Question about Canon imageRUNNER 2000 Copier
Where is the waste tone located in the machine
  • Canon Expert
  • 270 Answers
It is located in the drum.. Pull the drum and remove the white cover and gently dump the contents. It doesn't have to completely empty. Re-install the drum and all should be OK.
Posted on Dec 08, 2010
Reset Waste Toner
If your machine is displaying "replace waste toner container" then you can empty the waste toner box & reset the machine.
If you open the front door you will see a large black box & above this a small rectangular green button. Pressing this button will release the black box. The box will then lift upwards from the machine. At the bottom of the box you will see a round, clear plastic bung, remove the bung & empty the waste toner into a suitable bag or container. Once emptied, the bung can be re-fitted, the waste box can be inserted back into the machine. Locate the waste box into the 2 slots then push the waste box firmly back in place until it latches. Turn the machine off & on using the switch located to the left of the waste box in the bottom left corner of the inside of the front door. This should reset the machine. Be careful when disposing of the waste toner, it is flammable so do not dispose of in a fire. Hope this helps.
Dave.
Feb 19, 2016 | Sharp MX-3501N All-In-One Printer
Cleaned waste toner out but xerox 7545 wont ecept it says to replace waste tone
You didn't clean the bright plastic bubble at the upper inside end.
If dirty, machine thinks it is still full of toner.
Jun 24, 2014 | Xerox Workcentre 7545/PT 7545PT Color...
C-2204
replace the waste toner box and check the gears on the left side of the machine when you replace the box also check the transfer belt waste tone systems for proper operation
Apr 03, 2014 | Konica Minolta Bizhub C550
Where is the waste toner bottle on the xerox workcentre 5030 located at?
  1. Open the Waste Toner Bottle Access Door. The door is located on the left hand side of the machine, behind the Bypass Tray.
  2. Pull the colored cap from the top of the bottle and screw the cap onto the opening of the bottle.
  3. Remove the used Waste Toner Bottle and dispose of it according to the instructions contained in the new Waste Toner Bottle box.
  4. Unpack the new bottle from its box.
  5. Install the new bottle in the machine. Make sure that the bottle is placed correctly in the machine cover.
  6. Close the Waste Toner Bottle Access Door.
Mar 30, 2011 | Xerox WorkCentre M-24 Color Copier
HOW DO YOU CHANGE THE WASTE TONER ON SUMSUNG 2160 PRINTER
he 'Waste Toner Tank' is the gray colored part located to the left (If you're facing it) of the toners barrel. So all you need to do is take the Waste Tone Tank out, shake out all the waste tone from it and replace it.Then your printer should be up and running. Your other options is to buy a new one for about 12$ off the internet. If you need further assistance let me know.
Thank you,
Lee
Aug 25, 2010 | Samsung CLX-2160N All-In-One Printer
USED TONER CASE IS NEARLY FULL
Hello sir; There have no waste tone bottle for this machine, but waste toner all stuck in the imaging transfer belt unit, on the right hand side door,pull it out dump the toner out and vaccumn it.
May 06, 2009 | Ricoh Aficio 450 Copier
Emptying waste tone cartridge
You need to replace the waste toner bottle (packaged with a new toner cartridge) you can't just empty it. There is a photo sensor that "reads" through a window of the waste bottle. The sensor could be dirty. Clean the slits with a q-tip.
Oct 01, 2008 | Kyocera Ai3010 Copier
Waste tone bottle
bottom left hand side of the left side of the machine there is a small cover with one screw holding it. All you need to do is loosen the screw, remove the cover, and pull out the waste toner container. Please take note that the screw on this cover does not come out all the way
Jun 12, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Panasonic KX-FM220 fax machine does not have a dial tone
is your line provider ok.connect your line to ordinary phone to check if there is really a dial tone from the line provider.if there is a dial tone please let the analog board be cheked by a technician near you
May 01, 2008 | Panasonic KX-FM220 Plain Paper Thermal Fax
Waste Tone Box
Your machine catch's excess toner and puts it in a container and needs you to replace/empty it soon or it will have to stop work, sorta like needs just a dash of attention for all its effort.
The bottle at a guess for this model will be apparent when opening front door, instruction are probally on the inside of door but it is just a container full of black messy stuff that needs to be emptyied and replaced....hang on I'll google it....looks like you need to buy a new box and that will have instructions even.
Some links for your product toner box
http://www.precisionroller.com/catalog_display.php?mfname=konica_minolta_bizhub_c450p_waste_toner_container_details&m=297&d=7597&c=40&i=31526
http://www.tonermax.com/KONICA-MINOLTA-BIZHUB-C450-WASTE-TONER-BOTTLE/i/24194
Oct 31, 2007 | Konica Minolta bizhub C450P Laser Printer
Canon imageRUNNER 2000 Copier Logo
35 people viewed this question
old marine
old marine
