Question about Apple iPod touch
It says device not recognised code 43 - Apple iPod touch
  • 863 Answers
You got to use the original computer you used for the 1st sync. Also, try using a different USB port or do a hard reset while connected to the computer. Press the top power button and bottom home button at the same time and don't let go until you see the apple logo. This will reset the whole thing and you will lose all your data and tunes.
Posted on Oct 12, 2010
My Lexmark e332n shows error code 43 ,what does it mean?
G'Day Mate,
Are you running the Lexmark driver for Windows 7 64 bit.
Try down loading the driver and installing it on your p.c.
Suspect USB driver for printer is missing - Windows can't detect it as it doesn't recognise it. By installing the Lexmark driver it updates windows to recognise the lexmark printer usb interface.
you will find driver here
http://support.lexmark.com/index?locale=en&page=product&productCode=LEXMARK_E332N&segment=SUPPORT&userlocale=EN_US&frompage=null#1
Aug 14, 2015 | Lexmark E332n Laser Printer
A lot of my favorite music is on my flash drive,error code 43 message
Code 43 Error Message
The Code 43 error is one of several Device Manager error codes. The Code 43 error will almost always display in the following way:
"Windows has stopped this device because it has reported problems. (Code 43)"
Details on Device Manager error codes like Code 43 are available in the Device Status area in the device's properties
rror Code 43 Troubleshooting
  1. Restart your computer if you haven't done so already.
    There is always the chance that the error Code 43 you're seeing on a device was caused by some temporary problem with the hardware. If so, a restart of your computer might fix the Code 43 error.
    Note: Some users have also reported that powering off their computer completely (not just a reset) and then turning it back on has corrected their Code 43 issue, especially if it exists on a USB device. In the case of a laptop, turn it off and remove the battery, wait a few minutes, and then put the battery back in and start the computer.
  2. Did you install a device or make a change in Device Manager just before the Code 43 error appeared? If so, it's very possible that the change you made caused the Code 43 error.
    Undo the change if you can, restart your PC, and then check again for the Code 43 error.
Jan 28, 2013 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
What is code 43
Details on Device Manager error codes like Code 43 are available in the Device Status area in the device's properties: How To View a Device's Status in Device Manager.
Cause of the Code 43 Error
A Code 43 error is generated when Device Manager stops a hardware device because the hardware reported to Windows that it's having some kind of unspecified problem.
This extremely generic message could mean there's a true hardware issue or it could simply mean that there's a driver problem that Windows isn't seeing as such but that the hardware is being affected by.
Error Code 43 Troubleshooting
Depending on the changes you made, some solutions might include:
Jan 23, 2013 | Lenovo Computers & Internet
How do I fix the msi motherboard windows 7 USB error 43?
How to Fix a Code 43 Error
  3. Reinstall the drivers for the device. Uninstalling and then reinstalling the drivers for the device is a possible solution to a Code 43 error.
    Important: If a USB device is generating the Code 43 error, uninstall every deviceunder the Universal Serial Bus controllers hardware category in Device Manager as part of the driver reinstall. This includes any USB Mass Storage Device, USB Host Controller, and USB Root Hub.
    Note: Properly reinstalling a driver, as in the instructions linked above, is not the same as simply updating a driver. A full driver reinstall involves completely removing the currently installed driver and then letting Windows install it over again from scratch.
Sep 16, 2012 | MSI INTEL G41 INTEGRATED VGA-MATX 2DDR3...
Microsoft Lifechat Lx-3000 headset, USB not recognised. I bought the headset a few weeks ago and installed the installation disk. Worked fine for about two weeks until suddenly it will be recognised by my...
In some cases installed drivers become defective for one reason or the other. You may try a free program from Glaysoft called GlayUtilities. Run the program and let it find faults. Clean the system when it finds errors. After the system is clean; reinstall the USB headset drivers and see if that works. That's a Start
Jan 11, 2018 | Microsoft LifeChat™ LX-3000 Headset
I have a toshiba satellite L510, running on windows 7 home premium. My problem is that under the device manager there is an unknown device in one of the Universal Bus Controllers. When i looked at its...
Check this link to find an upgrade assistant for toshiba
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/bulletin.jsp?ct=SB&soid=2460108&ref=EV
Probably you missed a driver when installing or you have an usb device plugged in, that is not recognised.
May 03, 2011 | Computers & Internet
Whats code 43? i have an HTC Touch phone im
As Microsoft states.
Recommended resolution
One of the drivers controlling the device notified the operating system that the device failed in some manner.
If you have already run the Troubleshooting Wizard, you might want to check the hardware documentation for more information about diagnosing the problem.
Aug 08, 2010 | Microsoft Windows Vista Ultimate Edition
Apple iPod touch Logo
317 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
