Question about Kenmore HE2 Plus Front Load Washer
Water leaking from the dispenser on front load washing machine
  • 15,935 Answers
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating and POSITIVE TESTIMONIAL is appreciated for answering your FREE question
Posted on Oct 12, 2010
Whats so tricky about the repair?
Amana Washing Machine Parts - RepairClinic.com
www.repairclinic.com/Shop-For-Parts/.../Amana-Washing-Machine-Parts
Huge selection of Amana Washing Machine parts in stock. Same day ... A small leak in front of the washer could be caused by a defective pump. OEM Part ...
www.repairclinic.com/Shop-For-Parts/a11/Washing-Machine-Parts
Find your parts fast and repair your Washing Machine with our free repair help. ...Admiral · Amana · ARDO · Asko · Bosch · Crosley · Danby · E-Wave · Electrolux · Estate ..... A small leak in front of the washer could be caused by a defective pump..... Washing machine door lock and switch assembly for front loading washers.
How To Fix Front Load HE Washer Does Not Dispense ...
removeandreplace.com/.../front-load-he-washer-does-not-dispense-deter...
May 15, 2015 - HOW TO REMOVE WASHING MACHINE SOAP DISPENSER ...
Jan 10, 2016 | Amana Front Load Washing Machine Washer...
Why would the machine leak out the detergent drawer when filling?
When the machine starts to wash water passes into the detergent dispenser and carries the detergent into the drum, if the detergent outlet is blocked, or resticted, this will cause the water to leak out of the dispenser.
Check the dispenser to see if an accumulated crust of powder is clogging the outlet holes, most dispensers are removable for cleaning, check your machine instructions for details.
Dec 13, 2010 | Whirlpool GHW9400 Front Load Washer
Water leaking into soap dispenser when machine off
faulty water valve turn both off to see if it stops then turn on one at a time if it leaks thats it
Dec 15, 2009 | Miele Touchtronic W3033 Front Load Washer
GE whre5260e1ww zh133346g top load washer is leaking small amount from the bottom of the machine during wash cycle? I took the back of the machine off and the pump and motor assembly had broken off from...
Hello there:
Here is a few tips that might help you out
Hope that they are very helpful for you
Best regards Mike
Washing machine is leaking Washing machine leaks are very common. There are many places a washing machine can leak from although most leaks come from the same few places. The most common cause for a leaking washing machine is the door seal. Door seals often get holes in them and water leaks down the inside of the washing machine which then runs out under the front. Water leaking down the front of the washing machine from the door can be caused by a worn door seal (the flange part that the door glass presses against when closed) or something trapped between the door seal and the door glass which breaks the seal. If the door seal doesn't look worn, or it's too young to be worn, then try cleaning the door seal's flange and the door glass on the inside of the door. Bits of cotton, un dissolved washing machine detergent etc can cause a leak.
Soap dispenser leaks
The next most common cause of a leaking washing machine is the soap dispenser. Leaking water from a soap dispenser is often caused by a blockage, or water pressure that is simply too high. Despite seeing many leaking soap dispensers, I've never seen a soap drawer with a seal, they just rely on water not getting to the front which is not really good enough. Some Hoover soap dispensers in particular, are renowned for leaking, and over the years Hoover have had to introduce modified soap dispensers twice.
Some washing machines, can flood water out of the soap dispenser when a hose gets blocked (usually with un dissolved soap powder) Indesit, and Candy, as well as some of the later Hoover washing machines suffered from this design flaw. The hose where the water is flushed down, was right at the front of the soap dispenser on these washing machines and the hose wasn't wide enough. Un dissolved powder from a tablet or lumps of detergent through poor hot water pressure can block this hose solid. (Note: water flooding out of the front of a washing machine's soap dispenser can also be an indication of overfilling or a partial pump blockage if it does it when spinning)
Finally, black gunge in the top of the soap dispenser can cause water to spray towards the front and leak. Take out the soap dispenser drawer and look at the roof of the soap dispenser. If it's covered in black gunge, blocking some of the water holes, it could be causing problems. In extreme cases I've had to replace the dispenser.
Tips for finding a leak on a washing machine
  • If you have a leaking washing machine, and you can't see where it's coming from, shove some newspaper underneath the washing machine. The slightest drop will give a clue where the water is leaking from. Pull the sheet out regularly to check for water leaks.
  • Water can run round things and drip onto other parts. Be careful with your diagnosis, as water dripping from a hose at the bottom could actually be leaking from somewhere else higher up.
  • Leaks usually leave marks, so it's possible to see something is leaking even without witnessing it. The soap suds that come out with the leaking water leave white trails. Rust is a good indicator of a water leak too. However, if you have had a previous leak cured, the "evidence" of a leak may still be present so be sure you don't blame a part that was repaired in the past.
  • If the washing machine leaks only at the end of the wash, when water is being pumped out. Make sure water isn't backing up and cascading over the top of a blocked drain pipe in the plumbing.
  • WARNING: Don't get electrocuted trying to witness a leak. It's dangerous running the washing machine with the top or back off.
Nov 13, 2009 | GE WDSR2080D Top Load Washer
Whirlpool front load leaking water from the detergent dispenser
Could be pressure too high reduce feed to machine only ....Slightly...Also try cleaning just in case its blocked
Sep 28, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Lg tromm front loading washing machine has
Yes the system is cloghed. Pull the detergent drawer out and clean the drawers housing. try using some bleach. It allways helps.
BE ADVICED: after using bleach run quick wash cycle on without any load, it's just to get rid of all bleech remains and not to damage your clothes
Update me about your progress
Jul 20, 2009 | Washing Machines
Water leaking from soap dispenser front loading washing machine
water leaking from soap dispenser. so water pours out under the soap dispenser
Apr 19, 2008 | Whirlpool Washing Machines
Frigidare front load washing macine leaks water
Sounds like the dispenser is leaking somehow, there is no filter that would cause it to leak. Remove lid of washer by screws on back lip and inspect during fill to see where leak is.
Jan 20, 2008 | Washing Machines
Leaking from the dispenser
Try to pull out your dispenser drawer gently to clean out thoroughy. If you cant succeed, use a tooth brush, see that the brush does not fall in. Probably you have dried powder blocking the passage, nothing else.
Rate me pl.
Nov 12, 2007 | Whirlpool LHW0050PQ Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
434 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
