Question about Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV
Blue lines and tinges near to the bottom of the screen and now moving up slightly
We have just started to observe bluish lines and tinges near to the bottom and lower half of screen, I don't think it is the lamp.
Alan
  • 1 more comment
  • tsutko Jun 04, 2008
    We have the 55" Sony Wega rear projection HDTV and are experiencing the same thing - blue is "leaking" along the bottom and left side of the screen. Any ideas?
  • Anonymous Jun 13, 2008
    I have the same problem...seems to get worse as the tv stays on longer(gets hotter?)......and it's getting worse over time.....
  • broncofl Jun 17, 2008
    Same problem with the blue on the lower left corner, also have blue dots showing up depending on the picture showing. I also have the other problem where it shuts off for about 20-30 green flashes and then comes on followed by the sound a few flashes later. I going to try to change the bulb for that. I had read on the SONY website about a month ago that SONY had extended the warranty on these models till the end 2008. Anyone else found that out?
    Genius:
  • 1,847 Answers
For free sony support go the link choose the produce and chat for free
http://esupport.sony.com/US/perl/support-contacts.pl
Thanks for using fixya. Hope this solution may have helped you.
Posted on Jun 17, 2008
Brand new. Leaking a clear light oil out of lower left door hinge. French doors. Slight bluish tinge on cotton ball. Smells like oil.
Contact supplier to check if it a fualt. I do however suspect that it is oil for lubricating the hinge and that too much was applied. Hope this helps
Mar 04, 2016 | Fisher and Paykel Refrigerators
How do I fix vertical lines and no picture.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to both Plasma & LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 20, 2015 | Vizio E320VP 32" LCD TV
A slight blue ting has developed at bottom of screen.
Like all sonys Light engine, Call Encompass Parts Distr. or look them up online 1-800-638-3328 they have 20 of them in stock.
Nov 20, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Hi i have a bluish tinge on screen?
clean the entire optics of your projector.
Oct 09, 2009 | Hitachi Performa CP-RS55 Multimedia...
Horizontal blue lines with a slight blue wash in the screen
Its because of Over Voltage of Screen (G2) to Blue CRT.
Take off front lower cover (speaker grill) and unscrew board. There you will need to find Focus Block mounted having 6 control knobs. 3 knobs are for Focus control and 3 are for Screen volts control. Find Blue Screen control knob and turn is Counter Click Wise slightly until bluish shade disappear on screen including few blue horizontal lines.
If you select AV input to adjust that will be fine as you do not need to wait for dark-scene.
Apr 09, 2009 | Sony KP-65WS500 65" Rear Projection...
Sony KDF50 rear projection TV with a Blue tinge (haze) on screen
You have a problem within the light engine. This a hugely expensive. If the set is not too old you could contact Sony and see if they will help you out. Otherwise it is not eceonomical to repair
Mar 30, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Mitsubishi WD-62526
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Jan 13, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Sony LCD tv
i guess its the old magnet problem maybe in fluke u or someone in your house had taken a magnet around your tv try fixing it with a magnet by moving the magnet again around the screen and using the same old technique by moving the magnet slowly on the defected area and then quickly taking it off
Nov 05, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV Logo
63 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
