Question about ASUS Computers & Internet
Hi, I have just purchased a HDMI cable with converted video and audio connectors for the tv. However after connecting it to my asus k52j computer, i cannot get my computer image on the tv. Can you help??
Set your tv to be connected to the hdmi...and you can set on your pc to see your monitor on tv or with pc and tv...
Posted on Oct 16, 2010
Hdmi instructions
Hi Kelly,
I believe the Sony Trinitron WEGAs do not have an HDMI connection on the back of the TV. If they do it would be labeled as HDMI input below that familiar looking HDMI narrow horizontal connector. But I believe what you have is the RGB connector which looks like three round female connectors which are color coated Red Green and Blue. Now these RGB connectors are a form of high definition but it's not a direct connect for for your HDMI DVD player or your XBOX 360 or what ever you want to hook the TV up to.
You'll have to convert you HDMI to RGB. you can still purchase DVD players with RGB outputs but if you already have a device that requires a TV with HDMI, you can buy a converter. Go to RadioShack or BestBuy or search online for a HDMI to RGB converter cable . It should look something like the picture below.
RED GREEN AND BLUE for video. And then the white and red connectors that are banded together are for your audio.
Good Luck
Dec 12, 2014 | Sony FD Trinitron WEGA KV-32HS420 32" TV
How do I connect my pc to the smart share tv?
Hi Roxy
The first thing to do is determine what the TV input connectors are. Then what the computer output connector type is.
Write these down and then you can go into an electronics or cable supplier company and ask the staff.
Computers often use a Super VGA output connector that carries video only. The sound comes either out of an Audio out connector or fibber optic Toslink connector. Would be excellent if it had a HDMI connector caring audio & video. Check your computer manual.
The best input connector to use on a modern TV is HDMI. This is a single connector carrying video (1080) and audio. then you would simply connect one to the other.
There are several converter boxes available from xxxx to HDMI.
Good Luck
Trevor
Aug 17, 2014 | HP Computers & Internet
How to connect acer aspire 5315 to LG led tv
Acer Aspire 5315 doesn't come with an HDMI port. So, you have the following options:
1. Use a VGA Cable to connect the PC to TV if the TV has PC-Input facility
2. Use an S-Video cable to the TV's S-Video-in port if the TV has it
3. Use and S-Video to HDMI converter if the TV has HDMI port
(http://www.amazon.com/Composite-S-video-Audio-HDMI-Converter/dp/B003NS0UUQ)
for audio, you can use 3.5mm to RCA (Red/White) connector to connect to TV's audio-in port.
Apr 15, 2013 | Acer Aspire 3680 Laptop
Element tv wont see laptop
Connecting laptop VGA port to HDMI port on a TV
VGA to HDMI converter is required to connect a laptop to a TV with HDMI input. The VGA signal does not have an audio component. You need to connect an audio cable from the audio/headphone port on your laptop to the audio connector on your TV. There are HDMI converters with Audio input so you do not need to connect an audio cable to the TV. The audio is connected to the HDMI converter and then passes the audio with the video data to the HDMI cable to HDMI port on the TV. Check out these WEB site for these HDMI converters. http://www.aten.com/products/productItem.php?model_no=vc180 http://www.sybausa.com/productInfo.php?iid=1174 http://www.topbuy.com.au/tbcart/pc/Audio-VGA-to-HDMI-Video-Converter-Box-HD-HDTV1080P-p164633.htm
Mar 14, 2013 | HP Pavilion Computers & Internet
We have connected our asus K52J lap top to our panasonic viera plasma TH-P50V20A via a HDMI cable . We have picture ON THE TV but sound from our lap top only. How do we get sound from our TV
Hi there
I've just looked at that TV model, and it appears that your TV does not support a separate audio connection for HDMI sockets. It also appears that your laptop model has a issue with sending audio via HDMI. Are you running Linux, or windows?
Hope this helps
TV_Doctor
Jan 03, 2011 | Panasonic Viera TH-50PX80U Plasma TV
Connect my xbox on reicever
If your xbox has HDMI connector then you HDMI cable to connect it to the receiver and another HDMI cable to connect receiver to the TV. Receiver should support both video and audio over HDMI.
If your xbox doesn't have HDMI, connect the video directly to your TV using whatever connector/cable is available (in terms of quality from best to worst: HDMI, component, s-video/scart, composite).
Then connect audio to the receiver via optical spdif cable.
Jan 29, 2010 | Yamaha RX-V463 Receiver
What cables do I need to connect my toshiba satellite m55 laptop to my hi def tv?
This really depends on the connectsionon your hi def TV. The laptop doesn't have an HDMI port (these ports carry sound and video in one cable), but it does have a VGA out port as well as a s-video out.
You can connect an s-video cable from your laptop to your hi-def TV, if the TV has an s-video input port.
You can also purchase a VGA to Component converter if your hi-def TV has component inputs, these are the Red, Green, Blue inputs. Amazon sells these, here is a link: http://www.amazon.com/Premium-VGA-Component-Cable-Black/dp/B000RJLSZU
If you have a DVI input you can purchase a VGA to DVI converter as well. These are very inexpensive and you can find a wide selection on Amazon, here: http://www.amazon.com/s/ref=nb_ss?url=search-alias%3Delectronics&field-keywords=vga+to+dvi
Finally, you can also purchase a VGA to HDMI converter. This would be the most expensive option, but you can use this box to put both sound and video from the laptop onto the HDMI cable. YOu would need both the converter and cable for this to work. Converter is here: http://www.amazon.com/VGA-Audio-HDMI-Converter-Adapter/dp/B0015YWV1G/ref=sr_1_3?ie=UTF8&s=electronics&qid=1263068538&sr=1-3
Cable is here: http://www.amazon.com/HDMI-meter-foot-cable-1080P/dp/B0002L5R78/ref=pd_bxgy_e_img_b
Jan 09, 2010 | Toshiba Satellite M55-S325 Notebook
What cable do I need to connect latitude D600 to a hdtv ?
The first step is to inspect both your laptop and TV and identify the connections, easily located on the back of either component. There are five basic types of jacks, or ports involved:
*Composite/phono plug (RCA)
*S-Video
*Video graphics array (VGA)
*Digital video interface (DVI)
*High-definition multimedia interface (HDMI)
*An RCA connector, sometimes called a phono connector, is used for analog audio and video components. Three round, colored sockets are standard — left audio is white, right audio is red, and composite video is yellow. These are standard jacks on older TV’s and laptops. A three-prong cable, readily available at any computer or electronics, is the easiest way to make an RCA laptop to TV connection.
*S-Video, or Super-Video, a more advanced analog video connector, uses a four-prong round plug, like those used in TV cable installations. Separate audio cables are the same as for the RCA connector, left audio/white, and right audio/red. S-Video is commonly found on older TV sets and some laptops.
With S-Video on both TV and laptop, connecting a laptop to a TV is a simple matter of a single S-Video cable. If your laptop has a great sound system, you won’t need audio cables, but for better quality you’ll also want audio cables.
RCA to S-Video cable, a special laptop to TV cable, is available when you have RCA jacks on one device and an S-Video port on the other.
*A VGA connector and cable are used to carry analog video signals plus display and graphics data. The VGA is a 15-pin connector commonly found on laptops and other devices. With this port you need a PC-to-TV Convertor to connect laptop to TV. You simply plug the VGA cable from the source into the convertor, and use an S-Video or RCA cable out to the TV. The converter is USB powered, so there’s no external power adapter to carry around, making this laptop to TV connection entirely portable.
*A DVI port is rectangular with 24 pins arranged in three horizontal rows of eight pins for digital video; separate RCA analog audio cables fit into white and red plugs. DVI ports are found on Macintosh laptops; sometimes they are smaller than normal DVI ports and require an adapter, which usually comes with the laptop.
*The HDMI port, one-half the size of the DVI port, is also rectangular with 19 pins. It provides digital audio in addition to digital video, despite it’s smaller size, for a complete TV to laptop connection. These ports are found on new HDTVs, and sometimes there are two or more. TVs with HDMI ports are the only ones that do not require additional audio cables.
TV’s with a single digital port labeled HDMI/DVI require only one cable when the source is another HDMI component. But when source is a DVI laptop, you need a DVI-to-HDMI cable for the video and a separate pair of RCA analog stereo cables.
NOTE: Whenever ports do not match, you can by adaptors and/or cables to make any connection.
Nov 22, 2009 | Dell Latitude D600 Notebook
Connecting my laptop to my new TV
Hi there.
Check on the back of the TV for a VGA input port, if it has what you will need is a male to male VGA lead and a mini stereo to mini stereo audio lead to plug into the headphone port on the laptop to audio in on the TV.
Good luck and thanks for using Fixya!!!
Feb 23, 2009 | Compaq Computers & Internet
Computers & Internet Logo
188 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
