Question about Westinghouse Microwave Ovens
Reattaching wires to rangehood westinghouse wrj900us
    Champion:
  • 248 Answers
Usually have wiring diagram posted somewere on unit
Posted on Oct 12, 2010
Am I able to fit a charcoal filter to a viali undermount rangehood model VPP90s and what kind
There is a picture that supposedly shows you how at this site: http://vialiproducts.com.au/wp-content/uploads/2015/10/VPP52S-60cm-Undermount-Rangehood.pdf
I am not too impressed with it, but hope it helps you!
Feb 12, 2017 | Microwave Ovens
Tappan Electrolux tmv151fs microwave/rangehood. turntable and cavity light intermittent (but work/fail in unison), all else work ok
Either a wiring problem or worn contacts on the relay that powers the two would be possibilities.
Nov 24, 2016 | Microwave Ovens
Technika rangehood parts
please follow the steps and fix it. God bless you
  1. Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  2. Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction.
May 27, 2013 | Microwave Ovens
Hi i need a function switch for a Zanussi ZHC914 rangehood, are you able to help
might have to get from zanussi..........i don't know of a generic replacement.........meder's tv service
Aug 31, 2011 | Zanussi Microwave Ovens
Parex beta 90 ss rangehood stopped working Lights on switches work but not the fans or lights
Unfortunately didnt do anything about this for years. Managed to take off the white box behind the front panel swithes. Opened this up and "hey presto" the circuit board is faulty. Wouldnt it be nice if De Longhi sent out another one free of charge as this is obviously faulty, looking at some of the same complaints that have been posted. Imagine all the people that dont use computer or internet. I soldered wire between the points and it worked straight away.
Jun 10, 2011 | Microwave Ovens
I have a qasair rangehood (uv-1200-2) with 2 lights. The lights have not worked for a year or so. I have now replaced them (following http://www.qasair.com.au/images/installation_inst/QAIInstr_Lamp.pdf )...
First, turn off power to the rangehood. Check the contact resistance of the light switch(es) with an ohmmeter. It should be less than 0.1 Ohms. If you get a substantially higher resistance in the on position, the switch contact is burned out. Also, inspect the wiring harness connector and the connections to the light fixtures. If they show signs of overheating, the connection resistance is too high. You can try polishing the connector contacts to remove oxidation. I use a pencil eraser for mild cases and a non-metallic dry scouring pad (3M Scotch-Brite) for more severely tarnished contacts. In the worst case it will be necessary to replace the terminals or connector.
According to the drawing for this series on the Qasair website, the unit uses fluorescent lamps rather than the halogen lamps referred to in the lamp installation instructions. If this is true, it is likely the ballast has failed (if the lamps have separate switches, they probably have separate ballasts also). If the original ballast model is no longer available, make sure the replacement has at least as high a maximum temperature rating as the original. This is especially critical for electronic ballasts. You can extend the life of the new ballasts by making sure the fans are running before turning on the lights - this should reduce the ambient operating temperature inside the hood.
May 25, 2011 | Microwave Ovens
Baumatic rangehood bah9005 the switch pushes in and the lights dont work , motor works when electrical switch at wall is on
Thank you for using FixYa. It sounds like there is obviously power getting to the rangehood ( the motor works) and I would suspect that it is just the bulbs that have blown.
Mar 16, 2011 | Microwave Ovens
Where can i get the Dishlex ranghood filters that more than 20 years old ?
The following Australian site carries Dishlex parts. You will need to know the model number of your rangehood or the size of the filter. If you know the model number simply do a more specific search to narrow your choices.
http://spares.alliedappliance.com.au/search.php?match=&keyword_list=Dishlex+rangehood+filter
Feb 15, 2011 | Microwave Ovens
Kenmore combo microwave rangehood.everything works but won't heat food.what do you think the problem could be ?
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Aug 30, 2010 | Kenmore 62622 Microwave Oven
Microwave Ovens Logo
210 people viewed this question
Top Westinghouse Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Westinghouse Microwave Oven Expert? Answer questions, earn points and help others
