Question about Samsung SyncMaster 172N 17" LCD Monitor
I have a Samsung monitor.Over the last two weeks, I observed my screen going blank, the colors going haywire and sometimes even partial loss of screen whereas the other half seems to work. Initially, I thought that this might be due to overheating as I tend to leave my computer on for a whole day or so periodically(though even on these days, I switch off the monitor when I am not using it. I test the monitor frame to determine if it is heated up and it remains cool). However, now even if I run it for 10 mins , it starts to go blank. Please help me!!!!!!!!!
SOURCE: problem with samtron 56v 15" monitor
IT IS REULATION COMPLIANT PLEASE CHANGE THE 7805REGULATOR IC NEAR THE MEMORY IC
Posted on May 12, 2007
SOURCE: Monitor not switching on.
Sync753s Monitor power switch problem.
I have to press monitor power switch to on my monitor, but occasionaly it works. Once On without any problem it is working. What will be the problem.
How to solve this problem ?
Posted on Jan 07, 2008
HACK ICB
SOURCE: Screen goes blank
Its simple bro , Your CPU is not reading RAM,so just Remove and Re Insert the Ram to in DIMM Slot and then Switch on Computer it will work fine.
Posted on Jul 21, 2009
  • 1684 Answers
SOURCE: No display on SyncMaster 920NW after reboot from power failure
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. Look in our monitor repair section for step by step repair guide for this model it should be the same power supply as the 930. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Posted on Jul 22, 2009
  • 121 Answers
SOURCE: i have the syncmaster 20wm samsung monitor. I
try pushing the input button or checking the cables
Posted on Dec 02, 2009
Compaq presario cq61 SCREEN GOES HAYWIRE WHEN POWERED ON
I love posts that use haywire words...
really.
old Cq61 (310us) is it a 310? for sure, as the service tag shows?
no photo of screens, i can promise you that missing photo
is worth 1000 words !
does it run with them main battery out on line power AC?
it must for as long as you want too.
my guess, besides above test 1 on all laptops
is to
make sure its not overheating. and fan blows, and fan is not packed in lint if the GPU chip overheats it can go nuts. all can,.
we run temp monitor program that lets me see all that.
but im not teaching that now.
this PC has an LED screen so is very good.
but if hit, they break easy, super easy. kids playing thowing things at the screen or dropped PC.
The pC has and external VGA jack to test the PC on any VGA desktop monitor.. (barrow one for a day)
Oct 06, 2017 | Compaq Presario CQ61-310US Laptop
FP-768 (Silver, Black) (Black, Silver) 17 in. Flat Panel LCD Monitor: My screen goes haywire with all kinds of color cha...
The vertical lines/bar are sign of bad T-CON (LCD controller driver) board is bad, it is part of the LCD panel assembly, new screen will be needed, not worth it. You may try reseating the ribbon cable at the panel.
http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
May 16, 2010 | Fuji FP-768 17" Flat Panel LCD Monitor
Dear Sir, I am facing problem with my Samsung LCD monitor, when I switched on my Computer it shows the bootup screen, after booting the LCD screen goes blank, when i turned off the monitor and again turned...
yes turn on the computer and keep pressing F2 contineulsy immediatly after display observed then menu will be come then highlight on last good known configuation and press enter problem will be solved
Mar 05, 2010 | Samsung Syncmaster 730B 17" Flat Panel LCD...
Brightness/Contrast Adjustment
try going to the setup screen button left of adjustments
try going to the set up menu on the left of the buttons come down to the slider control just above the information icon then go across to color reset hope this helps regards Jim
Mar 12, 2009 | Samsung SyncMaster 2253BW LCD Monitor
Samsung 204B random blank screen
I too have a dual monitor Samsung SyncMaster 204 setup. My monitors started flickering, then a week later had turn on problems like your describe. I found a fix on this fixya website and followed the fairly techie suggestion. It worked. I wrote up a .pdf set of instructions so others might also benefit. Hope this helps. Doug
Feb 07, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
Computer boots fine but the monitor is blank
if the monitor works fine on your laptop, the problem definitely is at the computer, possibly with the video card (if it is using one). it could have loose connection, or parts might have damages. it seems the problem is intermittent so electronic component of the video card could have parts partially damages or leaky components.
if your still using the motherboards built in video out put, try installing a new video card.
Oct 31, 2008 | Computers & Internet
ViewSonic VG170m 19 in. flat screen monitor
plug it in at the back of the monotor.....i left my connector undone and it fell out a LITTLE bit on one side of the connection and all i got was a blank screen also.
good luck
Feb 11, 2008 | Computers & Internet
Flickering, sparkeling, ghosting, you name it. Related to electricity in house?
No, it is not the electricity in your house, I had the same problem. Send it back to Samsung and get a new one. I have had to send my monitor back 4 times!
Oct 28, 2007 | Samsung SyncMaster 204B 20.1" LCD Monitor
Samsung SyncMaster 172N 17" LCD Monitor Logo
46 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
