Question about Kenmore 25512/ 25513 Progressive Canister Vacuum
Hose is clear and suction is fime. Icleaned the threads off the rotor brushes but it wont spin
  • 377 Answers
Two things you can do. First, remove the brush and you will find a small plastic clip at each end that holds it in place. Spray a bit of WD40 between the brush and each of these clips then turn each of the clips by hand while holding the brush. They should turn freely with the WD40. As long as you have the brush off, put on a new drive belt. That should rectify the situation unless the motor is burned out. Paul
Posted on Oct 12, 2010
Can't get the roller to spin
i suggest taking hose off and declogging it by using a water hose to make sure its free of debris. Plus check your belt first take off bottom plate the you'll be able to tell if belt is broken which it sounds like it is.
if belt is good and hose is clear and still brush wont spin then your brush motor needs replacing. hope this helps.
Mar 05, 2013 | Eureka Whirlwind Litespeed 5740 Bagless...
Hi my dc07 has lost suction on the roller, but not on the hose there are no blockages cyclone still strong any ideas thanks
Are the brushes in the base of the vacuum spinning? You wont get much suction from the base of the hoover if the brush bar isn't working?
Lie the vacuum on it's side and turn it on. If the brushes aren't spinning then your belt has either come off or broken. I suspect this is the cause of your problem.
Nov 04, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
No Suction/Brush not spinning on Bissell Powersteamer Pro Deluxeb
make sure hoses are clear and check belt
Oct 08, 2009 | Vacuums
The machine will not suction - it will spray and spin the brushes but will not suction - the power is going to the machine, but it will not suction.
Disconnect the suction hose. While running, check the suction port if it works, by putting a piece of paper. If the paper is taken in, then it is oK. Now, check the suction Hose for breaks or opening before the suction head. Breaks or opening breaks the suction power at the suction head. Loose connection between the suction pipe and the suction port also must be check as this will also cause the same
problem. You may need to replace the suction hose
to correct this problem,
Send us the e-mail and your vote if this solves your problem.
Sep 27, 2009 | Eureka Atlantis 2590A Wet/Dry Vacuum
My Bissell TurboForce Bagless Turbo Brush doesn't work
clean the filters..on atop the dustbin, inside the dustbin bottom..and over the fan below..if not sqeaky clean you loose suction
Sep 07, 2009 | Vacuums
Brush spin,good suction at hose, no suction at
Air passage from back of brush head, through the joint, and up to bag, may be blocked.
Jul 11, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Dyson Brush Bar Always Spins
Take off the brush cover and check that the suction orifice is clear. Also check the rubber flaps at the bottom of the hose/handle holder is correctly positioned.
Feb 06, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Lost suction
Hi.
Remove the sole plate turn the 3 plastic screws to unlock & lift off.
Now remove the blockages that have accumilated from the oppening of short clear hose.
Check you can turn brush roller & check belt.
Now reassemble switch on pull handle back & look under machine is brush spinning ?
If not check the knob on side of machine is in drive (D) position.
http://dysonmanuals.llc.nu
Chris..
Dec 27, 2007 | Dyson DC07 Animal Bagless Upright Cyclonic...
Help
as the hose fits into the base (if i am correct) the power at the base should be fine, make sure the base is clean and free from blockage, you say the brush doesn't spin, has the belt broken, if so replace it, (very cheap) and only a couple of screws to undo, the roller not rotating will effect the power of suction dramatically, start from there and see how you go if i have helped please rate me
Sep 15, 2007 | Hoover U8171-900 / U8172-900 / U8173-900 /...
Kenmore 25512/ 25513 Progressive Canister Vacuum Logo
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
