Question about Alphasonik PMA1200D Car Audio Amplifier
Amp turns on all was well now no sound evwryrhing is wires right don't get it 99 Taurus w ecc so I used output adaptor replaced that to
Amp turns on but puts out no sound except for faint noise which dies out after a few seconds.
It sounds like a defective/incorrect AC-to-DC adapter may have caused your problem. These adapter come with different output voltages, AC or DC output and different amperage ratings. AC-to-DC adapters list the polarity of the DC voltage as it relates to the DC power plug and you must match both the devices voltage and power requirements. As for the amp...not working on batteries either, I would suspect output transistors or IC.
May 23, 2014 | Marshall Amplification Marshall MG2FX...
Tip
How To Diagnose No Sound Output From Your Vehicle Stereo
  1. Check each Subwoofer or Speaker that isn’t working for continuity - At the subwoofer or speaker, one at a time, test the terminals for Continuity using your Digital Multi-Meter; if your DMM doesn't have a Continuity test, use the Resistance, or Ohms, test and check for Resistance in the Subwoofer Coil (be sure to disconnect the subwoofer wiring before performing these tests).
  2. If they test out good, hook the wires back up and test the terminals at the terminal cup or at the Amp hookup if you didn’t use a terminal, don't hook it up to the amp yet. Sometimes the wiring inside the box can be a problem if it has come loose, or isn't making a great connection.
  3. If you have a Sub or multiple Subs with Dual Voice Coils, or multiple Subs with Single Voice Coils, make sure your wiring is correct by checking here: http://www.the12volt.com/caraudio/woofer_configurations.asp
  4. Make sure there are no Hi-Pass filters, crossovers, or multi Channel switches enabled.
  5. Replace your RCA cable/s with known working RCA cable/s from the Source/Head Unit to the Amplifier/s.
  6. Check your Head Unit settings; make sure the Bass is turned up and/or the Subwoofer setting is turned On.
  7. If you are still getting no output, try plugging in an MP3 player or CD player using a headphone to RCA adaptor and check for sound output. If there is still no output, your Amplifier outputs are probably burned out.
on Jul 18, 2010 | Car Audio & Video
Marshall Amplification Marshall MG2FX Guitar Combo Amp power turns on but no sound
Hi!
At this point, I would just take it to a tech rather than poke around in it. It sounds like the power section is the problem as you have guessed, but without the technical knowledge you'd be shooting in the dark. That particular amp is right on the line of being expensive enough that would be worth repairing, but you might do just as wel to check Ebay for another used one.
Good Luck!
May 21, 2014 | Marshall Amplification Marshall MG2FX...
99 ford taurus rear tires wearing onthe inside.how do i fix
It sound like the Camber is off in the rear. Did you have an alignment done after the new struts wear installed?
Jan 03, 2013 | 1999 Ford Taurus
Want to reset ECC (ECM) on 1995 Mitsubishi Mirage 1.5L. Don't know if I am doing it right
This procedure is knowed as "soft reset", and you will must keep in mind that, if some anti-theft system is instaled there, the no start condition could appears after disconneting the battery.
Additionally, could try and check if the starter is cranked when turn ignition key, or no click sounds there? Could be a battery charge, starter or ignition swtich issue.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Aug 23, 2012 | 1995 Mitsubishi Mirage
I have an old kenwood kac-801. It doesn't have rca outputs. i have an output adapter but the wire colors are different. i need the scematics or someones help
take one of your door speakers and check the wireing on the speaker and hook up your wires to those wires on your raido
May 12, 2010 | Car Audio & Video
1993 Volvo 850, ECC lights blinking and no fan
sounds like you bought a defective part.
Jun 12, 2009 | 1993 Volvo 850
2007 Ford Taurus
If you check your head unit it should have a "remote wire" output at the wire dock.
This is the wire that tells the amp to turn on every time you switch the head unit on to listen to music.
Then you need to run a positive wire from your battery with an inline fuse to the amp. (Make sure you use thick wire, if you skimp and use thin rubbish wire it may catch on fire/heat up and will also result in a huge performance loss).
You need a negative wire also the same thickness, that bolts directly to body somewhere.
If you go to an auto sound shop they should be able to provide you with a amp kit for around $20 bucks. In my experience its far less hassle than messing around trying to make one up from scratch.
Because they come with the sound cable wiring and all the electric wiring cable and all necessary plugs ect.
Thats my advise anyway.
Jules
Aug 12, 2008 | 2006 Ford Taurus
How to install Rockford Fosgate 3sixty.1 to a Toyota factroy head unit?
You will need a line level adaptor to get an audio input for the amp.
A line level adaptor is a device that lets you tap off of your speaker outputs of the radio and it converts that signal into the proper level for an RCA input signal the amplifier uses.
If you are installing the amp in the trunk of the car you can just tap off the speaker outputs of the rear speakers mounted in the trunk. Keep the speaker outputs connected to the speakers, just run an extra set of wires from them to the line level adaptor. It will not take anything away from the speakers sound because it is not a power drain on them.
After that, you just connect the power wires for the amp as you would normally and you also need to run an extra wire from the radio power antenna wire to the remote turn on of the amp, or you can use a wire directly from the battery and connect it thru a switch you would need to connect somewhere around the dash, so you can turn the amp on and off when you need to. The power antenna wire from the radio is best, so you don't need to turn the amp on and off manually. It is easy to forget about turning it off sometimes and that would run doen your battery if the amp is left on over night even with no signal going thru it.
Then connect your speakers to the amp and thats it.
Then big issue is getting an audio signal to the amp and the turn on signal for the amp.
If you need more help let me know,
Dave
Aug 08, 2008 | Rockford Fosgate Audio Players & Recorders
Alphasonik PMA1200D Car Audio Amplifier Logo
20 people viewed this question
Top Alphasonik Car Audio & Video Experts
xxxxxx xxx
Are you an Alphasonik Car Audio and Video Expert? Answer questions, earn points and help others
