Question about D-Link Wireless N 150 Home Router 4Port Switch 80211nbased 150Mbps DIR601
Can not connect to wan port via DHCP - D-Link Wireless N 150 Home Router 4Port Switch 80211nbased 150Mbps DIR601
  • D-Link Master
  • 7,733 Answers
How to configure router & switch
You shouldn't have to configure anything except the PC's should have IP and gateway set to auto.
Here is how it works:
A router connects two separate networks and manage the traffic between them.
In most home network applications the router connects your local group of computers and devices known as the LAN with the Internet, commonly called the WAN or Wide Area Network.
The router usually assigns unique Local IP addresses to all of the devices connected to it via a service known as DHCP. The addresses assigned by your router are private addresses http://en.wikipedia.org/wiki/Private_net... and are not routable across the Internet.
Dynamic Host Configuration Protocol (DHCP) is an auto configuration protocol used on IP networks. Computers that are connected to IP networks must be configured before they can communicate with other computers on the network. DHCP allows a computer to be configured automatically, eliminating the need for intervention by a network administrator. It also provides a central database for keeping track of computers that have been connected to the network. This prevents two computers from accidentally being configured with the same IP address. http://en.wikipedia.org/wiki/Dynamic_Hos...
Your cable or DSL modem will get a Public WAN IP address from your ISP's DHCP service. These public IP addresses are leased in blocks by your ISP and are Internet routeble. The modem is connected to the WAN port on your router. The router will manage the traffic between the devices on the LAN and the Internet.
If your 5 port switch is connected to one of the router's LAN ports and router's DHCP is on then it will configure the clients attached to It automatically.
Feb 04, 2013 | Computers & Internet
Im having an invalid ip address of 169
If your computer is not properly authenticated to your wireless router or if DHCP is turned off in the router an invalid address or (windows auto configure address of 169.x.x.x) may occur since windows can not find a DHCP server, it assigns its own default address space to your PC.
1. If your PC is connected via wireless make sure you input the correct wep / wpa or wpa2 password. 2. If your PC is connected via cable reboot the router and see if it gets a valid address. If it still doesn't, you may need to reset the router by pressing and holding the reset for min 5 seconds. You may have DHCP disabled which is causing this issue so resetting the router will re-enable that.
Do you have more then one PC connected to your network? Do they all get 169 addresses or just one? If just one has this issue then it could be the network card (try removing it from device manager and reboot the PC so it finds it again and reconfigures it) IF the PC is connected via cable, try another cable. Make sure the PC is connected to a LAN port not a WAN port.
If resetting the router and everything else does nothing, you may need to replace the router.
Chris
Sep 14, 2011 | Belkin (F5D7230-4) Router (587009)
We have an SBS2011 behind a Sonic TZ-100. A router with DHCP enabled is connected to WAN of TZ-100. We need to block DHCP in the TZ-100, as the SBS shuts down his DHCP when it finds the DHCP on the router....
So I can understand better... You are trying to move DHCP off of your Small Business Server and on to a router that is connected to your firewalls WAN? I don't understand why you are trying to block the connection between your router and your server. Once you turn off DHCP on your server and remove the static IP on it, it should get a new address from your router.
Best, -Mind
Aug 04, 2011 | SonicWALL TZ 100 0101SSC8734) Firewall
How do I connect a Dlink wireless router to a Netgear WiFi Internet adaptor?
Hi there is two way to connect best is to connect via cable ,DIR 615 login to router setting by typing 192.168.0.1 enter user name and password uaser name will be admin and password could be admin or blank or you need to enter text " read the manual to access the router via internet explorer" make sure WAN connection is DHCP connect LAN cable from your main router to the WAN port of your Dlink it should be ready in 1 miutes also if it support WDS you do not cable it can find the main router signal and connect to it and boost it , should you need any help please post me your question to http://computernetworksupportindubai.com/
Jul 22, 2011 | D-Link DIR-615 Wireless Router
How does the gateway2000 solo get the internet my son just buy this
what type of connection you have just try to connect the WAN port of Ethernet cable if u use this cable directly to connect your laptop to internet after that connect to router via wireless it will give you an option to configure the ssid and password for your WiFi follow instruction then you done u don't need to use CD for installation .other old method is to connect your computer to any port of linksys Router E2000 "not WAN " in the browser type 192.168.1.1 then enter put admin for both password and username go to setup make sure DHCP enabled WAN connection should be dHCP as well go to wireless choose manual then enter any name u like for your wireless go to security TAP under wireless then choose manual and the choose enable ,,,, encryption WPA2 enter any password you like save the configuration reboot the router make sure WAN port connected to your main internet it is ready to use should you need any help please contact me on my blog http://computernetworksupportindubai.com/
Jul 22, 2011 | Linksys WirelessN Gigabit InternetSharing...
I am trying to install a Netgear router after my switch. I end up having no internet on some of the computers connected to the hub and none on the router. If I configure the router as a dhcp client...
You'll want to configure your router as a dhcp server. Connect the switch to your router's lan port. Connect the remaining devices to a port on the switch. Your wireless access point should have it's dhcp server disabled. You can only have one dhcp server per network. The wireless can get it's address from the router's dhcp and the wireless client devices will get their ip address from the router, as well. If your wireless access point is a router with a wan/broadband port and some switch ports you will want to make sure that you are connecting to your Asus switch via one of the switch ports.
Be sure that your client devices are configured to get their ip address via dhcp and you should be surfing the interweb in no time flat.
Oct 21, 2010 | ASUS GX1008B 10100Mbps Desktop Unmanaged...
I have a WRT54G router and want to daisy chain a Linksys BEFSR41 switch off it, but I seem to be doing it wrong...
Not sure if you just want to expand the amont of computer you can connect to it or the wireless range but I would setup the BEFSR41:
  • Disable DHCP
  • Set an address out of the DHCP scope of the WRT54G
  • Connect them LAN to LAN if not use xover to connect them
Aug 27, 2010 | Linksys Wireless-G WRT54G Router
Dual Router Configuration
Plug the second router into the lan not the wan and it will act as a switch instead of a router
Oct 02, 2008 | D-Link DGL-4100 Router (DGL4100)
Internet connection
Connect a computer to one of the lan ports 1-4.
Connect the adsl modem to "internet" or "wan" port of hub.
Open the hub's configuration page in your browser, usually this is http://192.168.1.1 Under Setup->Basic Setup, set the configuration for "Internet Connection Type " to "Automatic Configuration - DHCP". Under Network Setup, enable the hub's internal DHCP server so your lan hosts can get their ip's from the hub. Each local computer should have DHCP enabled. Your adsl modem must support DHCP for this to work, some do not. If it still doesnt work, try setting "PPPoE" instead of DHCP.
May 14, 2008 | Linksys Wireless-G WRT54GL Router
DI-524 Wireless
Yes you can, it's easy.
1. Just connect one of the LAN ports of the DI-524 to a LAN port of your other router. Leave the DI-524 WAN port empty.
2. Disable the DHCP server on your DI-524, your other router will be the DHCP server.
3. Assign a static IP address to you DI-524, different from your other router's. Example, if your other router has 192.168.2.1, you may assign 192.168.2.4. Make sure that the IP address you assign is outside the DHCP range configured in your other router and that the subnet mask is identical on both.
Feb 20, 2008 | D-Link AirPlus DI-524 Wireless Router
D-Link Wireless N 150 Home Router 4Port Switch 80211nbased 150Mbps DIR601 Logo
162 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
