Question about GPX Audio Players & Recorders
I have a gpx mw 140 mp3 player it has frozen after some downloads what can i do to remove corrupted files?
mikethompson
  • 155 Answers
SOURCE: help to recover or repair a corrupted file on my daughter's sansa mp3 player
If the file is corrupted then there is no way for you to play nor listen to it. If the player is saying the file is corrupted and to test if the file is really corrupted please try to do this steps. Connect the player to the computer. Open My Comptuer window and open the player locate the file and try to copy that file to your desktop and play that file. If the file copied and played successfully then that good. If not the only way to prevent this is to format the player. Change the player to MSC mode then connect to the computer and open my computer and right-click on the player and choose format remove the check on the quick format and click start to format the player. Formatting the player will delete all the files and data on the device and it will fix any bad sectors that would cause file corruption on the player.
Posted on Jul 22, 2007
Ongion
  • 37 Answers
SOURCE: MacBook Intel and GPX MP3 Player
The GPX MP3 Player will not recognize .m4a files. You must convert the files to MP3 files first. To do so, in iTunes, click "Edit, Preferences". Change the tab to "Advanced". Inside, there should be a second tab control. Change that to "Importing". Change the "Import Encoder" to "MP3 Encoder". Close those windows. Select the song you want to convert to an MP3, right click, and choose "Convert selection to MP3". Then, locate the file that was created, and put it on your GPX. If you want to convert your entire library, just select all files using Control+A.
Posted on Apr 05, 2008
SOURCE: gpx mp3 player downloads
igo
Posted on Nov 22, 2008
  • 4 Answers
SOURCE: compatability of GPX MP3 player MW3847 with Windows Vista
I have Vista and when I open MY Computer after I've connected my gpx mw3847 it shows up as GPX (F:). I did not format it. If I right click on GPX (F:), the drop down menu shows a FORMAT item there. But I can drag or copy songs to it without having to format it. The (F:) stands for the drive letter so yours might be different.
Posted on Jan 11, 2009
SOURCE: GPX MW-3847 MP3 Player How do i disable write protection
If you have an mp3 player like the one shown in the picture, then just flick the hold switch on, then flick it again to off. This should work. It worked for me.
Posted on Jul 09, 2009
I need a instruction manual for a GPX MP3 digital player - MW238P. I am not able to download music onto this player. Thank you.
You can download the manual from the manufacturer's web site at
http://www.gpx.com/owners_manuals/MW2X8B-IB.pdf
Nov 03, 2010 | GPX MW-238B MP3 Player
How do i remove write protection so to delete file?
How do i remove write protection from flash memory sony 500GB?
Feb 19, 2010 | GPX MW-3847 MP3 Player
How do you remove all of the music/data from the GPX ML638B?
Deleting Files,Pictures,etc from MP3 Player
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release, right click and then click on "Delete"
Now you mp3 player should be clear of the files/songs you do not want.
Good Luck,
I hope this helps
Nov 19, 2009 | GPX MW-3805 MP3 Player
Windows media will not sync because mp3 is not responding
If the mp3 file is not responding then more than likely you have a corrupt mp3 file and need to either redownload the mp3
Sep 24, 2009 | GPX MW-3847 MP3 Player
Device will not sync. i only have 1% memory on the gpx mtp. it says no file, when there is sonngs on the player.
it happens if the file is got corrupted or not getting read properly.reformat the mp3 player drive then check again by reloading the files again.then sync and check out.
Aug 30, 2009 | GPX MW-3847 MP3 Player
Can not download music to player.
Windows Media Player says that my ML638B is full but it’s actually empty. How do I fix this problem?
If this problem occurs then your ML638B needs to be formatted.
1. Connect your ML638B to your computer with Windows XP or later.
2. By default your computer will recognize ML638B as GPX MTP Device. Press the POWER button from top of your ML638B, to change it to USB mode connection. You will also see USB on the screen of ML638B.
3. ML638B will now mount 2 drives, one as Tools (as CD-Drive) and second as Removable Disk (Drive) – under My Computer on your Windows Desktop.
4. Right click your mouse and then select the Format option. When the Format Removable Disk window appears select the Start button to start formatting your MP3 player.
Dec 13, 2008 | GPX MW-3805 MP3 Player
MW-3847 MP3 player will not play DMA 10 liscense files
Try updating the firmware to the latest version.
Jul 01, 2008 | GPX MW-3847 MP3 Player
120 people viewed this question
Top GPX Audio Players & Recorders Experts
Sandy Moore
Sandy Moore
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
