Question about Troy Garden
How do I remove old gasoline out of my Troy Bilt snow blower without tipping it over to the side? Is there a cap to remove to drain the fuel underneath the gas tank?
4 Suggested Answers
#1 Taper
  • 1040 Answers
SOURCE: Can't find the oil drain plug on Troy Bilt with 5.5 Honda engine
You may want to look under the deck. They sometimes put them there. And if it is a self propelled, you will probably need to remove or loosen the plastic cover that protects the self propelled belt.
You are looking for a nickel sized plug that has a square peg. Use an extension piece for a socket set if you don't have the proper plug removal tool.
Jim
Posted on Jun 21, 2009
  • 430 Answers
SOURCE: Hello, I have a Troy Bilt 2410 SnowBlower that
If memory serves me your unit is a 4-stroke and the motor is very well hidden by covers. There probably is not a fuel shut off valve on that unit from the factory, and there is no drain plug on the tank. To drain the tank, pinch the fuel line off between the tank and carb with some kind of locking pliers/ vice grips, then remove the fuel ilne from the carb and place that end of the line in a container and remove the pliers to let the fuel flow. Also, spray a prime directly into the throat of the carb with the choke open. Snow throwers do not have air filters since the only thing they would catch is water ( theoretically).
You should be able to spray the prime to diagnose without too much hassle but to perform any service on the unit you will have to remove all covers and gaurds. Take your time the first time and its not as bad as it looks, after the first time its a breeeze. Some units have a little 90 degree extension coming off the muffler that prevents the removal of one of the covers, with the right sized 1/4 drive socket on an extension you can reach up and loosen the pinch bolt and remove the extension which makes the job a whole lot easier.
Good luck, hope that helped
Posted on Dec 10, 2009
  • 108 Answers
SOURCE: My Troy-bilt Storm 7524 snow blower goes off after 10min running
it sounds like it may be you armeture[coil], it heats up and stops.
Posted on Dec 22, 2009
Troy Bilt 3090 snowblower surges off choke, doesnt surge on choke, cleaned the carb, jets, float, drained tank, cleaned fuel filter, fresh gas, still surges. Could it be the governor or idle jet?l
you could try opening up the idle/mixture screw another turn to make the transmission from idle to throttle better
governors just open the throttle butterfly according to the spring tension setting from the throttle lever
Dec 16, 2016 | Troy-Bilt Storm 2840 277cc 28-in Two-Stage...
Electric start on Troy Bilt 21" single stage snow blower doesn't work. Recoil starter does. Electric start worked last year, but today, nothing. All cords good, power, etc.
The starter could be bad. Remove starter and see if it will turn over when 120v is applied.Check the wires to starter first! Good-Day!
Nov 16, 2014 | Troy-Bilt Squall 2100 208 cc 21-in...
My Troy bilt squall 2100 snowblower does not idle steady. It races and slows while idling.
It sounds like the carb needs cleaning and readjusting, or the fuel filter is clogged. Good-Day! Remove and clean out carb, it may be dirty inside.
Nov 13, 2014 | Troy-Bilt Squall 2100 208 cc 21-in...
How do I drain the oil from my Troy bilt 2100 squall snow blower so I can change the oil?
You need to remove the lower panel to access the engine. In the engine blow-out, the oil drain plug is numbered 77 (bottom of the crank case).
25256884-5livr0uqynklw3svefpqfefw-2-0.png 25256884-5livr0uqynklw3svefpqfefw-2-2.png
Oct 26, 2014 | Troy-Bilt Squall 2100 208 cc 21-in...
How do you do a oil change on troy bilt bronco
Look for a plastic cap with two bumps on it near the bottom of the engine (or a pipe about 4" long with a pipe cap on the end). Open the cap and tip the machine to drain the oil. Set the blower upright and refill with 3/4 quart of oil (24 oz). Check level, add more until the dipstick says it is correct. Usually about 32 oz.
May 28, 2014 | Troy-Bilt 179cc 24-in Two-Stage Gas Snow...
Troy bilt fix
check drive belt
tip it on its nose, ( be sure gas is only 1/2 full or less)
remove plate on the bottom
see if wheel is close to the alum plate
sqeeze handle see if wheel contacts plate
if not adjust cable under handle
Mar 31, 2014 | Troy-Bilt 179cc 24-in Two-Stage Gas Snow...
Last year I purchased a Troy Bilt snow blower . I used it one time after using it I drained the gas out of it. Just recently I got it out and was checking it out because they were talking about snow so it...
Cecil,
I am curious why this repair was not covered under the warranty? This snow blower has a 2 year warranty from the manufacture.
Two things for you.
First, there has always been the "what came first, the chicken or the egg" issue over leaving fuel or draining the fuel from you snow blower. Half the experts say drain it, and the other half say leave it in.
Secondly, all of the current Cub Cadet, Craftsman, Troy-Bilt, Yard Machine, and Yardman snow blowers with the Powermore engine need to be treated differently than the old Techumseh or Briggs side-valve that you were used to.
The issue with your Powermore engine is actually today's ethanol fuel. If you leave the ethanol blends in your tank without a fuel stabilizer the alcohol separates from the gas. This alcohol then rises to the top of the tank and gets into the fuel lines. The fuel lines actually will soften. (I've seen the primer bulb actually melt on a few units)
If you drain the tank and run it dry the remaining fuel will "varnish" and/or dry out the carb.
I know a service manager that repairs a lot of these Powermore motors. Instead of replacing the carb, his techs actually take the carb off, soak it overnight in carb cleaner and then reinstall it. This is so common that he keeps a few clean carbs on the shelf and then just switches them out when a customer has a problem.
So how do you keep from getting those high repair bills? First, use fuel stabilizer ALL THE TIME! Mix Sta-Bil, Sea Foam, or Craftsman Fuel Stabilizer according to the directions on the bottle. Secondly, try not to use ethanol blended fuel. Especially try to fill the tank the last time you use it in the spring with non blended fuel. Third, When you put your snowblower away, fill it with stabilized fuel, start the motor and run it until warm. Then "fog" the carb with SeaFoam spray until it loads up and quits running. Put it away for the season. (If you don't know how to fog go to SeaFoam's website and read about doing this with the spray)
It will start next fall.
Feel free to ask me any other questions about your snow blower. Don't forget to rate this answer and you are welcome to leave a comment about it.
Jan 11, 2011 | Garden
I have a troy-bilt squall 2100 snowblower that wont start. Primer bulb doesnt seem to do anything. Use of starting fliud in the air intake will get it to start briefly. Removed carb bowl and there seems...
I share your frustration. We just had our first snow fall of the season and my Troy Bilt Squall 2100 would not start or do anything. The snow blower is well maintained and does not have 2 hours use. I use 0-30 synthetic oil and installed fresh gasoline. It is simply maddening to have plunked down close to $500.00 and have a useless snow blower. Trying to get through to Troy Bilt's help line is next to impossible.
Nov 21, 2010 | Honda Garden
My Troy Bilt Self Prop. Z-start won't keep running. I clean All, replace Filter and Plug, have clean gas and lubed all. It Starts for 2 seconds and then cuts off. What do you think it could be? Thanks....
I had the same problem, Tilt the lawnmower on it's side air filter facing up and remove air filter cover and air filter then remove the fuel bowl underneath the carb; then clean the fuel bowl with some gas and a clean rag. For the next step be sure to aim blower tip at target then look away before pressing trigger, this will prevent gasoline form getting into your eyes.Take an air compressor and carefully clean out the carb where the flap is and the tube where the fuel float that would rest inside fuel bowl is. Leave on side install everything back except for air filter and cover. Then pour a little gas in the carb to prime it, lay the lawnmower back on all 4 wheels and try to start.
Aug 02, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
423 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
