Question about Garden
I have a Skil model 944 and have no manual. How do I change the spark plug?
2 Suggested Answers
dontbother10
  • 2220 Answers
SOURCE: Does anyone have a chainsaw manual for Skil model\
A search for Skil here:
Beg for manuals thread (ArboristSite) (free to join) http://www.arboristsite.com/showthread.php?t=72322
Nets a few hits. One for a 1616. Post your need Someone probably has what you seek.
Lou
Posted on Jan 17, 2010
Skil belt sander model 448 plastic handle
Contact direct
Owner's Manuals & Parts Lists Make the most of your SKIL tools. Review owner's manuals and parts lists online by searching in the desired tool category.
If you're looking for an older model that isn't listed, call 1-877-SKIL-999 (1-877-754-5999) or email Customer Service.
For manuals and parts lists on models beginning with SPT, please visit www.SKILSAW.com
Owner Manual Parts Lists
Mar 24, 2018 | Skil Tools & Hardware - Others
1985 porche 944 cylinder 2 and 3
to check that substitute the ecm with a known good unit
Jun 20, 2017 | Porsche Cars & Trucks
Hi; I have a Skil hedge trimmer model 518H2 that got under water when the basement flooded - now does not work - can it be fixed - how - or do i just buy a new one; Thanks sawent under ,,erq Kil
Remove spark plug and allow everything to completely dry. Check oil, if water in oil, replace oil. Heat up plug with a torch or lighter to get rid of any moisture. Then reinstall. Fresh gas should do the trick.
Jul 04, 2012 | Garden
How do the black things connected to the spark plugs go in a 1987 Porsche 944
do you mean the spark plug wires? and what is your firing order? and what make and model car and engine?
Oct 06, 2011 | 1987 Porsche 944
Lou
Jan 07, 2010 | Garden
83 Porsche 944 2.5L. No spark, no fuel...
Start at the coil. With key in on, the coil should have a hot wire to the primary side of coil. You have the manual-does it show troubleshooting for the ignition system? You will most certainly need an automotive volt tester, a digital volt-ohm meter (DVOM) is best buy, also known as a multi-meter. Doesn't have to be an expensive one either-$30 for decent ones. Use it to test for power at the coil when key is on- that's why they call it the "ignition switch", hey? So if you have power to coil, read up on your ignition system to see how the coil is controlled to deliver spark. On American makes of those years, an ignition control module was used to turn the primary side of coil on and off. Before computers, the ICM was controlled by a pick-up coil inside the distributor to tell the control module where the crankshaft was. So spark would be delivered at the right time.
Sep 14, 2017 | 1985 Porsche 944
Looking for the manual for use for a Skil biscuit joiner. Can I find one online to print off? Chris oldlincolnian@wwdb.org
Here is a link to the owner's manuals page at Skil.: Skil OM
Unfortunately, you haven't listed the model number, and skil manufactured several biscuit joiners or plate joiners over the years. If the manual you're looking for isn't available to download online, there's a phone number listed on that link or you can email Skil to acquire older manuals.
I hope this leads you to the solution to your problem. Thanks for consulting the folks at FixYa!
Mar 26, 2009 | Saws
Car wont start .
You will not be able to hear the fuel pump on that model. First you have to determine if you get fuel and have spark. If it is a fuel problem, replace the DME relay first. Very common. They act up and fail without warning. Part is cheap and located in the fuse box. Next would be the fuel pump.
If it is spark related it may be the Flywheel Reference Sensors. There are two and the cost about $100 each.
Good Luck.
Jan 10, 2009 | 1987 Porsche 944
Garden Logo
144 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
