Question about Pentax Optio E60 Digital Camera
Shows lens error 0x02110000 - Pentax Optio E60 Digital Camera
    Guru:
  • 377 Answers
You kind of need to contact the company. they might have a kind of website or kind of phone help
Posted on Oct 12, 2010
  • camel99 Jan 22, 2011
    I have just discovered that if you manhandle it a bit by pushing the outer ring in so it clicks and goes skew, and then pulling it out again to straighten it seems to loosen the mechanism. I know this sounds dodgy but it worked for me....It is a mechanical problem and not a software issue.
    Aaron Cass
Epson 092-651-0x02110000 error
Did you ever sort it cos I have the same error
Jan 16, 2014 | Epson Office Equipment & Supplies
When turned on, my VPC S1070 shows
This blog explains the problem you're having, and things you can try to fix it.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
They say about half the cameras can be fixed, trying their suggestions. Good luck, hope you're in the "fixed" half!
Jun 10, 2010 | Sanyo Vpc-s1070w Digital Camera
When i turn it on it has 0x02110000 error messages and turns off
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
May 13, 2010 | Pentax Optio E60 Digital Camera
I turn on the camera and it saysprogram green mode for a while and then it shuts down saying lens error 0x02110000 although im not sure how many 0's there are on the end of the 0x0211
Dear Sir,
This is problem of the lens block.You are not able to solve this issue by your self.You must send thi camera into the local Pentax Service.
Best Regards
AIOS
Apr 18, 2010 | Pentax Optio E60 Digital Camera
Dear Sir,
You must send camera into the Pentax service.
Best Regards
AIOS
Mar 23, 2010 | Pentax Optio E60 Digital Camera
When you turn camera on it says lens error 0X02110000
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 16, 2010 | Pentax Optio E60 Digital Camera
Camera says lens error:0x02110000
Hello
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
Regards
Andrea
Jan 09, 2010 | Sanyo Vpc-s1070w Digital Camera
Error 0x02110000
If you have recently dropped the camera you may have damaged the lens tube (housing). This damage will prevent the lens from moving properly and will cause the camera to shut itself off after a few seconds. If the lens is damaged the camera will require professional repair. If the lens is not damaged, the problem may be battery related. Make sure that you have the correct battery type installed, and that the batteries are fresh/fully charged. If the problem persists, you may have corrosion on the battery contacts inside that camera that is preventing full battery power from flowing to the camera. Remove the batteries and wipe the inside camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sand paper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and reinstall them in the camera. This cleaning solves the problem about 90% of the time, and I hope it works for you.
Sep 12, 2009 | Pentax Optio E60 Digital Camera
Lens error 0x02110000
This is a common problem with with cameras with retractable zoom lens .
Heres a few thing you should try :
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install the new batteries, when you turn it on it should come back to life. If you get another type of error message this may mean you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one). TO AVOID THIS PROBLEM AGAIN : Keep away from dust, dirt, grit, sand and any camera bag that has loose fibres (clean it before use).
If this helps you, please vote...thankyou and good luck!
Jul 28, 2009 | Pentax Optio E60 Digital Camera
When i try to open my camera it says lens error :0x02110000
This seems to happen when something (water, sand, dust) gets trapped in the lens mechanism. Has the camera been somewhere filthy before?
The recommended methods include taping on the bottom of the camera, rapping it on a table, and pressing hard on the lens. If the lens moves when you turn the camera on, try keeping your hand on it so that it's forced back into the camera body. A can of compressed air squirted around the lens is also a possible fix... but be super careful with that stuff, a good hard blow of breath might be safer.
I'm not recommending that you do crazy stuff to your camera, but if you're careful you may be able to get it working again without having to get it serviced.
Jul 06, 2009 | Sanyo Vpc-s1070w Digital Camera
Pentax Optio E60 Digital Camera Logo
153 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
