Question about Kenmore Elite 45986 Front Load Washer
Kenmore he5t Hi I saw your post about your he5t having the f22 code and the door being locked. I was wondering if you found out what the problem is. I just got my washer and dryer today and I'm having the exact same problem. Thanks! - Arlene
  • 240 Answers
This looks like a classic whirlpool control board issue. fault is a communication error between board and panel. check connections.
whirlpool always recommends replacing both at same time. very common problem.
Posted on Jun 03, 2008
Kenmore elite he5t front loading washer door locks, unlocks, then locks again before beginning cycle
This is aself test procedure on the door locking mechanism . You will also hear a click, the drum will make a partial turn,and the door will unlock berore locking again. Once the door has locked a second time the washer will begin tumbling and adding water. The sensing process will continue until the correct amount of water is added to the load.
Feb 12, 2013 | Kenmore Elite HE5t Washer
Whirlpool Duet Washer F22 Error Code Follow-up
1) F22 mean DOOR LOCK ERROR , this problem can be a) switch for open or defective b) loose wires or broken wires, test by continuity VOM .
2) adjust the Door vs switch very well for propely closed, and test the closed switch.
3) see if the color are missing and put in the WRON terminal.
God bless you
Jun 28, 2012 | Washing Machines
I have a kenmore elite; suddenly when I try to start it, it makes a few clunking noises and the F22 error code appears
Whirlpool (Kenmore) 'F16, 18, 20, 21 and 22' all refer to 'control unit failure I'm afraid. Sounds like a service call is required, sorry ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Jul 30, 2011 | Kenmore Elite HE5t Washer
Washer gives code F22. I replaced the door lock mechanism but it still will not start.
Hi, F-22 means that the CCU /touch pad/LED assembly unable to transmit/receive
data to/from the CCU central control unit
Possible causes/procedure:
1. Check the touch-pad/LED assembly by selecting different
cycles and changing the modifiers and options available to
confirm the touch-pad/LED is responding.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the
touch-pad/LED assembly and Central Control Unit (CCU).
Your model's tech sheet gives error codes and remedys.
Jun 17, 2011 | Kenmore Elite HE5t Washer
Door locked model he 2t
F22 error code means that the door lock mechanism is not functioning and the wiring has probably come loose. Open the top (2 screws in back) and you'll probably find (as we have now 3 times) that the wires and door lock mechanism have come loose (no wonder with the vibrations of the spinning drum!). Plug it back in yourself and save the annoying repair bill! Make sure to unplug the washer before you attempt it...
Jun 05, 2010 | Kenmore Washing Machines
HE5t Kenmore Elite
non existent code. if under warranty call tech support. probably control board. can manually override door lock. by removing lower panel and pulling tab at bottom of lock mech.
May 30, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore front loader HE2
F22 Error means
DOOR LOCK ERROR
after 6 failed attemts to lock the door.
Possible Causes/ Procedure 1.-*Door lock mechanism is broken or removed from door. 2.-Door  switch/ lock unit failure. Check door switch/ tock unit. 3.- Check the wire harness connection to the door switch / lock unit and Central Control Unit (CCU).
was this helpful?
May 05, 2008 | Kenmore 82836 Gas Dryer
Kenmore Elite HE5T Steam - Won't Start, No error codes
I had the same problem, but due to the great info on the internet, I found the problem and solution.  I have been able to temporarily fix it until I can get someone out to repair the plunger.  The site below has the details.  http://applianceblog.com/forums/view_topic.php?id=730&forum_id=2&jump_to=4559
Karen
Nov 15, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
371 people viewed this question
Sal De
fordexpert
Robert Rankin
