Question about Sony KDF-E42A10 42 in. LCD Television
Hdmi issue as well
I have had the same problem... I used to use a HDMI to DVI hookup for my cable, but recently had a DVR upgrade and it is a HDMI to HDMI. I bought a cable and at first it worked, but then I had to disconnect it and when I reconnected the signal was dead. I even exchanged the cable to no avail... I am very confused on what I should try next.
  • Anonymous Jul 15, 2008
    I'm also having the same issue - I am connecting my HDMI cable from a working PS3 to my KDF-E42A10 and getting nothing on the input screens but a small amount of noise on the bottom of the screen.
    You suggested that there was a possible software upgrade I can attempt to possibly correct this issue. Can you please elaborate?
    Thank you for any help you can provide.
    JT
  • j_tollberg Jul 16, 2008
    jkgjjgkjkjhkjhjkhkjhk
    Scholar:
  • 137 Answers
Hello sushy99.
You need to do what is called a software upgrade. This will fix the problem. The software upgrade is free. I can tell you how to do that. There is another possibility that your HDMI board is defective. If after the upgrade, and you still have the same problem...then you must change that board.
Best regards
circuitcity
Posted on Jun 01, 2008
When I connect HDMI from a Time Warner DVR to my Vizio thru a DVI/HDMI adapter, I get no sound. I can only get sound if I use Component input (RGB+ audio R&L). Is this a DVR issue or a Vizio issue?
Use the Time Warner remote and hit the settings button twice. Scroll down to "audio: digital out" and select HDMI. That solved it for me.
The only issue I have now is that I also have component sound outputs going from the cable box to a receiver. When I turn off the TV while the HDMI cable is hooked up to both the box and the tv the sound goes out to the receiver...
Nov 15, 2009 | Vizio P42HD Television
TV is connected to a DVR with HDMI/DVI cable and the picture keeps blinking.
Try another HDMI scource to see what happens there. If the second HDMI works with no issues then it is just a compatability issue with the DVR to your TV. At that point you will have to use the component inputs which will offer high definition as well.
Nov 11, 2009 | Sony FD Trinitron WEGA KV-32HS510 32" TV
I have a problem with the HDMI hookup. The sound
I've come across issues in the past where low quality hdmi cables can cause issues like this. When they were upgraded, the problem was resolved. With having you switching the cables, I wanted to make sure that the audio and video output of the dvr was functioning correctly, which it seems to be. I don't think that you have a problem with either the TV or the DVR. There is a term known as the "HDMI handshake" between 2 components that are connected. Where the DVR isn't even aware that their is a problem with either intermittent audio or video to the TV. It's just that communication via the hdmi cable causes the TV to keep trying to interface with the DVR if it "senses" any inadequacies in data transfer from the DVR. I am not sure what quality hdmi cables you are utilizing, but a higher quality pair will hopefully suffice to resolve the issue. Just a suggestion.. Try finding cables online, such as ebay. You will get a much better deal on them. I hope this information is of some help, despite sordid rambling..lol. If you have any more questions, feel free to contact me. I would be more than happy to assist you in any way possible. Good luck!
Nov 02, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
My monitor says cable not connected
If it like my monitor, same hookups as yours, then when you want to use the hdmi port you need to disconnect the dvi cable. The monitor cannot read from hdmi & dvi when both are connected, Try this & see if your PS3 works. Good luck
Jul 03, 2009 | Hannspree 22" widescreen LCD Flat Panel HD...
Powersurge made my HD setting revert to low def.
Your TV plays High Def material through either Input 4 (uses component cables R,G,B) or through Input 5 (Uses DVI cable).
Today most equipment uses HDMI cable for High Def or it may have a component (RGB) output that you can use. The DVI hookup is best, so you need a HDMI to DVI cable or Component Cables (Red, Green, Blue). You need some source that OUTPUTS High def (ex. 1080i) either through HDMI or component cable. You need to either connect the component cable(R,G,B) from the source to the Input 4 on the TV or connect the HDMI to DVI cable from the source to the Input 5.
You need to set the AV source on the TV to AV5 (if you are using the DVI input) or AV4 (if you are using component cables).
If you want to play Highdef source like Blue Ray then you can just connect the output of the blu ray player to your Tv using either the HDMI to DVI cable or component cable (Red, Green, Blue) and set the TV input to AV5 (for HDMI/DVI) or AV4 (for component).
But if you are trying to get Free High Def from an antenna then you will need to have a component that can OUTPUT high def. The $40 converter boxes don't do this - they simply convert the Digital signal to Analog (non high def). What you need is a High Def TUNER that OUTPUTS High Def. I was looking for one for this same reason and ordered the centronics ZAT 502 HD. But it cost about $80. Then I saw that Tivo had an upgrade deal where I could upgrade my existing Series 2 Tivo to Tivo HD for $99. It has a High Def Tuner in it. So I cancelled my order with Centronics and got the Tivo. In any case if you want Over the air HD you will need a High Def Tuner that will OUTPUT 1080.
Jul 02, 2009 | Philips 55PW9363 55" Rear Projection...
DVI/HDMI Cable lost my pic and sound
Try disconnecting the hdmI cable and the dvr box.
Connect the cable directly to the cable input.
Sometimes the dvr boxes will cause this problem
after you connect the hdmi cable.
Dec 09, 2008 | Hitachi 57F500 57" Rear Projection...
HDMI Cable?
Hi CrysR,
Although you may not be able to locate a cable with one HDMI male end and one USB male end, it is possible you may find a solution with an adapter.
I recommend looking for an adapter that will accept USB input and output to either HDMI or DVI. If you only locate DVI, you can then add a DVI to HDMI adapter at the end.
Be aware with these extra pieces and signal transfers included, it may degrade the quality of your picture.
Thank you,
Jason,
Go Ahead. Use Us.
Jul 05, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Hdmi and audio
It may be the top of set box.. Most times the sound and picture are auto detected by the set when HDMI is used. Both sound and video are carried in a HDMI cable but not with a S video cable. Try another HDMI cable *** dont buy the expensive one the tv don't care if they cost $125 or $25.
May 23, 2008 | Insignia 37" LCD Flat-Panel HDTV
Help with hook up
A lot of people buy digital TV's only to discover that they need to upgrade the rest of their stuff as well. You can hook up the dvr and vcr with composite or component cables of course, but that isn't digital.
Jan 24, 2008 | Haier HLH32ATBB 32 in. LCD HDTV
Sony KDF-E42A10 42 in. LCD Television Logo
110 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
