Question about Maytag MER5775Q Electric Kitchen Range
Electric stove stopped working. Code 50 appears when I turn burners on.
  • 3 more comments
  • fadiatiyeh1 Oct 12, 2010
    Just to clarify. I can turn the burners on and the oven on and can see the display with a code of "50", but nothing heats up or works in the entire stove, and within a few minutes the display and the entire stove shuts off in that the screen goes blank. Again, the oven or the burners do not work. Is the problem and solution still applicable? Please advise!
    Thank you.
    Thank you.
    Hopefully, it will work. Thank you in advance!!!
    Hopefully, the proposed solution will work. I will find out in 1-2 days.
  • fadiatiyeh1 Oct 13, 2010
    Folks,
    I just got the ERC part today and replaced it, but I'm still getting the same code "50" on the LCD display and the stove is still not working. So, could it be that the solution you proposed is the not the correct solution. And if so, what other solutions recommendations would there be? Please advise!
    Regards,
    Fadi Atiyeh
    Genius:
  • 1,416 Answers
HELLO,
What this error code on a Kitchen Aid range indicates a keypad short on the Electronic Range Control (ERC) board. This is the clock/timer on the operator console. The recommended fix is to replace the ERC. It has cost it to stop working You can generally find replacement parts at these websites:
searspartsdirect.comappliancepartspros.com repairclinic.com
All these sites offer great service with competitive pricing, so shop and compare.
Replacing an ERC is not a difficult repair and can be accomplished by the average do-it-yourself offer. If you decide to order the part and wish to repair this on your own, follow these steps:
1. UNPLUG the range. Dangerous voltage is still present inside even with the range turned off.
2. Pull the range away from the wall and turn the unit around so you can access the rear panel.
3. Remove the screws on the back of the operator console.
4. Carefully disconnect the connector plugs to the ERC. Take note of how they are connected, so that you can reinstall them correctly.
NOTE: The connectors are usually color coded with the colors printed on the circuit board. However, if the colors are not printed on the board, write them down. (A digital camera also comes in real handy for this).
5. With the connectors removed, remove the mounting screws to the ERC and the assembly will come out.
NOTE: Most replacement ERC boards do not come with the overlay. This is the plastic pre-printed number display. The overlay can easily be peeled off and re-used. Just make sure you properly orient the overlay so that you don't inadvertently place it on the new board upside down. If your existing overlay is damaged, you will need to order separately.
6. Install new ERC using the steps provided in reverse order. Minimize handling the new circuit board with your bare hands to avoid damaging the board.
Thank you and thank for using fixya.
Posted on Oct 12, 2010
  • 1 more comment
  • Oloyede Monsuru Oct 12, 2010
    What is the comment like?.
    Thanks once again.
    Yes.
    Thanks once again.
    hello,
    Good luck
    thanks once again.
All 4 rings get extremely hot immediately and don't cool down.
Appliance Science: The hot physics of induction cooktops ...
www.cnet.com > Appliances
CNETJan 12, 2015 - Induction cooktops don't heat up themselves: they create heat in the base of the cookware. ... the cookware, and so react quicker when you turn the dial up or down. ... US consumers don't like them because they grew up on gas rings. ...pans, they don't get hot when you put them on an induction cooktop.
4 Lessons I Learned From My Electric Stove - Life in the ...
www.thekitchn.com/why-im-grateful-fo...
Apartment Therapy's The KitchnFeb 24, 2015 - Electric stoves don't have a lot of redeeming qualities. ... "low" burners rather than wait for the front burner to sufficiently cool down. ... burner for all my cooking, as I did when I cooked on a gas stove. ..... I was used to looking at the size of the flame to gauge how hot it really was, I never looked at the dials.
Moving From Gas to an Electric Stove: What I've Learned So ...
How to Fix Problems With Burners on an Electric Stove ...homeguides.sfgate.com > Landlords & Tenants > Landlord ProblemsElectric stoves rely on electrical resistance to heat up the burners on the cooktop, which means they function much in the same way as electric heaters. ... When one of the burners stops working, you can usually trace the problem to the burner switch, theburner receptacle or the ...Electric Range Stove Repair: How To Repair Burner ...? 6:52https://www.youtube.com/watch?v=ndQU7RtqfRwJan 31, 2012 - Uploaded by applianceassistantHow to Fix Electric Stove Burner Elements That Won't Turn On Or Won't Turn Off. ... How To Test Stove ...Fixing Electric Stove Burners that Don't Heat Up Properly ...? 2:34https://www.youtube.com/watch?v=GfqaPcha__o
Dec 15, 2015 | Kitchen Ranges
2 hobs on my electric cooker are not working
? 2:34
Jul 2, 2012 - Uploaded by SamuraiRepairman
Fixing Electric Stove Burners that Don't Heat Up Properly ... Coil Surface Element Test - Electric Stove Repair - Duration: 2:04. by... Temporary Repair For Electric Plug In Range Stove Surface Element Burner Not Working ...
? 6:52
How to Fix Electric Stove Burner Elements That Won't Turn On Or Won't Turn Off. ... More Range and Stove Troubleshooting, Repair Help, And ... Fixing Electric Stove Burners that Don't Heat Up Properly - Duration: 2:34. by ...
Oct 26, 2015 | Ovens
The F1-2 error code appears on the range and the oven stops working but stove top burners still function?
Hi adsdunn2,
The F1:-2 error code means "Runaway Clean Lower oven". You need to check the oven temperature sensor, replace if necessary.
Hope it helps.
Thank you for using FixYa.
(Positive feedback will be greatly appreciated.)
Aug 20, 2011 | Maytag MER6772 Gemini Electric Kitchen...
F5 display not turning burners on
Hi
Thanks for using FixYa. Error F5 means that the control board has failed and to resolve this unfortunately you’ll have to replace the control board. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 03, 2010 | Frigidaire PLEF398AC Electric Kitchen...
I have a Kenmore Ultra Bake Stove, we had a power outage and neither the oven nor burners works. The code on top reads PF 5Ab. What can i do to reset the stove?
PF is usually power failure.
If "PF" appears at any other time, a power failure occurred. To remove "PF"and to reset the clock, press STOP/CLEAR.
Unplug the unit for half an hour or so to see if it will reset.
If not try to get into the diagnostics so you can see if there is a stored
error code
Feb 15, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Frigidaire electric stove, burners work oven does not. No clock
one of the stoves does not work. What could be the problem and how to fix it?
Thanks
Jan 06, 2010 | Frigidaire FEF336BC Electric Kitchen Range
Electric range burners and oven element just stopped working. Burner indicator light came on and oven temp setting displays correctly. Clock went into set mode automatically, though. Burner came back on...
check the power behind the stove, the outlet for 220 volts, i just fix one with the same problem, it was getting 110 volts but not the 220 volts. so there was nothing wrong with the stove but with the power source.when the stove indicator lights work and the clock, it means that only 110 volts are coming to the stove.
Dec 10, 2008 | GE JBP24 QuickClean Electric Kitchen Range
Stove won't heat
Oven was working, I had it on pre-heat, then I turned on the stove top, but the burners won't heat. When I turn on the stove top the stove makes a short BUZZ noise and the clock area lights up, when the burner is turned off all the lights go out. Please help, food prepared.
Thank You
Dec 02, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Problem with Kenmore Electric stove
I have kenmore stove mod.790-95660103 you turn on any top burner . T he small one inside the big burner comes on Roy
Nov 24, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Maytag MER5775Q Electric Kitchen Range Logo
232 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
