Question about Kitchen Ranges
Hi I have a Kenmore coldspot MOD 106 61982100 built in 2001. What is the capacity for fresh food and the capacity for the freezer? Thank you
  • lacbrome Oct 13, 2010
    This is the information I have:
    Kenmore Coldspot
    Mod. 106 61982100
    Ser. EL4011527
    President:
  • Kitchen Ranges Master
  • 1,932 Answers
I need the manufactures model number .It looks like this Mfr. model 58943 and the full capacity of the refrigerator
Thank You
Posted on Oct 12, 2010
  • Udhaya Rajan
    Udhaya Rajan Oct 13, 2010
    Here is the specification of your Kenmore model refrigerator
    Capacity
    • Freezer Section: 4.9 cu. ft.
    • Refrigerator Section: 13.8 cu. Ft
    • Overall: 18.8 cu. ft
    Thank You
Kenmore coldspot refrigerator repair
20b285e5-2f39-4d20-a743-32f4ef00196e.jpgKenmore uses a model number like this example=> 321.2468901 and can be found around the fresh food section door frame. Let me know that number so I can look over the parts so I can help you solve this, Thanks Sea Breeze
May 09, 2013 | Kenmore Refrigerators
I have a 2001 Kenmore Coldspot that is having temperature issues. The freezer is fine but the fridge will not get below about 55 degrees. I have defrosted it already and also checked the air flow as...
Is the fan motor blowing from below? Does this model have a damper that opens and closes to allow freezer air into the fresh food compartment? Is the condenser area and kickplate clear of dust and lint?
May 18, 2011 | Refrigerators
I suspect my Kenmore Coldspot refrigerator is using too much electricity. It was built in 2001. Does that year indicate it might be inefficient?
These are the things that makes a frig inefficient.
Dirty condenser coil
not an energy saver model
temp. in freezer only 20 degrees instead of zero
lost of freon
too much food in the freezer blocking air vents
thermostat set too high
bad doors gaskets
frig. located in area that is extremely hot all the time
these are possiblities so see if you can use this as a guide.. if none fit your problem let us know... thank you
Mar 28, 2010 | Refrigerators
Kenmore coldspot side by side refrigerator - freezer fine. other
Good to see you put your model number down correctly. Do the lights come on inside when you open door? I noticed your refrigerator has a control board inside the fresh food section behind the control panel I want you to unplug the refrigerator and examine that board for burn marks or loose solder connections on both Sides. Then let me know what you find. Thanks, Sea breeze My email is appliancepsrtsse@yahoo.com Web Site http://servicepartstec.blogspot.com/ Part Number for Control board is 8201528
Jun 10, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Where is timer located
Should be in the control area inside the fresh food section.
Phil
Apr 15, 2009 | Refrigerators
Kenmore coldspot top freezer auto ice maker, water
Dear customer,
               We suggest u to perform the following checks to solve ur problem...
  1. Check the refrigerator for level
  2. Check the ice maker for level
  3. Inspect the fill cup alignment
  4. Inspect the water supply line
  5. Test the water inlet switch
  6. Test the water inlet valve
  7. Check the shutoff arm
  8. Test the shutoff switch
thank you..
Apr 08, 2009 | Kenmore Refrigerators
Kenmore Coldspot 106.9552610 not cold enough
Inside the fresh food compartment look for an opening that will allow you to turn the defrost timer clockwise slowly. When you hear it click the refrigerator should go into defrost. If the timer is bad it will need replaced. Let me know. Below is a photo of timer.
Part number 6
Feb 27, 2009 | Kenmore Refrigerators
Fresh food section not maintaining cold temp
You're frozen up.  Defrost completely.  Then, clean your condenser.  Make sure to never leave open containers in the fridge...water condenses into ice.  If you still have problems, you may be low on gas.
Nov 15, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kitchen Ranges Logo
460 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
