged Canister Vacuum
USB Cables
most of them are easily found. You could take it to your nearest radioshack and they should be able to point you in the direction of a new cable.
Jan 30, 2008 | Computers & Internet
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
166 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
