Question about Nikon D70s Digital Camera
I bought a second hand d70s. it seems to have a problem. the shutter release button does not seem to do anything when pressed half way (like auto focus). I can only get autofocus to work if i program AE-L/AF-L button to AF-ON. I press the AE-L/AF-L button on the back, then press the shutter to take the shot. And if i set the AE Lock On, pressing the shutter button half way does not lock the exposure setting. so there seems to be an issue with the shutter button itself...is there an easy fix? thanks.
    Brigadier General:
  • 11,967 Answers
You need to press the button half-way first to allow an exposure reading to lock on to.
Posted on Oct 12, 2010
I bought a second hand Mamiya 645 Af but as soon as I load a film it shows a error message ERR 01 .... what is that ?
From the manual:
"If the error display is not canceled when the shutter release button is pressed again, insert the Dark slide, half-press the shutter release button while pressing the roll film holder's manual film advance button to wind up the film, then contact your nearest Mamiya agent or service center."
If you need a manual, you can download one from
http://butkus.org/chinon/mamiya/mamiya_645af/mamiya_645af.htm
Aug 04, 2011 | Mamiya 645AF Medium Format Camera
Static subject, but 15-20 second delay after pressing shutter button before photo is taken. Manuel mode, autofocus lens. I have 7 other d70s that all perform fine.
have you contacted Nikon about this issue, they stand behid their products and since you have bought so many of these it seems to me that they will listen to you. Have you tried the camera in "auto" mode just to see if the problem is there too?
Mar 18, 2011 | Nikon D70s Digital Camera
My camera will not focus and take a picture.. I am receiving a r07 on the top screen and nothing seems to be helping. Any suggestions?
"rXX" is the cameras estimate of how many shots legt on your memory card. As for other issue: Turn camera "ON" and remove battery while holding shutter button for about 30 seconds. Turn off, reinsert battery, turn "ON" then press hardware reset button on bottom of camera for about 2 seconds. Page 200 in Nikon d70 (do not know about d70s) manual.
Feb 16, 2011 | Nikon D70s Digital Camera
Shutter release is slow, I press the shutter release and the camera doesn't take the photograph for a second or second and a half. I'm in auto or sports settings
To get it to instantly take the picture, you must press the button half-way and allow the camera to lock in the focus (it will beep)...then when the moment is right, press the rest of the way.
Oct 29, 2010 | Konica Minolta DiMAGE Z20 Digital Camera
Shutter speed on the auto mode of my s1000 camera seems slow. how can it be increased in the auto mode? This is a Fuji camera and by the time I press the shutter button subjects have moved. I have set the...
You need to press the shutter button half-way and allow the camera to lock in the focus before you press the rest of the way. This eliminates "shutter lag".
Dec 30, 2009 | Fuji FinePix S1000FD Digital Camera
My nikon d70 wont focus at all
  • Make sure both lens and body are set for autofocus. There are two switches near each other with "AF" and "M" settings.
  • Check the camera's focusing settings, or do a factory reset (from menu) to 'start over'. Usually helps to have AF-Assist on.
  • Try setting the AE/AF-lock button (upper rear, near right thumb when holding camera) to turn on AF. The camera may respond better to this than half-pressing the shutter release.
  • Make sure the lens is fully attached to the camera. You shouldn't be able to rotate the lens without depressing the lens release button, and you should be able see a tight seal between the two.
Jun 23, 2009 | Nikon D70s Digital Camera
How can I point and shoot with my Fuji Finepix S1000fd? I press the shutter button and it goes through all sorts of focasing, Etc. What if I want a candid shot and want what is going on when I press the...
Be sure you are on auto. Pressing the shutter release down half way causes the camera to focus. This needs to happen to get a clear picture. Be sure you have adequite light or the auto focus will not work. You might need to set your flash to auto as well . Them by pressing the shutter release the rest of the way down, you will get a picture. But gain, you need to allow it to focus first, then take the photo.
Mar 08, 2009 | Fuji FinePix S1000FD Digital Camera
In auto focus mode the lese seems to "hunt" and won't focus
When this happens with my D70s, I know of two options. 1) use manual focus or 2) autofocus on another object about the same distance away from my subject (holding the shutter release half way) and then move the camera back to my subject composition. This seems to happen when there is little contrast in the scene, i.e., a field of same colored flowers. Hope this helps.
Dec 29, 2008 | Nikon D70s Digital Camera
Shutter won't close on Nikon D70s
Format the card. I have same problem with mine ---requires a new shutter assembly.$40.00 item and they want $300.00 to fix it at Henry`s cameras. Ouch .Better to buy a new camera.
Nov 19, 2006 | Nikon D70s Digital Camera
No picture is taken when shutter release button is pressed
Are those NiMH batteries? Have you tried resetting the camera? If no standard way, just take out batteries for a few minutes, the more the merrier, let the tension build, and replace them. Try tapping on the lens area, it might loose something up. Best I can do, know it aint much ;] Good luck!
Jun 01, 2006 | Nikon COOLPIX Cameras
Nikon D70s Digital Camera Logo
197 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
