Question about Visioneer OneTouch 5800 Flatbed Scanner
Gracias por atender mi pedido, tengo instalado windows 7 pero no me funciona los controladores del escaner one touch 5800 usb solo me funcionan para windows xp, he buscado los controlodares pero no consigo por favor si me pueden ayudar con este problema, les agradezco muchisimo.
3 Suggested Answers
SOURCE: escaner 3630
I have solved the problem
thank you for their attention
sincerely
armopconta
Posted on Jul 03, 2008
SOURCE: Visioneer OneTouch 5820 USB for windows 7
ok guys here is the fix for vist and or windows 7 to make your scanners work
1. put your cd in the drive don't let it autorun
2. goto my computer then right click the driver that has your install disk in it
3. click open
4. then fine the drivers folder and open it
4. the file you see should be your driver for your scanner the number on this file should be the modle # of your scanner
5. right click that file then click run as adm. allow any and all pop up's
6. after the install is done restart your computer
7.after the computer reboots go back to my computer and open the driver that has you install disk and open it (do not do auto open) like for this file start32.exe and right click it then click run as adm. allow any and all pop up's (you may see something saying in any one of the steps that the driver or software u are trying to load dose not have a signature always click ok, allow, or indtall this sofe ware is old so it dose not have a signature)
8. after the install is done reboot your computer goto control panle and open it look for systems and open it goto device manager open it then look for your scanner it should not be hard to fine it's the one marked with the yellow flag
9. right that file then goto properties then click on it then goto update driver ( do not click driver update software in the same menu with properties) another menu will open up click on update driver it's just below the driver details box
10. now windows will update your driver when done restart your computer and y should be good to go
Posted on Jun 20, 2010
Aire acondicionado
I can't understand this language. If you are in search for a remote code, visit this link. http://electrohelponline.blogspot.com/ It has setup codes to so many brand remote controls.
May 13, 2013 | Cars & Trucks
Hola, tengo un controlador behringer BCD 2000 y mi portatil es de windows 7, el problema es ke los driver del controlador no estan actualizados (hechos para XP) y por lo tanto no puedo hacer funcionar...
Hola, pruebe este enlace http://www.driverscape.com/download/Behringer-BCD2000-v1.0.0.6 detecta su sistema operativo para darle el controlador correcto para su ordenador. No entiendo el espa?ol. ยก sin embargo, he traducido al ingl?s!
Jul 22, 2017 | Computers & Internet
No encuentro los controladores de scanner4300. para w7
Esta escanner no funciona en windows 7, Dusculpe teine que baja su systema O arrgue un maquena virtual VM ware.
Disculpe Senor por esta molestia pero no es de problema de fixya o de MI es que esta compania y esta escanner is fue de supporte.
Pero todos modos Gracias a usar Fixya Y por favor mi deja un Voto de Gracis Haz click los dedos arriba, y deja sus commentarios
Gracis
Aug 20, 2010 | BenQ Scan to Web 4300U Flatbed Scanner
Problema con audio de hp d530 sff(DS140US)
Hay dos controladores para el sonido de esta placa madre. Aqui estan:
Link a los controladores
Aug 31, 2009 | HP Compaq d530 SFF PC Desktop
Controladores para windows xp
Yo tengo los controladores, pero los puedes buscar en la pagina de rapidshare. yo los descarge de ahi y me funcionan correctamente.
mi correo alsace2407@yahoo.com
May 05, 2009 | Computers & Internet
Tengo telefono GE modelo 27831 x 2 y uno de ellos no funciona
La solucion es super sencilla, simplemente debe poner el auricular auxiliar en la base principal durante 10 segundos y luego ya va a funncionar, por que es la base la que que debe identificar el teléfono, ya que la base auxiliar solo es un cargador.
Saludos...
Apr 04, 2009 | Uniden Cordless Phone
No esta instalado el wireless, no tengo drivers wireless network de mi PC
tendrás que darme su número de modelo de su placa base para que yo le proporcionan los controladores del sitio
garcias
Oct 26, 2008 | Computers & Internet
No funciona
Ulises,
A ver si me entendes, el televisor se ha descalibrado con el control remoto.
o por la tecla que apretaste o por algo que paso.
Para que funcione nuevamente simplemente debes volverlo a programar.
Ya se que no anda, y ya se que probaste mil veces.
Ahora empeza de nuevo y programa el control remoto como si empezaras desde cero
Para ello necesitas el codigo de tu TV para ingresarlo en el control remoto.
Los codigos normales del Silvania son 0054, 0030, 0020, 0096
Si estos numeros no funcionan dame la informacion que te pido abajo
modelo de tu Sylvania
modelo de tu y marca Remote
Oct 19, 2008 | Vehicle Parts & Accessories
Necesito todos los drivers asignados para el Acer TravelMate 3010 (3012WTMi)
https://www.acer.com/ac/en/US/content/support for drivers and support
Mar 07, 2017 | Acer Cameras
Problemas con la camara web
Hola soy nuevo en esto de los foros, tengo problemas con mi camara web 1,3m que viene integrada a mi Toshiba Satellite A215-S4807, tengo Windows Vista Home Premium, entonces mi camara web casi nunca logra funcionar con el msn e incluso el programa que trae ("C:\Program Files\Camera Assistant Software for Toshiba\traybar.exe.exe") no funciona correctamente ya que a veces funciona y otras no... ahora ultimo no ha querido funcionar mas con el msn.
Quedo de ustedes y esperando sepan ayudarme.
Gracias de antemano. Carlos
Jan 25, 2008 | Computers & Internet
Visioneer OneTouch 5800 Flatbed Scanner Logo
42 people viewed this question
Top Visioneer Office Equipment & Supplies Experts
TomHighRidge
Mark Gough
Are you a Visioneer Office Equipment and Supply Expert? Answer questions, earn points and help others
