Question about Raypak Free Hydraulic Lift Gate Delivery - No L...
Heater wont ignite? - Raypak Free Hydraulic Lift Gate Delivery - No L...
    Top Expert:
  • Raypak Master
  • 5,061 Answers
Check to see if safety circuit ok if ok check ignitor if ok see if cobwebs in gas lines
Posted on May 25, 2016
My 40-FAC heater will not ignite and run. The igniter has been replaced. What should I check next?
These models require electrical power to run the blower fan.
When you connect the electrical cord, the fan should turn on, then you should be able to start / ignite the propane. if the fan does not turn on when you connect the power cord, you will not be able to ignite the propane.
Dec 09, 2014 | All-Pro Propane Garage Shop Heaters - All...
Heater wont ignite
make sure you have 24 volts ac on both sides of pressure switch if not see if fusible link is ok 24 on both sides ok see if ignitor glows when heater is turned on if it doesn't glow need new ignitor
Jan 10, 2014 | Jandy Pool & Spa
Tempstar furnace wont ignite? fan works just wont ignite?
your glow rod, is shot...fans will come on but it will not ignite your burners
Dec 18, 2010 | Goodman GMS90703BXA Heater
Bosch 25e water heater wont ignite
combi or standard if combi pressure too high and will be blowing off your high pressure release valve which would stop your boiler from igniting best of luck
Oct 27, 2009 | Bosch Water Heaters
Hd100 wont ignite
since heater is calling for heat,i suspect ignitor is faulty.it could just be dirty.remove it clean with fine steel wool.
Jul 14, 2009 | Hayward 100,000 BTU Pool Heater H100ID1 -...
Gas wont ignite
unless you are well trained in troubleshooting you need a pro .carrier furnastys are overly complex you should call carrier dealer if you want the shortest route to a workin system
Feb 23, 2009 | Coleman Propane Forced Air Heater...
Heater wont ignite. Has fuel coming out front of
if the spark plug is sparking it is hot enough to lite the fuel.is ther dirt in fuel tank???is there water in the fuel???? what is the air pressure set at????is the nozzle clean and spraying correctly?????any of these will cause the heater not to fire.not the spark plug.
Feb 20, 2009 | Dayton E51 Oil Filled Utility Heater
Raypak Free Hydraulic Lift Gate Delivery - No L... Logo
46 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
paulcarew
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
