Question about Magellan SporTrak GPS Receiver
Want to use my magellann sport trac pro for geo caching - manual is lost- can enter Marks but don't know how to pull the 'mark' up again in order to find cache. any advice would be appreciated
    President:
  • 2,777 Answers
This was very difficult to find but I tracked down the manual for you. It is definitely best to have this manual and you can find the information in there. If you still have a question though please reply and I wills till help. Also if possible PLEASE rate my answer 4 thumbs up, it means a great deal to me. I would be forever grateful for this. Here is the manual:
http://www.magellangps.com/assets/manuals/SporTrak_series_en.pdf
Posted on Oct 12, 2010
I have a 2005 ford sport trac ,I just put a used sohc 4.0 in its real hard to start and has no power,so much white smoke is coming out that u cant c also raw gas is pouring out of exh manifold
it is a fuel problem and may be that the injectors are not sealing off in the manifold allowing fuel under pressure to bypass the seals to get straight to the pistons
really hard to start could be a valve timing issue but that can be check by looking at the timing marks when no1 is at tdc
white exhaust is an indicator of a water problem so check with a compression test and a coolant pressure test
Feb 16, 2017 | 2005 Ford Explorer Sport Trac
Which one is number one on the distributor
i know the firing order for my 1991 geo storm is 1-3-4-2 but where ...
https://answers.yahoo.com/question/index?qid=20100724161217AAxsz6L
  1. Cached
  2. Similar
Jul 24, 2010 - I know the firing order for my 1991 geo storm is 1-3-4-2 but where on the distributor does it start? ... the guy told me that i had the firing order wrong and now my car keeps cutting out when i go to ... Holey Mufflers · 6 years ago.
Geo Tracker Plug Firing Order - My Geo Tracker
www.rlb.50megs.com/trkfiringorder.html
  1. Cached
  2. Similar
FIRING ORDER. Notice the rotation of the distributors for each engine type. Why they are different is odd itself. . . The blackened areas designate the the numner ...
Firing Order - Geo Metro Forum
geometroforum.com > Geo Metro Forum > Metro Tech > Engine Tech & Diagnostics
  1. Cached
  2. Similar
May 3, 2010 - 15 posts - ‎2 authors I looked up on the internet the firing order 1-3-2 counter clockwise but no ... the best explanation of both types of timing I know of starting about posts #6 ... Location: College Park, MD; Year/Make/Model: 1991 Pontiac Firefly ... 91 geo storm1 6 firing order Google Search
Nov 18, 2016 | Cars & Trucks
Ichanged the head on my 91 geo storm 1.6 dohc and now it won't start
Double check crankshaft timing mark, on your lower timing cover has some timing marks - crankshaft should be on the 0 mark. Camshaft timing marks--intake camshaft mark set at 3 o'clock and exhaust camshaft mark set a 9 o'clock. These timing marks are critical for motor to run and start correctly. These timings marks can move while trying to install the timing belt. After, you confirm or reset timing and belt, you can confirm timing is correct by rotating the crankshaft twice. Your timing marks should be on right on timing marks discussed at the top of the page. If timing marks are off, start over with timing process.
Jul 11, 2012 | 1990 Geo Storm
Timing belt replacement. what are the mark settings on the pulleys?
If you dont know the marks on an engine when replacing the timing belt. There are usually marks on the pulleys and housings to line up. Put the engine on top dead centre TDC from the crankshaft marks before looking for the other marks. If you cant find them Use white out to place your own marks on the pulleys and housings before removing the old belt . To be sure nothing gets out of line mark any pulley that has teeth. It can be useful to take a few digital photos . When fitting the new belt make sure your marks line up again.
Mar 03, 2011 | 1992 Geo Storm
The bike goes to Pause mode frequently throughout the workout. I have tested all the exercise modes and made sure my RPMs stay the same but it just flips to pause and then starts working again...
Star Trac Pro Upright Bike Owner's Manual - ManualsLib
www.manualslib.com > ... > Exercise Bike > Pro Upright Bike
Exercise Bike Star Trac Upright Sport Bike Owner's Manual. Stationary sport bike (28 pages) ... Pro Upright Bike Pro Recumbent Bike ' W N E R A N U A L..
Jan 20, 2011 | Star Trac Sport Recumbent Exercise Bike
I need to know witch tining marks do i line up with the timing mark on a 95 tracker the I or E on the cam shaft
Click on the following free, direct Link. It has the Timing + Marks: Belt Diagrams, including for your 1995 Geo Tacker, 1.6L SOHC 4-Cylinder.
Let me know if this helped, or if you have additional information or questions. Feel Free to contact me at FixYa.com!
http://www.2carpros.com/car_repair_information/year/1995/make/geo/model/tracker/1995_geo_tracker_timing_belt_diagram_marks.htm
Apr 19, 2010 | 1995 Geo Tracker
I timed the cams just as haynes said and the cam timing isnt rite theres no compression i need to view the timming marks
Yeah, just pull the covers off again to view the marks to find out what happened. Then pull a couple spark plugs so you can spin the engine by hand. Get it to come around clockwise to one mark, then check the rest, then do it again. Put the tensioner pin back in before removing the belt. When that tensioner lets go, the belt should not move a fraction, it should stay right where it is, on the marks..spin her around again and see where it lands, I wouldn't cover it up till I was sure. I had some idiot do my belt once, (since then I've done it myself), the car went 11 miles and the cam shattered in 3 pieces!!! I couldn't believe it, he took no responsibility for it. I said, Pete! You didn't work on the brakes, you moron!!! Good luck.
Feb 26, 2010 | 1991 Geo Prizm
Geo metro timing
how to put the timing chain back on the engin. what i need too know is how too set the point up?
Jun 07, 2008 | 1992 Geo Metro
Magellan SporTrak GPS Receiver Logo
212 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
