Question about Samsung HL-R4266W 42" HDTV-Ready Projection Television
Screen has 3 or 4 places where white light passess through, pinhole size holes. Do you know what might cause this and will it get worse.
  • Samsung Master
  • 5,138 Answers
Light Engine and Yes spots will become worser.
Encompass Parts 1-800-638-3328
Posted on Oct 12, 2010
LED light installed but does not stay on full powered while using dusk to dawn. how to keep LED Par38 on full power all the time
The darker it gets, the brighter the lamp gets. If it's not getting bright enough at sunset or dawn, simply reduce the amount of light getting to the sensor.
Take a piece of black electrical tape, cut a hole in it, maybe 3/4 the size of the sensor opening, and place it over the opening. If that's too much effect, remove the tape, make the hole a little better, and re-apply it. If it's not enough, use a new piece of tape with a smaller hole.
My neighbor did this, over 30 years ago, after telling his kids they could play outdoors until the yard lamp came on.
Sep 07, 2015 | Defiant Flood Lights. 180 Degree Outdoor...
White fog "ring" around outer third of screen. Dark spots and a single white pinhole in picture as well.
If the model above is correct you are describing a bad optical light engine, about the most expensive part inside that set.
Dec 13, 2012 | Mitsubishi WD-65737 Home Theater
Pinhole om rear projection Mitsibishi TV
not an actual hole I PRESUME but a white dot which can be seen in the picture? That if a dot is a bad pixel in the optical light engine.
Jun 11, 2012 | Televison & Video
Strating to get many pin holes in screen
If these pinholes are white dots that do not go away, then more than likely the chip is going out. This will only get worse not better. This is usually sold as a unit and not just a chip itself.
Apr 19, 2011 | Mitsubishi WD65737 65" DLP TV
I have to refill my radiator every 3 days. theres no leaks hose are good i dont know what is the problem? i was thinking it could be the heate core
Have your cooling system pressure tested - you'll find your leak immediately. Could be heater core, could be water pump, could be pinhole leak in radiator or head gasket.
Mar 07, 2011 | Toyota Camry Cars & Trucks
How can i reset my Belkin Wireless G Plus MIMO Router it cannot connect for an internet connection
  • Locate the small master-reset pinhole on the back of the router. The pinhole is located directly to the right of the Ethernet port labeled "connection to modem."
  • 3
    Soft-reset the router by placing a sharp object, like a push pin, into the router hole. Push inward and immediately release the button. The lights on the router will flash and then the "Power/Ready" light will start to blink. When the light turns solid, the router is reset and ready to use. This reset does not restore the router to factory settings. It refreshes the software and is similar to rebooting a computer. If you want to restore the router to the factory settings, skip this step and move to step four.
  • 4
    Master-reset the router by placing a sharp object, like a pushpin into the router hole. Keep the pin pushed into the hole for 10 seconds. The lights on the router will flash and then the power/ready light will start to blink. When the light turns solid, the router is reset and ready to use.
    Read more: How to Reset a Belkin Wireless G Plus MIMO Router ' eHow.com http://www.ehow.com/how_6759000_reset-wireless-plus-mimo-router.html#ixzz16uTbPLCW
  • Dec 01, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
    Propane doesn't seem to be coming out of the right place, thus I can't light the pilot. If I use a match to light the pilot, the flame is coming out of a hole in the valve lower than where I believe it...
    IF THIS IS A WHITE ROGERS GAS VALVE AND IF GAS IS COMMING OUT OF PINHOLE AT SIDE OF GAS VALVE WHERE TWO PILOT PRESURE SWITCH  WIRES GO IN GAS VALVE THAN YOU HAVE TO REPLACE VALVE. AND THESE ARE HARD TO FIND . I BOUGHT ABOUT 10 OF THESE BECAUSE THY ARE PHASING OUT
    Apr 21, 2010 | Endless Summer 1501 Patio Heater
    There is green fluid spraying from the top of my radiator causing my engine to smoke. No overheating alarms are going off.
    sounds like you have a pinhole in the radiator... it will take a long time to set the warning lights off with a pinhole but will make a mess and get worse ...i would say fix it before it becomes a big hole
    Oct 08, 2009 | 2001 Chrysler Sebring
    Hpc4100 printer error message 'Remove and check cartridge on right"' Refer to printer documentation
    3 causes
    1 faulty cartridge
    2 dirty contacts
    3 print carriage ribbon damaged
    Rmove cartridge and rub the golden contacts at the back of the cartridge with a slightly damp (not wet) tissue. Re insert and turn printer off and on again
    If this doen't work check the white ribbon inside the printer cartridge carriage in the printer (which touches the golden contacts on the back of the cartridge when it is inserted) for damage - it might have a pinhole in it where the metal pin holding the cartridge in place has pushed back through the white ribbon
    If there is no damage and rubbing the cartridge contacts has not worked then most likely it is a faulty cartridge
    Let me know how you get on
    Nov 11, 2008 | HP PSC 1210 All-In-One InkJet Printer
    My dvd player wont turn on
    Unplug the unit - look underneath disc tray for an oblong shaped hole with another pinhole or plastic white piece down inside - use screwdriver to move the white piece to other side of oblong - disc should eject. Then try plugging dvd player in and try again.
    Jun 15, 2008 | Philips DVD 622 DVD Player
    Open Questions:
    Samsung HL-R4266W 42" HDTV-Ready Projection Television Logo
    Henry  Thomas
    Henry Thomas
