Question about Surebonder 9600 Pneumatic Fine Wire Staple Gun With Carrying Case
Surebonder 9600 - does not shoot out the staples - I don't understand how the pusher and the spring work>
Mine did the same thing. I had it stored improperly. So I took it apart, removing the 4 top and front allen bolts, and the downpusher had a tad of rust on it, cleaned and lubed it, put it back together, and it works like new again!
Posted on Nov 12, 2017
  • 20 Answers
Hold the 9600 upside down. The front of the gun in your left hand using your right hand squeeze on the track release and slide it open to the right. Lay your staples in front of the track that you just slid open. Slide the track over the staples. Ensure that your air compressor is set at 80 psi a brand new gun needs 6 drops of air tool oil through the air inlet before the first use if you don't have an automatic oiler that is recommended then you must manually oil with three drops every third strip of staples. Store your tool at room temperature when you're not using it.
Posted on Nov 11, 2014
I need a solution to this problem too
Posted on Jan 17, 2011
How to replace the spring in the staple loader
Call the manufacturer with your email address and request step by step instructions on replacing the pusher and spring in your specific model number.
Jun 03, 2014 | Surebonder Pneumatic Stapler
Stapler trigger stuck
Check for a trigger lock/bar that slides up or down to unlock trigger. If no lock, take a small flathead screw driver and jiggle it in the back of the trigger.
Aug 17, 2013 | Surebonder Pneumatic Stapler
Surebonder 9600
Call the manufacturer with your email address and ask for detailed instructions on how to replace the pusher and spring on your specific model number.
These are instructions on replacing the spring and pusher for Pneumatic model #'s: 9600, 9610, 9615.
1. Wearing protective eyewear, remove air line supply HOSE from your gun, turn gun upside down holding the front of the gun in your left hand
2. Remove u-shaped piece that holds the track in place at the back of the bottom of the gun.
3. Slide track out of gun.
4. Take the long black spring (part # 38) and hook one side of it to the hook inside the pulled out track.
5. Feed the other side of the spring under the silver wheel in the front of the track and pull it up holding the tension. You might need to use the end of a paperclip to feed the spring through.
6. Take the u-shaped pusher (part # 33) and place the other end of the springs hoop onto the hook inside part #33. Make sure the opening of the hook faces the back of the track, and that you see the yellow tape so that it will show in your view window.
7. Carefully place part #33 with the spring attached and the opening of the hook facing the back of the track, back onto the front of the track. The springs tension will hold it in place.
8. Carefully slide the track back into the bottom of the gun making sure you are placing each side of the track into the grooves.
9. Carefully snap the u-shaped lock back onto the bottom of the track to hold the track in place.
10. With the tool upside down, slide your track open and be sure to place your staples in the bottom of the gun itself with the points of the staples pointing up towards the ceiling, not on the track.
Parts are available online at www.surebonder.com on the left hand column, select Pneumatic Parts, then select your tool. It will bring you to the ordering page.
Mar 17, 2013 | Surebonder Pneumatic Stapler
My rexel stapler does not work, any help[
When you lift up the top of the stapler (as though you are going to put staples in), does the pusher slide freely back and forth? It might be getting stuck at some point and not pushing the staples (either due to a worn pusher spring, or friction). First (after removing the staples) try spraying some light oil on the mechanism and lifting the top part of the stapler up and down a few times and observe how easily it moves back and forth. Also, with the top open try GENTLY sliding back and forth a little - if it slides fine with no sticking, try loading staples and using stapler. If it slides ok, but doesn't quickly return to it's "normal position" when pulled so as to put tension on the spring, rhen the spring may be worn and need replacing.
Sep 11, 2012 | Office Equipment & Supplies
The staples do not go far enough into the sdlide chamber to allow the hammer to strike the staple. The staples do not show in the openning when it is loaded. What am I doing wrong? I have a model D51420 18...
I believe on that model you have to release the magazine latch, pull the lower half all the way back, load the staples into the upper half of the magazine, then close and latch the lower half. The staple pusher and spring are located in the lower half so the staples need to be in front of that for them to be properly pushed into the nose. Also make sure you are running the correct staple. There are 1/4" and 3/16" narrow crown staples out there and they don't interchange. The staples should slide freely in the magazine when they are loaded.
Jul 17, 2011 | Dewalt Air Tools & Compressors
Do I adjust the staple depth with the pressure from the regulator?
there should be a thumb screw behind the trigger. turn it clockwise for a deeper depth and counter clockwise for shallower.
Let me know if this helps
Feb 26, 2011 | Surebonder 9600 Pneumatic Fine Wire Staple...
How do the staples stay in place in my stanley 1/4" stapler? They slide back and forth and therefore aren't in place for the stapler to work?
There should be a pusher that is attached to a spring. If the spring broke, or the pusher is missing the staples will not stay in place.
If you can locate a model number on the tool, you go to bostitch.com to find the parts you may need
Apr 18, 2009 | Stanley Tools Staple/Brad Nail Gun
Swingline Stapler Staples Only After You Open It Up....
Dec 14, 2008 | Staples Swingline® 36115 Staple Guns Tools...
Surebonder 4.8 v cordless stapler
with mine there is a fine spring on the plunger which holds the staples in which i restretch every now and then you could also try checking for jammed staples and putting one or two drops of oil on the shaft that pushes the staples down after the oil operate afew times empty of staples see if this helps bestaluck glenn
Oct 26, 2008 | Tools & Hardware - Others
Surebonder 9600 Pneumatic Fine Wire Staple Gun With Carrying Case Logo
634 people viewed this question
Top Surebonder Tools & Hardware - Others Experts
Joseph Wright
Jo Ann
Level 1 Expert
Are you a Surebonder Tool and Hardware - Other Expert? Answer questions, earn points and help others
