Question about Asko 24 in. D3250 Built-in Dishwasher
Door Latch will not cycle to unlatched position thus door will not properly close. I have run the dishwasher through different cycles however the latch, which is located in the opening at the top of the door, still refuses to open.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Sorry, but I don't have good news for you, unfortunately it is time to replace the door latch, hope you understand there is nothing else that you can do with the latch as every other part is working fine. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Oct 12, 2010
Less that 2 yrs old..door wont latch. As a consequence machine won't start.
It is possible the door latch is faulty or the springs at base of dishwasher are soft and need adjusting. the springs keep the door in position. refer this site for parts.
Dec 31, 2012 | KitchenAid KUDS30IXBL Builtin Dishwasher
PDW8100 Dishwasher went through cycle several times, but I am unable to open the door. Is there a way to get it open? Thanks, Barbara
When your dishwasher door has a problem, check these:
Latch
Springs
Hinges
Door seal
Latch The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem.
If the latch has worn out in a way that makes it impossible for you to close the door properly, you probably need to replace the latch.
Springs Your dishwasher has two springs that counterbalance the weight of the door. If either or both of these are broken, the door feels quite heavy and you need to replace both springs.
Hinges The hinges are important to the door closing properly. If they're bent or deformed, you probably need to replace them. Once bent, only rarely can they be straightened well enough.
Door seal If your dishwasher is new--or if you have just replaced a door seal--the door may be difficult to latch for a week or two. If the tightness persists, though, try adjusting the latch, if it's adjustable. If it's not adjustable, there's probably nothing you can do immediately. But try running the dishwasher on the highest heat cycle to help the seal conform to the door. Otherwise, the seal should compress over time.
Goodluck..
Jun 07, 2008 | GE Dishwashers
NO ON OFF SWITCH
Hello Heather, I know It is weird they don't have a on and off switch, but when the cycle is done it turns off. Turn it on by starting the cycle. You can stop the cycle by unlatching the latch when it is running. So like if you need it quiet, just open up the dishwasher door a little bit, it will stop. Close the door and it will finish washing.
Nov 14, 2012 | Dishwashers
My dishwasher door wont shut
see this causes, and use the common sense. God bless you
When your dishwasher door has a problem, check these: Latch Springs Hinges Door seal Latch The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem. If the latch has worn out in a way that makes it impossible for you to close the door properly, you probably need to replace the latch. Springs Your dishwasher has two springs that counterbalance the weight of the door. If either or both of these are broken, the door feels quite heavy and you need to replace both springs. Hinges The hinges are important to the door closing properly. If they're bent or deformed, you probably need to replace them. Once bent, only rarely can they be straightened well enough. Door seal If your dishwasher is new--or if you have just replaced a door seal--the door may be difficult to latch for a week or two. If the tightness persists, though, try adjusting the latch, if it's adjustable. If it's not adjustable, there's probably nothing you can do immediately. But try running the dishwasher on the highest heat cycle to help the seal conform to the door. Otherwise, the seal should compress over time.
Sep 19, 2012 | Hotpoint 24 in. FDW60 Free-standing...
The door wont shut properly
see this causes and use the common sense.God bless you
The door won't close completely
Hi, Check for the following whenever you have problems in door
Latch: The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem. If the latch has worn out in a way that makes it impossible for you to close the door properly, you probably need to replace the latch.
Apr 12, 2010 | Frigidaire Professional Series 24 in....
The door will not close. It appears that the lock is in the closed position and will not allow the catch to close fully and engage. The m/c is mid cycle so I have switched off at the main socket
Check for obstructions, Check the door latch the latch may have moved into its housing,use a screw and position the door latch properly free from any obstruction,then try closing the door again..if not then you may need to replace the door.hope this helps pls do let meknow
Apr 05, 2010 | Neff Dishwashers
Unable to turn off the delay start and the latch is in the wrong position so that the door will not close properly. Also, there is no digital display--it remains dark. I tried the cancel/drain, which...
Pull the open handle to open the latch up and try to get it to close. Disconnect the power to the machine for a few minutes. Run a cycle that you don't usually run. See if that helps.
Nov 02, 2009 | Bosch 24 in. SHV66A03 Built-in Dishwasher
The door on the dishwasher squeaks terribly. How can this be corrected?
If your dishwasher door squeaks you have to check the following:
Latch
Springs
Hinges
Door seal
If your dishwasher is new or if you have just replaced a door seal the door may be difficult to latch for a week or two. If the tightness persists, though, try adjusting the latch, if it's adjustable. If it's not adjustable, there's probably nothing you can do immediately. But try running the dishwasher on the highest heat cycle to help the seal conform to the door. Otherwise, the seal should compress over time.
Sep 10, 2009 | KitchenAid Dishwashers
Door won't close wont lock closed
Check the following if you have problem with your doors:
1)The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem.
2)Your dishwasher has two springs that counterbalance the weight of the door. If either or both of these are broken, the door feels quite heavy and you need to replace both springs.
3)The hinges are important to the door closing properly. If they're bent or deformed, you probably need to replace them. Once bent, only rarely can they be straightened well enough.
4)If your dishwasher is new or if you have just replaced a door seal the door may be difficult to latch for a week or two. If the tightness persists, though, try adjusting the latch, if it's adjustable. If it's not adjustable, there's probably nothing you can do immediately. But try running the dishwasher on the highest heat cycle to help the seal conform to the door. Otherwise, the seal should compress over time.
Sep 03, 2009 | Westinghouse Dishwashers
Asko 24 in. D3250 Built-in Dishwasher Logo
163 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
