Question about Brother Office Equipment & Supplies
Printer will not print black. put new ink ,twice and ran the clean head function a few times ,still will not print black ,colors are fine
  • 734 Answers
Brothers and Canons can sure be cantankerous. My guess is your printer is due for a complete servicing at the nearest local center qualified and guaranteed. Please just take it there, with the caveat that it must be accompanied by a FLAT RATE quote. And get it back in order.
Otherwise, I do not recommend purchasing a Canon or Brother printer ever again. Always buy HP, and the moment you get home, buy the highest extended warranty online possible for as long as possible, or finally,
learn to be a printer technician by reading hours of blogs, threads, and all otherwise concerned only with your model of printer.
I'll let you be the judge of the cross-referencing of costs. Those may not incluse recordkeeping you're fond of.
Kind Regards,
Posted on Oct 12, 2010
Black color will not print. Installed a new black
Ink is a lubricant for the print heads. Some color ink is used even if you only print in black or vice-versa. If you printed with a color missing, you could destroy that print head from the friction of running without ink to lubricate it. That's why most printers won't allow you to print with a color missing even if you aren't using it.
If you allow a color to go empty, the residual ink in the head could clog and become permanently blocked. You would never be able to print that color again. So always replace ink cartridges as soon as they are empty.
Leaving your printer on takes very little power. Every so often the printer sends a signal to cycle the ink in the heads so it doesn't clog. If you turn your printer off, the next time you turn it on it will do a cleaning which wastes a lot of ink. The excess ink is soaked up by the waste pad beneath the printer. When the waste pad is full, the printer stops working. Unless you want to spend more than the cost of the printer or waste a lot of time on a messy cleanup you will end up throwing the printer out. So shutting it off actually shortens its life.
If you leave the printer off for extended periods of time, the ink in the heads will clog and you will have to throw the printer away. Someone I know with a Canon (though this can happen with any inkjet) had to have the heads replaced twice within the first few months before the Canon tech told her to stop turning it off. Since then it has worked perfectly for over a year.
How to clear blocked print heads:
-leave the printer on for a day
-run several head cleanings and print the nozzle check pattern
-if that doesn't fix it, remove the cartridge(s) from the blocked head and drop alcohol where the ink enters the printer.
-reinsert the cartridges
-run one head cleaning
-wait about an hour then run some head cleanings.
-dip the print heads in Isopropyl Alcohol overnight, which you can buy from chemist
-if that still doesn't work, your heads may be clogged to the point where they need repair or replacement, which will probably cost more than a new printer.
Dec 06, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
MFC 790cw will not print in black.
garetg,
Your issue with the black ink only is because the print head my be dried up. Witch me that the ink cant flow to the "paper" fast enough. So by time to rollers eject the paper, the ink cant print on the paper. I had the same problem with my Kodak EasyShare 5300 All-In-One. So I contacted Kodak and they are sending me a new one. Try doing the same. Contact your manufacture and ask them..... :)
Much Regards,
Kyle
Sep 16, 2009 | Brother Multi-Function Center MFC-240C...
MFC-790CW; will not print the black color..
You probably have a plugged print head or the black ink feed is plugged.
Depending on how bad it is you may find it easier or even cheaper to replace the printer.
If this is a ink caused problem you stand a chance of fixing it if you are patient but you might go through half an ink cartridge to get it working, If it is stubborn it can take 20 or 30 cleaning cycles before you see any black. You can try using household vinegar (dissolves the dried ink) on a qtip or lint free paper towel to try to clean the print head. To do this you remove the ink cartridge and very gently rub the towel with the vinegar on the print head. This might require you to move the print head to one side so you can see the actual print area (where the ink comes out). Keep doing this until the towel starts to come clean ie not as much ink coming off. Then run a few print cycles and if this works your printer will print as good as the first day you had it.
The next stage would require filling a old clean ink cartridge with vinegar and running cleaning cycles. Usually can be pretty messy and you should rethink buying a new printer but will really clean things out.
It is also possible that the print head has picked up clay or paper lint from the paper and this has hardened like a cement. That means replacement.
Aug 17, 2009 | Brother Multi-Function Center MFC-240C...
Black Ink won't print on my Cannon ip90 Printer
Here's the link to the transcript..
http://www.fixya.com/support/c36778-black_ink_print_cannon_ip90_printer
Please post your comments there if you are not able to reconnect to the session with me..
Mar 20, 2009 | Canon PIXMA iP90 Mobile Printer
Wont print
I had this problem recently with my IP90. Both the black and color heads were clogged. After running the "canned" routines several times to clean the heads and deep clean the heads...still didn't help...here's what I did:
1. open the top lid to have the cartridges that are inserted in the print head move to the middle of the printer.
2. remove both cartridges
3. What is left there is the print head holder. Slightly move it to the right and gently lift the print head lock.
4. Grasp the print head and lift it out of the tank.
5. Have several paper towels hand and know that you will have color and bw ink on your fingers
6. Put the print head on the paper towel
7. Pour rubbing alcohol on the blk and color heads and let them sit of about 10-15 minutes.
8. after that dry the heads and re-insert them in the printer
9. I put new cartridges in the printer and ran clean and deep clean a few times.
10. My color and black and white print came right back!
Hope this helps.
Mar 17, 2009 | Canon PIXMA iP90 Mobile Printer
Printer will not print black ink.
1. open the top lid to have the cartridges that are inserted in the print head to the middle of the printer.
3. What is left there is the print head..slightly move it to the right and gently lift the print head lock.
4. Grasp the print head and lift it out.
5. Have severasl paper towels hand and know that you will have color and bw ink on your fingers
10. May color and black and white print is back!
Hope this helps.
cw
Feb 16, 2009 | Canon PIXMA iP90v InkJet Printer
IP90 WONT PRINT BLACK
Hope this helps.
Jan 30, 2009 | Canon PIXMA iP90 InkJet Printer
Replaced empt 3E cartridge. Now it won't print
I had removed and reinstalled the empty 3e cartridge. Sorry for the Confusion. I hadn't put a new 3e cartrige in until today. Them I ran " deep clean" twice. The printer works fine. I still don't understand why the printer wouldn't print color, when I was had set the printer to print in color when my 3e cartridge was empty and all colors including the 6 black showed full.
Mar 31, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Black will not print
This may seem obvious but have you tried cleaning and refreshing the print heads? I've had a similar problem with only certain colors and the cleaning seemed to help.
Nov 06, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Black Won't Print On MFC 420 CN
Use another new genuine (original brother) BK cart. Do the cleaning twice only for BK. Wait some time (4 hours). If the ink has dryed up, the cleaning ink will break up the dryed one. Do the cleaning again. If it doesnt work, please write again.
Sep 18, 2007 | Brother MFC 420CN All-In-One InkJet...
41 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
