Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Doess not open
I can hear the motor runnnig but it's not pulling the chain to open the door.
Doe this means that I need a new unit or is there something I can fix myself?
Motor needs a gear kit ,cost approx, $40-$50-dollars
Posted on Jun 11, 2008
Electric motor hums but does not open or close garage door
If it just hums and not actually run. Then the trolley is jammed against one of the stop bolts.
Mar 26, 2014 | Building Materials
Craftsman 3/4 chain drive will not open, when pressing wall switch I hear click at the unit and the programming light will flash, but it doesn't open the door, or close for that matter the motor...
The unit is for sure repairable. You should remove the cover from the motor unit and check the drive gear. It is a white nylon gear just in front of the motor and it will be obvious if it is bad. If you have had electrical storms it may have gotten to your logic board. You need to pull it and check for burnt or missing traces on the printed circuit.
Aug 09, 2011 | Sears Craftsman LiftMaster Chamberlain...
Garage door opened fine but now when I try to close it, all I hear is a buzzing sound for 3 sec., light comes on but door won't go down.
Your trolley may be jammed against the bolt just in front of the motor unit. If so, loosen the chain enough to relieve the strain on the chain and then run the opener until the door is closed. While the door is closed locate the 'up limit' control on the side of the motor unit. Turn this control 2 full turns in the opposite direction of the arrow printed on the cover. Tighten the chain.
Jul 18, 2011 | Sears Craftsman LiftMaster Chamberlain...
Unit has power, went up, won't go down. Pushed re set, still nothing. Can hear unit try to engage but will not operate
Check to see if the trolley is jammed against the bolt just in front of the motor housing. If it is you need to loosen the chain enough to release the tension and then run the opener until the door is closed.While the door is closed, locate the 'up limit' control on the side of the motor unit. Turn this 2 complete turns in the opposite direction of the arrow printed on the cover. Tighten the chain.
Apr 01, 2011 | Sears Craftsman LiftMaster Chamberlain...
I press the button to close the door and i hear a click at the motor and nothing happens
Check to see if the trolley is jammed against the bolt just in front of the motor unit. If so, loosen the chain enough to take the strain off the chain and run the motor until the door is closed. While the door is closed locate the 'up limit' control on the side of the motor unit. Turn this 2 full turns in the opposite direction of the arrow printed on the cover. Tighten the chain.
Nov 02, 2010 | Sears Craftsman LiftMaster Chamberlain...
I Have a Liftmaster Professional Formula 1 garage door opener. When we press button on wall or garage door opener, we hear the motor going but the garage door doesn't do anything. Do I need a new opener?
There is a rope or string hanging down that releases the dog that hooks the door to the chain...if someone pulled that the door will not open. You need to pull down and back on the srting to relaese the dog and then push the door up to catch the chain...then the door will work again...
heatman101
Aug 14, 2010 | liftmaster Chamberlain Garage Door Opener...
Opener opened fine from the wall and stopped
Check to see if the trolley is jammed against the bolt just in front of the motor unit. If so, loosen the chain enough to ease the tension on the trolley and run the motor until the door closes. While the door is closed locate the 'up limit' control on the side of the motor unit and turn it 2 complete turns in the opposite direction of the arrow printed on the cover. Tighten the chain.
Jul 20, 2010 | Sears Craftsman LiftMaster Chamberlain...
I can hear the motor "working" but the chain is not moving and so door will not open?
Remove the cover from the motor unit and check the drive gear. It is a white nylon gear just in front of the motor and I'm sure you will find it is stripped. The part number is 41A2817 and is available at any door opener service company. It comes with instructions.
Mar 15, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener motor runs, but the chain drive doesnt turn
If the chain is not moving and the motor is – you need a gear kit.
Unplug the unit - take of the cover – you will find white shavings inside – these confirm the diagnosis. .
Get the gear AND sprocket kit.
It’s a good DIY project but you MUST VERY CAREFULLY Follow the instructions step by step.
HOPE THIS HELPS
Mar 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
