Question about Western Digital Caviar SE WD2500JS (WD2500JS20PK) 250 GB Hard Drive
Won't boot in safe mode or reinstall windows vista. Failed a hard drive test by seagate.
  • Western Digital Master
  • 27,725 Answers
You could run the check disk utility
click start run type cmd then type chkdsk/r/f which will automatically fix any corrupt files on your hard drive or
go to control panel administrive tools computer management you can right click on the drive select properties tools check now?tick in both boxes to scan for and repair/recover any bad sectors and automaticall fix any corrupt files
in xp
hope this helps
Posted on Oct 12, 2010
How do i boot into safe mode?
To boot into safe mode press F8 continually on and off from before the windows logo!
Oct 04, 2014 | E-Machines eMachines Desktop PC
Userinit.exe application error
Hi again:
I would suggest that you may have a virus / spyware infection that has infected this windows file.
If you can boot into SAFE Mode ( reboot the computer) and when the screen goes to the black background with white writing start pushing F8 - keep doing so until you get a screen that gives you a list of things you can do -
ie:
restart windows normally
safe mode
safe mode w/networking
use the arrow keys on the keyboard and choose to boot into safe mode.- may take a couple of minutes
once there i would suggest running virus / antispyware scans as well as running a BOOT SCAN (a type of virus scan that scans the hard drive before it gets into windows)
NOTE on running virus/spyware scans - ALWAYS QUARANTINE the file infected - DO NOT DELETE - if you delete a critical windows system file you will cause windows to completely crash and in that instance you would have to reformat the hard drive and reinstall everything.
Jan 02, 2012 | Computers & Internet
Yahoo messenger error "this application has failed to start because the application configuration is incorrect"
Can you get the Chkdsk to run in the general Windows interface by following these instructions?
Try running ChkDsk to check your drive for errors. Right-click your Drive icon/ Properties/ Tools/ Error Checking. Try it first by not checking either box (this will run it in a Read-only mode) to see if it flags any hard drive or file problems. If it does, restart it by ticking both boxes, and rerun it to allow it to attempt to fix any found problems.
Does your Command Prompt work from Safe Mode or from a Clean Boot?
Advanced startup options (including safe mode)
http://windows.microsoft.com/en-US/windows7/Advanced-startup-options-including-safe-mode
How to troubleshoot a problem by performing a clean boot in Windows Vista or in Windows 7
http://support.microsoft.com/default.aspx/kb/929135
Does it work if you test with another user, you may have to create one to test with?
Is System Restore and the System File Checker able to fix anything?
How to repair the operating system and how to restore the operating system configuration to an earlier point in time in Windows Vista (or 7)
http://support.microsoft.com/kb/936212/#appliesto
How to use the System File Checker tool to troubleshoot missing or corrupted system files on Windows Vista or on Windows 7
http://support.microsoft.com/kb/929833
How to analyze the log file entries that the Microsoft Windows Resource Checker (SFC.exe) program generates in Windows Vista
http://support.microsoft.com/kb/928228#appliesto
Have you tested for Malware? I see lots of recommendations here for programs like -
Malwarebytes' Anti-Malware
http://www.malwarebytes.org/products/malwarebytes_free
SuperAntispyware
http://superantispyware.com/
Source: http://answers.microsoft.com/en-us/windows/forum/windows_vista-windows_programs/yahoo-messinger-wont-start-it-says-the-application/a4f50587-af18-44c8-9157-5157e465a191
Dec 31, 2011 | Yahoo Messenger
Dell inspiron 1545 Laptop computer is getting BSOD on boot, when first ran diagnostics got error: Hard Drive - DST Test Results - Fail Error Code 2000-0142 Msg Hard Drive 0 - self test unsuccessful status...
The error indicates that there's a hard drive issue. If it just happened after the hard disk is reinstalled, remove it and reinstall it. It could be a problem caused by loose connection or improper connections. If the same problem repeats, install the hard drive on another system (to verify whether it works on another machine or not and to confirm it still works). If it doesn't work on another computer/system then your only option to run the system is replacing the hard disk. If it works on another computer or if it's detected on another system, then there could be problem with the hard disk, eg. Corrupt Partition, Windows Corrupt etc....
First of all, try booting into Safe Mode. You have to press F8 during the startup to go into Advanced Boot Options. Once you are in the Windows Advanced Boot Options, select Safe Mode using the up and down arrow keys on your keyboard. If it still doesn't work, it's the hard disk issue. Try with another Hard Disk.
But if in case you can boot into safe mode, check the Hard Disk for errors. In other words, run Windows Checkdisk utility. Hope this helps.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Oct 10, 2011 | Dell Inspiron 1545 Notebook
I had windows vista and tried upgrading to windows 7. the upgrade failed (it was a download from windows) and it tried to resort back to windows vista however that failed. Now the computer wont start...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
Mar 18, 2011 | Seagate Barracuda 7200.10 ST3250310AS SATA...
Hi, toshiba tecra A9 with windows vista fails to startup with errors like; Windows failed to start. A recent hardware or software change might be the cause. options of starting windows normally or safe...
the easiest way to save your data is to get a usb to ide (or sata) connector and plug the drive into another computers usb. Hopefully the hard drive is not too far gone and you can copy your data off. I would like to suggest that the hard drive is bad and you may not be able to save much. if you save your data I suggest that you try to reinstall windows and if this fails test the hard drive for errors
Jul 15, 2009 | Toshiba Tecra A9-S9013X 15.4 Widescreen...
Windows failed 2 restart
A system restore would correct the problem perhaps upon boot try f8 I believe or f2 I forget with vista and try booting in safe mode, if windows can't correct itself reload.
Nov 17, 2008 | Acer Aspire 5100 Notebook
Laptop compaq v2000
your windows install is screwed up. i'd dig up your Windows XP CDand pop that in and do a repair install. if it still doesnt work then i'd enter the bios setup (hit F10 on compaq boot screen) and look in there for "Hard Drive Test" and run that. be aware it will take 70 mins on a 60GB hard drive, and longer for a bigger drive. if the hard drive passes the test then you may want to boot up the XP cd and do a fresh install, opting to format the drive. be aware that formatting WILL delete anything and everything on the laptop.
if the hard drive fails the test, then obviously you need to get a replacement drive and reinstall Windows on that. if the hard drive failed, any data on it is most defenetly toast.
Aug 16, 2008 | HP Compaq Presario V2000 Notebook
Western Digital Caviar SE WD2500JS (WD2500JS20PK) 250 GB Hard Drive Logo
64 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
