Question about Samsung Microwave Ovens
Hi,on my Samsung microwave over range,when I open a door my 20 Amp breaker in a panel goes off.This is a dedicated circuit and everything is OK until I open oven door.
    Champion:
  • 248 Answers
The wiring to the oven light,or light swicth is shorting out.will likely have to have a repairman service it unless you know some one with some elect.experiance
Posted on Oct 12, 2010
I don't have a dedicated circuit for a only microwave oven use only. Is this necessary?
no
microwave ovens are a plug -in unit and be plugged into any socket (GPO outlet) that has the correct voltage for the unit
Jan 04, 2017 | Microwave Ovens
My Frigidaire microwave trips the breaker every 5th or so use before the microwave begins to cook.
Thank you for your post, Steve Shaw!
From what you have described it sounds like a possible faulty wiring harness, control panel, or magnetron within your Frigidaire microwave. I would recommend having a professional out to provide a proper diagnosis. This will help to avoid unnecessary part purchases. -Matt
Dec 17, 2014 | Frigidaire FFCE1638LB
What is the wattage of a Kitchen Aid microwave model # kcms135h?
1200 Watts. It should be plugged into its own dedicated 20-amp circuit. It is shares a circuit with a refrigerator, coffee maker, or toaster, it will pop your circuit breaker.
Oct 20, 2014 | Microwave Ovens
GE Profile Microwave, model JES2251SJ02, just stopped working.
1= reset the c.breaker from your home see if are tripped and reset.
2= open for thermal fuse open, test continuity with DVOM OR VOM and replace.
3) test the power cord for open or broken or break.
4= check the switch for door maybe is open must be continuity until 0 , or swtich defective see the diagram attached. God bless you
Jul 13, 2012 | Microwave Ovens
Blowing main breaker
I have a hard time believing that the home's main breaker is tripping instead of the branch circuit breaker that feeds the microwave. I suspect it is really just a difference in terms. You should disconnect it and try using in another outlet - preferably one on a different circuit if possible. If the breaker continues to trip; this appliance should be disconnected and either be discarded, repaired or replaced before using again.
If the microwave works as expected (on a different circuit), it may indicate the original circuit is overloaded. Microwave overs are supposed to be installed on a dedicated circuit. This means only one outlet is on the circuit - no other loads (lights, appliances, etc.) are permitted on this circuit. A microwave typically requires 10 Amps or more when on "high" and will require a significant portion of the power supplied by a 15 or 20 amp circuit breaker. There is little unused to power much of anything else. If other appliances go out when the microwave trips the circuit breaker, you should contact an electrician to have a dedicated outlet installed for the microwave.
I hope this helps!
Sep 23, 2010 | Maytag Microwave Ovens
Upon startup, on high power, trips the circuit breaker. The microwave is on a dedicated 20 amp breaker. It's a recent vintage (2007) Kenmore unit, installed over a cooktop with the built in exhaust fan. I...
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor. See here.
If it went dead several seconds after pressing the Start pad, that's usually a failing high-voltage transformer. See here.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount. See this file.
You can find exploded views and order parts by entering your model number (from the tag in or on the unit) at the Sears parts site.
BUT once you have the part number from the Sears site, you can often get the parts cheaper here.
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Jan 30, 2010 | Kenmore 61684 Microwave Oven
Opening the door blows the fuse
more than likely you door safety switch has a short and every time you pull the door open the connections arc and trip the breaker or blows the fuse.
Aug 24, 2009 | GE JVM1190SY/WY/AY/BY Microwave Oven
I need to install this range in a new kitchen and need to know the electical specs of the supply power
I don't see what range you're referencing. I see a title of microwave ovens. But, in any event, here's circuit requirement for each.
If it's a cooktop range: 220 volt 30 amp dedicated circuit
If it's a microwave: 110 volt 15 amp dedicated circuit
Charlie
Aug 22, 2009 | Microwave Ovens
Microwave / Frigidare PLMV
Chek the high voltage capacitor and the diode . If one of them are short there is a chance for tripping the breaker
May 25, 2009 | Frigidaire PLMV168 Microwave Oven
The past Few days the microwave would trip the breaker. today I went to use it and it worked for 30 seconds when I checked what I was heating and turned it bakc on and it would not work
Microwaves that are either built in, a part of the oven, or over the range are on a dedicated circuit by law. This means nothing else could have tripped that breaker but the microwave.
If it has a problem severe enough to trip a 20 amp breaker several times, it is only getting worse each time you reset the breaker and turn it on.
There is a possible chance of fire. I recommend you turn the circuit breaker off and replace the microwave. Is it a plug in, or over the range type?
May 18, 2009 | Microwave Ovens
Microwave Ovens Logo
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Devabhakthuni...
Devabhakthuni...
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
