Question about KitchenAid KESC307 Electric Kitchen Range
We have a 10 plus year old kitchenaid cooktop. The SAB code is showing on the display panel constantly. The oven works, and all the burners. How do I get this into normal operation. Wayne Styles
  • 2 more comments
  • catherine322 Oct 12, 2010
    I don't have the manual. That's the first thing I looked for. What do I do now? Isn't there a ccomman code that is used on all the kitchenair appliances.
  • catherine322 Oct 13, 2010
    Hi again
    The sequence you gave me didn't work. It seems that the key pad doen't work very well. The numbers don't work and the bake button will work if pressed numerous times. ( You cannot change temperature)
    Is it possible that the touch pad went on the blitz and this SAB Mode came into effect at the same time I understand sometimes the touch pad goes defective
    Wayne
    Tried what you said, and still no resolve. Does this mean the touch pad is gone. Can you even buy a touch pad?
    Wayne
  • catherine322 Oct 14, 2010
    If I understand you correctly I'm going to this "searspartsdirect" to get an exact model number search. What do I do with this information?
    President:
  • 1,554 Answers
You may have accidentally activated "SABBATH MODE". It is a designed feature to allow Jews use the appliance and the same honor their laws during Sabbath. Refer to the Operation Instructions on how to turn this feature on or off. Indicate the exact model number if you don't have the literature. You don't have to accept or reject and rate this post to add information or post comments and follow-up questions. But accepting the solution will not stop you from communicating with the expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Posted on Oct 12, 2010
  • 2 more comments
  • Jahn27
    Jahn27 Oct 12, 2010
    Try this:
    Open the door then press CANCEL OFF. Press the number pads 7, 8, 9, 6 in that order then press START. "Sab" and "On" will appear on the display if the Sabbath Mode is enabled or "Sab" and "Off" if disabled. The same sequence enables and disables the Sabbath Mode.
  • Jahn27
    Jahn27 Oct 13, 2010
    The touch pad is indeed not working properly if the buttons specified in the sequence are present on your model but there's no indication that the SAB Mode is enabled or disabled. The SAB Mode was probably activated on its own due to the touch pad malfunctioning especially if there's no instance where someone played with the touch pad that might activated it. Unplug the appliance for at least an hour to possibly "reset" it and make the touch pad work.
  • Jahn27
    Jahn27 Oct 14, 2010
    Go to SearsPartsDirect then enter the exact model number of your oven and select model number search.
  • Jahn27
    Jahn27 Oct 14, 2010
    You asked if you can buy a touch pad so go to SearsPartsDirect then enter the exact model number of your oven and select model number search. Under the parts category Control Panel, you'll find the touch pad you need.
Getting an F15 error code when trying to start Oven.
Error code f15 'Frigidaire FEB30T7FC Stainless Steel ...
www.faqqq.com/.../error-code-f15-frigidaire-feb30t7fc-stainless-steel-ele...
Error code f15 'Frigidaire FEB30T7FC Stainless Steel Electric Double Oven ... I'mtrying to open up a Unity3D game.exe that is on a remote computer through my main desktop. ... How 2016 will be the start of your virtual reality future - CNET.
Kenmore range shows f15 error code - ApplianceJunk.com
appliancejunk.com > ... > Forum Index > Range, Oven & Cooktop Repair
Oct 31, 2010 - 10 posts - ‎5 authors
Kenmore range suddenly started flashing f15 error code. With Thanksgiving just around the corner, i need help with this repair. Thanks.
Dec 30, 2015 | KitchenAid Kitchen Ranges
Tip
My oven displays error code 5AB
Hi.
I am publishing this tip because of the many users asking me about the code 5AB on Amana, Maytag and other ovens.
Error 5AB in fact does not exist , and what you see written on display isnot 5AB.
The beeping sound is a warning because the oven is in lock condition. The oven is not faulty, and the code is not 5AB, but SAB.
SAB means that the oven is in Sabbath mode, and the control board will be locked for 72 hours with SAB on display.
If power is disconnected a new 72 hours cycle will start.
Depending on the model, there may also be a beeping sound when you try to operate the oven.
Push and hold the Clock button for about 10 seconds, until the display clears, that will reset SAB mode.
If that does not work leave the oven connected and off for 72 hours. If the oven does not unlock after three days, then the electronic control may be stuck in SAB mode because it is faulty, in that case contact the manufacturer at the number listed on the owners manual.
Regards.
on Mar 05, 2010 | Ovens
Constant clicking from electric pilot connection. won't stop after leaving for long time, unplugging overnight, cleaning all burners, running gas by lighting with match and letting the flame run. ...
Hi nancypp,
The ignition switches probably got wet.
Please follow my below Tip on how to fix it:
GAS STOVE CLICKING PROBLEM...
Kind Regards
JEDEMEYER1
* If this solution helped you, please accept it
Sep 04, 2011 | KitchenAid Cooktops
I have a code 5ab on the panel my model nuber is MGR5775QDS its a 30 inch free standing gas stove.
Your range is probably in the Sabbath mode. The error code shown on the display is"Sab", not "5ab".
To disable the Sabbath mode push and hold the Clock pad for 3 seconds
Read more: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/2348-maytag-oven-weird-error-code-5ab.html#ixzz1GLM0d1gp
Mar 12, 2011 | Maytag MGR5775QDS Dual Fuel (Electric and...
Code S ab on screen
try pressing and holding the clock tab on the erc for 5 secs
this will usually cause the sab to flash 3-4 times and then retrun to normal operation mode
Oct 17, 2009 | Maytag 30 in. Admiral LGC1330 Gas Cooktop
Readout is stuck on 5Ab. Can't do anything with it
Hi.
Regards.
Jul 09, 2009 | Maytag MEW6530D Electric Single Oven
Error code F1E0 AND Replace UI ???
F1-E0 - EEPROM Communication Error - Disconnect power for at least 30 seconds and then reconnect.
Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 29, 2009 | KitchenAid KESC307 Electric Kitchen Range
Kitchenaid Gas Cooktop with electronic ignition
you sound as if the short is occourring within the switch assy perhaps water has spilled on it, listed on gas range, but assuming you have an electric unit, with the knobs poking through the glass
Nov 09, 2008 | KitchenAid Cooktops
Replace burner seals of gas cooktop
good day,
hope this link below will solve your problem.
kitchen
Sep 03, 2008 | KitchenAid 31 in. KGCS105 Gas Cooktop
KitchenAid KESC307 Electric Kitchen Range Logo
79 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
