Question about ASUS M2NPV-VM Motherboard
Video adaptor giving beep code on post Asus M/B M2NPV-VM 1 long then 2 short beeps also has a usb over current issue at post but has no usb pluged in. please help me decifer this. thanks in advance troy
This is a fix that worked for me, however I cannot tell you why or even feel that I had done anything which would constitue this as a fix. I leave my PC on 24-7 and came in one morning and it was locked up. Couldn't get a video screen, not even reset worked so I threw the power switch on the back of the power supply. Turned the switch back on and pushed the power up button. The MoBo started 1 long and 2 short beeps, repeating. I pushed the reset button and same thing. I again turned the power supply off, then on again and same thing with the beeps. So this time I turned the power supply off then also un-plugged the power cord to the power supply. I left it that way for maybe 10 minutes, while I did a few other things. I plugged the power cord back in, turned the power supply back on and hit the power up button. My PC booted up...no problem. ???
Point is - this issue as reported by others may just be a hardware or bios fluke and needs a power reset or maybe even clearing the bios and restarting. Reseating the memory sticks, use just one memory stick and rotate the memory sticks to sort out the possible bad one and reseating the processor may also help.
Posted on Jan 25, 2011
Won't post
if your computer wont boot and is not giving the post noise
one bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps
don
Mar 06, 2011 | ASUS P4S800-MX Motherboard
When i tune on the computer it gives me one long and two short beeps,and the monator is black.
the beeping sound is the post system searching for your hard drive and other connected devices
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
good luck
also make sure your RAM has a secure seating
Oct 03, 2010 | ASUS M2NPV-VM Motherboard
Onboard video card not working. New card not either
please check Ram bcz its ram beep sound may be ram not attached in proper way that why sound come or may be its damaged
May 10, 2010 | ASUS M2NPV-VM Motherboard
How to disable onboard display adapter without accessing BIOS?
Disable the motherboard device in the Device manager
Mar 27, 2010 | ASUS M2NPV-VM Motherboard
P5RD2-VM mobo will not post at boot
Three beeps for that bios is a memory error.Are you sure it's not a memory issue? Did you clear the CMOS and try to boot up again?
Dec 10, 2008 | ASUS P5RD2-VM Motherboard
I have an Asus p4s533-mx motherboard which boots and runs fine (sometimes). But when I perform a warm boot, it often won't pass POST. The beep code is one long and two short. If I power it down and let it...
The response from ASUS tech support - It's a standard Award BIOS, so they're the standard beep codes.
So I wrote the following on page 3-4 of my user guide:
1 long + 2 short = Video adaptor error
1 long + 3 short = No video card or bad video RAM
high freq beeps while running = Overheated cpu
repeating high/low = cpu problem
repeating (endless loop) = memory error
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Sep 29, 2008 | Computers & Internet
M2a-vm mother board
Hi auriaskate,
Currently you are using the onboard PCI video adapter. This graphics adapter uses you're system memory to function.
If there is a problem with you're system memory the beeps can lead one to think there is a problem with the onboard video.
You can not remove the onboard adapter so there may be a problem with you're system memory. (I doupt you're memory is bad) but on the other hand it might not be fully installed correctely. Power off the PC & unplug the power cord from the PC.
Please remove you're system memory & firmly reseat it.
Plug the power cord back in. Start the PC & listen for any beeps except the 1 normal beep known as P.O.S.T = Power on self test. Any beeps after that there is a problem with a device connected to the board.
You're Asus M2A-VM uses an Award bios. Click on the link below to see what Award beeps mean.
http://www.bioscentral.com/beepcodes/awardbeep.htm
Try the memory reseat & check. Let me know if this helped.
Mike
May 03, 2008 | ASUS M2A-VM (0610839149438) Motherboard
Video adapter error in boot - 1 long+2 short beeps
For memory go to pg. 1-14 section 1.7.2, after going over these configurations go to pg. 1-15 & check your current memory against the QVL list. In regards to the NVIDIA 6150 GPU lets check the device manager & see if there is a problem. At display adapters do you see a red X or a yellow ! point? If red X the NVIDIA controller is most likely defective. If a ! point, right click & uninstall device. Before you restart the PC reinstall the chipset drivers from the Asus CD. If the problem failed to resolve you'll have to contact Asus tech EST at 812-282-2787. The tech will run you trough a quick check to be sure the controller is defective & will than give you a case number for a RMA. You'll have to ask to be transfered to the RMA dept to save you from another call. To test your memory 1 dimm at a time download this program for free CrystalMark 0.9.123.404b & check your memory.: http://www.warp2search.net/crystalmark-2004r2-0-9-123-404b-s36517.html
I hope all goes well!
please vote.....
Jan 20, 2008 | ASUS M2NPV-VM Motherboard
Hp pavilion dx8210us notebook
Check the ram on board, reseat it and try again. Sounds like a memory problem to me.
Dec 21, 2007 | ASUS M2NPV-VM Motherboard
Boot error / No video out
Ajit,
The beeps are usually due to RAM or key board issues.
I would try by plugging it into a VGA socket of a monitor to see if it works.
Do you have heat problems? one suggestion is to try and reset the bios to default by moving the jumper on the mobo to do a hard reset.
good luck
Smeags.
Oct 23, 2007 | ASUS M2NPV-VM Motherboard
ASUS M2NPV-VM Motherboard Logo
294 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
