Question about Omron HEM 650 Wrist Blood Pressure Monitor
When I take my blood pressure, sometimes it starts to inflate (this is an electric cuff) then stops, then starts up again....always know its going to be high when this happens. WHY does this happen? My neck is tight and so is my left shoulder.
  • 490 Answers
Please seek immediate medical assistance.
Posted on Oct 12, 2010
Cuff doesn't inflate lifesource ua767 bp monitor. How do I reset or fix this? Have brand new batteries.
Inflating a Blood Pressure Cuff - YouTube
? 1:01
www.youtube.com/watch?v=8e6qtnHa8ps
Sep 30, 2008 - Uploaded by expertvillage When you take a blood pressure reading it is important to inflatethe blood pressure cuff until you no longer ...
Sep 24, 2015 | Lifesource Health & Beauty
I have a walgreen blood pressure monitor that you have to inflate and i dont know when to stop inflating and sometimes i inflate too much and gives me an error what am i doing wrong i lost the manual...
if you have to inflate it manually, usually 190 to 200 is a place to start. If you can tell me who the manufacturer is and the model number, I may be able to furnish you an Owners Manual.
Hope this helped you. Please let me know.
May 16, 2011 | Health & Beauty
When the blood pressure monitor reads E- error. What is the reason? Not keeping the wrist still?
It depends on which E-error you're getting.
EE - indicates several things:
  • Cuff has been placed incorrectly. Always place cuff on wrist 1" above heal of hand.
  • Did you talk or move during measurement?
  • Shaking of the wrist with the cuff ON.
E1 - Air circuit abnormality. Measure again.
E2 - Inflation pressure exceeding 300 mmHg. Switch the unit OFF.Wait 1 minute, then measure again.
E3 - Error determining measurement data. Measure again.
Hope this helped you to determine which Error you're receiving. Please let me know.
Apr 30, 2011 | Walgreens By HoMedics Automatic Wrist...
More frequently my Omron HEM-780 seems flaky. It would apply pressure and count up to 112-120 then start deflating, then inflating, etc. Then it would count down by units and end up displaying E. It would...
Part of the problem may the the placement of the cuff. Generally, if it's not placed correctly. the cuff will re-inflate trying to find the correct stopping point for inflation. Any movement of your arm could cause this. Also, if you haven't replaced the batteries lately, you should do that. Also check to make sure there are no air leaks in the rubber tubing or the cuff. Check your Owners Manual for the exact placement of the cuff.
Feb 07, 2011 | Omron HEM 780 Automatic Blood Pressure...
The cuff squeezes my arm too much and it hurts. The reading is way too high everytime. I don't know how to adjust it.
do not inflate the cuff too much. if you know your usual blood pressure, just add about 5-10 mmHg when you inflate it so that you won't hurt yourself. for example, if your BP is usually 130/90, squeeze the cuff to 135-140 only. but if you doubt that your BP is way much higher than that by assessing on what you are feeling, just do not squeeze the cuff further than 200.
Jan 21, 2011 | Life Fitness Ultra Blood Pressure Monitor...
What does it mean when you get a reading then 3 consecutive readings say EE
What is the pattern of the EE? If the two E's are on the same line, then you didn't inflate the cuff to a sufficient pressure. (Wait 2-3 minutes before trying again and then inflate the cuff to 40 mmHg higher than the previous attempt.)
If the Es are arranged vertically, then you overinflated the cuff. Any [ressure above 300 mmHg is beyond the range that this bp monitor can handle. If you reached this point by getting several underinflation alerts, ask your medical professional to test your bp and recommend the starting inflation level that you need.
Make sure that you have the cuff on properly. You may need to consider a different bp pressure cuff size to get an accurate reading.
I hope this.
Sep 09, 2010 | Omron Model HEM 432C Manual Inflation...
Walgreens HD303 Blood Pressure Monitor error 3
Possible explanations and work-arounds based on various blood pressure monitors..net is if it has worked religiously like mine had and this error comes up, and the simple fixes below do not work, there is something internally wrong with the unit..there does not seem to be any customer reset or obvious fixes..
Error Description Potential cause and remedy
«Err 3» No pressure in the cuff
An adequate pressure cannot be generated in the cuff. A leak
may have occurred. Replace the batteries if necessary. Repeat the
measurement.
Error Codes
Err 0 No pulse is detected
Err 1 Inflation rate is too low
Err 2 Systolic reading unattainable
Err 3 Cuff pressure is too high
Err 4 Diastolic pressure is outside of operation range
Err 5 Cuff deflated too fast
Err 6 Cuff deflated too slow
Err 7 Systolic pressure is outside of operation range
Err 8 Overall pressure is outside of operation range
Err 9 Cuff is unable to inflate to the necessary pressure level
Error No. Possible cause(s)
Err 1 No pulse has been detected. Cuff may be positioned incorrectly.
Err 2 The arm was moved during the measurement.
Err 3 Inflation of the cuff took too long. The cuff is not positioned correctly.
Apr 08, 2010 | Walgreens Wrist Blood Pressure Monitor
Omron hem-704C blood pressure monitor show down
If your HEM 704C fell hard, it is probably the pressure transducer that is faulty, broken. To my experience it is cheaper to buy a new one then to have it repaired by a technician
Dec 04, 2009 | Timex Health & Beauty
WITH AUTOMATIC CUFF BLOOD PRESSURE MONITOR GETTING ERROR
E might represents insufficient inflation for your mom. For automatic inflation monitors usually there is a mechanism to keep inflating the cuff to higher pressures for people with higher BP. Check how is done. In some auto monitors,while cuff is inflated you keep pressing on START button until pressure reaches to some 15 to 20 mmHg higher than the pressure that auto usually stops and displays E.
Mar 04, 2009 | Mabis Automatic Digital Blood Pressure...
When the pressure comes up on the monitor the top number was reading EE. It did it three times. I can't find the instructions. The machine is an Omron model: 741CREL. Thanks.
EE=Cuff under-inflated=not inflated enough. While cuff is inflated, keep pressing START button until pressure reaches 15-20 mmHg higher than the pressure when it stops and displays EE. Make sure at least 5 min allowed between readings.
Feb 21, 2009 | Omron Automatic Blood Pressure Monitor...
Omron HEM 650 Wrist Blood Pressure Monitor Logo
610 people viewed this question
Top Omron Health & Beauty Experts
Md Fazlurrahman
Md Fazlurrahman
Level 1 Expert
jay kaye
jay kaye
Are you an Omron Health and Beauty Expert? Answer questions, earn points and help others
